<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen remote Raspberry Pi B]]></title><description><![CDATA[<p dir="auto">Hi everyone!<br />
I’ve been trying to install MM on a Raspberry Pi Model B for a couple of days now and it seems like it’s finally working, but not fully.</p>
<p dir="auto">I don’t have the Raspi always connected to a monitor, but since I was going for the serveronly mode I’m working through SSH with Putty.</p>
<p dir="auto">The MM manual installation worked well, it finished without errors, all the other scripts (sideway display) work too.<br />
Now each time I start MM with \node serveronly\ I get this:</p>
<pre><code>Starting MagicMirror: v2.1.2
Loading config ...
Loading module helpers ...
All module helpers loaded.
Server started ...
Starting module: newsfeed
Sockets connected &amp; modules started ...
Ready to go! Please point your browser to: http://localhost:8080
<p dir="auto">Which should mean that it’s up and running, right?</p>
<p dir="auto">So I head over to my browser but all I see is a black screen.</p>
<p dir="auto">I know that the Raspberry Model B is not supported, but I thought maybe someone, somewhere has an explanation or a way to fix it.</p>
]]></description><link>https://forum.magicmirror.builders/topic/4711/black-screen-remote-raspberry-pi-b</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 19:59:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4711.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Aug 2017 17:37:15 GMT</pubDate><ttl>60</ttl></channel></rss>
