<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM &amp; Google Maps Traffic]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I was looking in the forum and internet, but couldn’t find a solution. Did anyone on you managed to show the google maps route (from A to B) and trafic?</p>
<p dir="auto">Like this (example from this forum):<br />
<img src="https://forum.magicmirror.builders/uploads/files/1473042804638-magicmirror-bingtraffic.jpg" alt="alt text" class=" img-fluid img-markdown" />.</p>
<p dir="auto">I (hope i did) intalled the module MMM-googlemaps. Sometimes I read I need an iFrame, sometimes: it won’t work with an iFrame.<br />
My code:</p>
<pre><code>//		{
		   module: "MMM-googlemaps",
		   position: 'bottom_right',
		       apikey: '*my API*',
			origin: 'Köln,+Deutschland',
			destination: 'Essen,+Deutschland',
			mode: driving,
<p dir="auto">Thx for your support!<br />
Birdy</p>
]]></description><link>https://forum.magicmirror.builders/topic/4726/mm-google-maps-traffic</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 18:36:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4726.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Aug 2017 14:24:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Fri, 08 Sep 2017 08:06:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mirrorolentia" aria-label="Profile: Mirrorolentia">@<bdi>Mirrorolentia</bdi></a><br />
thanks for helping me and sorry for late reply.</p>
<p dir="auto">Here comes the config:</p>
 * MIT Licensed.
var config = {
	port: 8080,
	language: "en",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "AWISTA &amp; Feiertage NRW",
						symbol: "calendar-check-o ",
						url: "https://calendar.google.com/calendar/ical/**********/public/basic.ics"
			module: "compliments",
			position: "lower_third"
			module: "currentweather",
				locationID: "2934246",  //ID from http://www.openweathermap.org/help/city_list.txt
				appid: "************"
			module: "weatherforecast",
			header: "Weather Forecast",
				appid: "***********"
    			module: 'MMM-Vrr',
    			position: "bottom_left",
        			city: 'Düsseldorf',
        			station: '***********',
        			numberOfResults: 6,
        			displayTimeOption: 'time+countdown'
		    module: "MMM-Fuel",
		    position: "bottom_right",
		        api_key: "************",
		        lat: *********,
		        lng: ************,
		        types: ["diesel"],
			radius: 1.4,
			max: 2,
			rotate: false,
		module: 'MMM-Traffic',
		classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
			api_key: '*********',
			mode: 'driving',
			origin: '******+Düsseldorf,+Deutschland',
			destination: '**********+Essen,+Deutschland',
			route_name: 'Home to Work',
			changeColor: true,
			showGreen: false,
			limitYellow: 5, //Greater than 5% of journey time due to traffic
			limitRed: 20, //Greater than 20% of journey time due to traffic
			traffic_model: 'best_guess',
			departure_time: 'now',
			interval: 60000,
			showWeekend: false,
			allTime: true,
	                width: '300px',
	                height: '300px'
<p dir="auto">and here is netstat:</p>
<pre><code>pi@raspberrypi:~ $ netstat -nalp | grep 8080
(Es konnten nicht alle Prozesse identifiziert werden; Informationen über
nicht-eigene Processe werden nicht angezeigt; Root kann sie anzeigen.)
tcp6       0      0 :::8080                 :::*                    LISTEN      1119/electron.js
tcp6       0      0 ::1:51608               ::1:8080                VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:8080                ::1:51610               VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:51606               ::1:8080                VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:51600               ::1:8080                VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:51610               ::1:8080                VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:51604               ::1:8080                VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:8080                ::1:51608               VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:8080                ::1:51598               VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:8080                ::1:51600               VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:51602               ::1:8080                VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:8080                ::1:51606               VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:8080                ::1:51604               VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:8080                ::1:51602               VERBUNDEN   1119/electron.js
tcp6       0      0 ::1:51598               ::1:8080                VERBUNDEN   1119/electron.js
pi@raspberrypi:~ $
]]></description><link>https://forum.magicmirror.builders/post/27787</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27787</guid><dc:creator><![CDATA[birdy]]></dc:creator><pubDate>Fri, 08 Sep 2017 08:06:24 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Sat, 02 Sep 2017 16:31:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/birdy" aria-label="Profile: birdy">@<bdi>birdy</bdi></a><br />
Sorry for the delayed response. Got caught with stuff :(<br />
By any chance do you have some other server running in parallel which is also listening on 8080 and using any available IPv6 address. Ideally you should have only “node” running with the specified port<br />
You can check this with netstat.</p>
<pre><code>netstat  -nalp | grep 8080
tcp6       0      0   ::: 8080                 ::: *                    LISTEN      2350/node
tcp6       0      0 ::1:43558               ::1:8080                ESTABLISHED 2103/libpepflashpla
tcp6       0      0 ::1:8080                ::1:43558               ESTABLISHED 2350/node
<p dir="auto">You can try killing that service (In the last column i.e 2350/node, 2350 represents PID. You can use "kill -9 ") and then probably restart the Magic Mirror.<br />
Also this may not be related to the actual problem.<br />
Please see if you can post your config.js.</p>
]]></description><link>https://forum.magicmirror.builders/post/27466</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27466</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Sat, 02 Sep 2017 16:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Wed, 30 Aug 2017 15:27:13 GMT]]></title><description><![CDATA[<p dir="auto">you mean like this:</p>
<pre><code>Connecting socket for: MMM-Traffic
MMM-Traffic helper started ...
Sockets connected &amp; modules started ...
Ready to go! Please point your browser to: http://localhost:8080
{ Error: listen EADDRINUSE :::8080
    at Object.exports._errnoException (util.js:1020:11)
    at exports._exceptionWithHostPort (util.js:1043:20)
    at Server._listen2 (net.js:1258:14)
    at listen (net.js:1294:10)
    at net.js:1404:9
    at _combinedTickCallback (internal/process/next_tick.js:83:11)
    at process._tickCallback (internal/process/next_tick.js:104:9)
    at Module.runMain (module.js:606:11)
    at run (bootstrap_node.js:389:7)
    at startup (bootstrap_node.js:149:9)
  code: 'EADDRINUSE',
  errno: 'EADDRINUSE',
  syscall: 'listen',
  address: '::',
  port: 8080 }
]]></description><link>https://forum.magicmirror.builders/post/27265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27265</guid><dc:creator><![CDATA[birdy]]></dc:creator><pubDate>Wed, 30 Aug 2017 15:27:13 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Wed, 30 Aug 2017 08:39:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/birdy" aria-label="Profile: birdy">@<bdi>birdy</bdi></a><br />
Seems like the MM system didn’t initialize the module itself :(<br />
Are you seeing any errors on the console from where you run “node serveronly” or on the chromium browser i.e from More Tools–&gt; Developer Tools–&gt;Console.</p>
]]></description><link>https://forum.magicmirror.builders/post/27254</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27254</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Wed, 30 Aug 2017 08:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Wed, 30 Aug 2017 08:21:15 GMT]]></title><description><![CDATA[<p dir="auto">somehow it’s not working:<br />
<img src="/assets/uploads/files/1504081240197-inkedimg_1205_li.jpg" alt="0_1504081238365_InkedIMG_1205_LI.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/27251</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27251</guid><dc:creator><![CDATA[birdy]]></dc:creator><pubDate>Wed, 30 Aug 2017 08:21:15 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Tue, 29 Aug 2017 15:57:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/birdy" aria-label="Profile: birdy">@<bdi>birdy</bdi></a><br />
Yes that is correct. You will need to copy the lines from /global module**/ all the way till end…somehow the comments didn’t embed the code correctly</p>
]]></description><link>https://forum.magicmirror.builders/post/27221</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27221</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Tue, 29 Aug 2017 15:57:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Tue, 29 Aug 2017 15:42:36 GMT]]></title><description><![CDATA[<p dir="auto">so, as a complete noobie, I just pasted the code (adding Google Api key)  in both files.</p>
<p dir="auto">I can see, there is a gap in the corner (I hope for the map) and if I get you correctly, the map will load “soon”(?).</p>
<p dir="auto">Thank you one more time and will keep u posted.</p>
<p dir="auto">Cheers<br />
Birdy</p>
]]></description><link>https://forum.magicmirror.builders/post/27220</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27220</guid><dc:creator><![CDATA[birdy]]></dc:creator><pubDate>Tue, 29 Aug 2017 15:42:36 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Mon, 28 Aug 2017 09:45:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mirrorolentia" aria-label="Profile: Mirrorolentia">@<bdi>Mirrorolentia</bdi></a> - wow, thx!! I will test it later :) can’t await</p>
]]></description><link>https://forum.magicmirror.builders/post/27162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27162</guid><dc:creator><![CDATA[birdy]]></dc:creator><pubDate>Mon, 28 Aug 2017 09:45:48 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Mon, 28 Aug 2017 07:38:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/devtech8" aria-label="Profile: devtech8">@<bdi>devtech8</bdi></a><br />
Sure that would be great! Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/27159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27159</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Mon, 28 Aug 2017 07:38:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Mon, 28 Aug 2017 06:23:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mirrorolentia" aria-label="Profile: Mirrorolentia">@<bdi>Mirrorolentia</bdi></a> - I was thinking of trying this too, but looks like you have made some progress. I hope to dig into what you have later this week. I had seen some further customization I would like to add when time allows. Thanks for the work on this!</p>
]]></description><link>https://forum.magicmirror.builders/post/27157</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27157</guid><dc:creator><![CDATA[devtech8]]></dc:creator><pubDate>Mon, 28 Aug 2017 06:23:21 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Sun, 27 Aug 2017 19:24:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/birdy" aria-label="Profile: birdy">@<bdi>birdy</bdi></a> you are missing quotes around the drivin mode, should be <code>mode: 'driving'</code></p>
]]></description><link>https://forum.magicmirror.builders/post/27146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27146</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 27 Aug 2017 19:24:28 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Sun, 27 Aug 2017 17:18:22 GMT]]></title><description><![CDATA[<p dir="auto">There are two catches which I will try to correct:</p>
<ol>
<li>The Google Maps have their own lifecycle which I could not align with MM module’s. So you may not see the map in the first instance but it will get uploaded within the next interval (as configured in config.interval).</li>
<li>The Maps div element keeps getting refreshed after every interval which is a bit irritating :(</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/27140</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27140</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Sun, 27 Aug 2017 17:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Sun, 27 Aug 2017 17:19:07 GMT]]></title><description><![CDATA[<p dir="auto">Please install the MMM-Traffic module and replace the MMM-Traffic.js with the above code.<br />
Below is a sample entry in config.js</p>
<pre><code>{
            position: 'top_left',
                api_key: '', // Your Google Maps API_KEY needs to go here
                mode: 'driving',
                origin: '',
                destination: '',
                mon_destination: '',
                arrival_time: '', //optional, but needs to be in 24 hour time if used.
                changeColor: true,
                showGreen: false,
                interval: 60000, //2 minutes
                showWeekend: true,
                allTime: true,
                width: '300px',
                height: '300px'
]]></description><link>https://forum.magicmirror.builders/post/27138</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27138</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Sun, 27 Aug 2017 17:19:07 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Sun, 27 Aug 2017 17:07:38 GMT]]></title><description><![CDATA[<p dir="auto">/* global Module */</p>
<p dir="auto">/* Magic Mirror</p>
<ul>
<li>Module: MMM-Traffic</li>
<li></li>
<li>By Sam Lewis <a href="https://github.com/SamLewis0602" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/SamLewis0602</a></li>
<li>MIT Licensed.<br />
*/</li>
</ul>
<p dir="auto">Module.register(‘MMM-Traffic’, {</p>
<pre><code>defaults: {
    api_key: '',
    mode: 'driving',
    interval: 300000, //all modules use milliseconds
    origin: '',
    destination: '',
    tues_destination: '',
    wed_destination: '',
    thurs_destination: '',
    fri_destination: '',
    arrival_time: '',
    loadingText: 'Loading commute...',
    prependText: 'Current commute is',
    changeColor: false,
    limitYellow: 10,
    limitRed: 30,
    showGreen: true,
    language: config.language,
    show_summary: true,
    showWeekend: true,
    allTime: true,
    startHr: 7,
    endHr: 22,
    avoid:'',
      summaryText:'via',
      leaveByText:'Leave by',
      arriveByText:'to arrive by',
    hideOffHours: false,
setLocalParams: function(){
	// These parameters are populated mostly
	// by node_helper
    this.loaded = false;
    this.mapLoaded= false;
    this.leaveBy = '';
    this.symbols = {
        'driving': 'fa fa-car',
        'walking': 'fa fa-odnoklassniki',
        'bicycling': 'fa fa-bicycle',
        'transit': 'fa fa-train'
    this.commute = '';
    this.summary = '';
start: function() {
    Log.info('Starting module: ' + this.name);
    if (this.data.classes === 'MMM-Traffic') {
      this.data.classes = 'bright medium';
    this.leaveBy = '';
    var myURL = 'https://maps.googleapis.com/maps/api/directions/json' + this.getParams();
    console.log("Querying with loc = " + myURL);
    this.url = encodeURI('https://maps.googleapis.com/maps/api/directions/json' + this.getParams());
    this.symbols = {
    this.commute = '';
    this.summary = '';
    this.updateCommute(this);
// Handler for notifications from any other module asking for
// TRAFFFIC update.
// This will invoke updateCommute with new source and destination
// TODO: The new source and destination will continue to get displayed untill
// it is reset. Will try to revert that
notificationReceived: function(notification, payload, sender){
	Log.log(notification+" received from "+sender);
	var myURL = "";
	if(notification === "TRAFFIC_ACTION_NEEDED"){
		console.log("Received new traffic update request for start: "+payload.start_location+" end:"+payload.end_location);
			    this.getParam_specific(payload.start_location, payload.end_location);
		console.log("Querying with "+myURL);
	    this.url = encodeURI(myURL);
updateCommute: function(self) {
	console.log("updateCommute called");
    timeConfig = {
      showWeekend:    self.config.showWeekend,
      allTime:        self.config.allTime,
      startHr:        self.config.startHr,
      endHr:          self.config.endHr
    if (self.config.arrival_time.length == 4) {
      self.sendSocketNotification('LEAVE_BY', {'url':self.url, 'arrival':self.config.arrival_time, 'timeConfig':timeConfig});
    } else {
      self.sendSocketNotification('TRAFFIC_URL', {'url':self.url, 'timeConfig':timeConfig});
    setTimeout(self.updateCommute, self.config.interval, self);
getStyles: function() {
    return ['traffic.css', 'font-awesome.css'];
createMap_area: function(start_location, end_location){
	console.log("createMap_area invoked");
	if(document.getElementById('map'))
		console.log("Map Div available "+start_location.lat);
		var map_options = {
			center: new google.maps.LatLng(start_location.lat, start_location.lng),
			zoom: 20,
			panControl: true,
			mapTypeControl: false,
			panControlOptions: {
				position: google.maps.ControlPosition.RIGHT_CENTER
			zoomControl: true,
			zoomControlOptions: {
				style: google.maps.ZoomControlStyle.LARGE,
			scaleControl: false,
			streetViewControl: false,
			streetViewControlOptions: {
	    // map div is added to document.body
    	var map = new google.maps.Map(document.getElementById("map"), map_options);
		var start_bound = new google.maps.LatLng(start_location.lat, start_location.lng);
		var end_bound = new google.maps.LatLng(end_location.lat, end_location.lng);
		var marker = new google.maps.Marker({
			position: start_bound,
			map: map
			position: end_bound,
			map: map
		var bounds = new google.maps.LatLngBounds();
		bounds.extend(start_bound);
		bounds.extend(end_bound);
		map.fitBounds(bounds);
		// the preserveViewport is almost mandatory to prevent zoom/pan out of the screen
       var directionsDisplay = new google.maps.DirectionsRenderer({
           map: map,
		   zoom: 20,
		   preserveViewport: true
	   directionsDisplay.setMap(map);
       // Set destination, origin and travel mode.
       var request = {
         destination: end_location,
         origin: start_location,
         travelMode: 'DRIVING'
       // Pass the directions request to the directions service.
       var directionsService = new google.maps.DirectionsService();
       directionsService.route(request, function(response, status) {
           if (status == 'OK') {
               // Display the route on the map.
               directionsDisplay.setDirections(response);
	   this.mapLoaded = true;
	return document.getElementById('map');
createMap: function(){
    var wrapper = document.createElement('div');
    wrapper.style.height = this.config.height;
    wrapper.style.width = this.config.width;
	wrapper.setAttribute("id", "map");
    // This script is appended to the main body
    var outer_script = document.createElement("script");
    outer_script.type = "text/javascript";
    outer_script.src = "https://maps.googleapis.com/maps/api/js?key=" + this.config.api_key;
	outer_script.setAttribute("async","");
	outer_script.setAttribute("defer","");
    document.body.appendChild(outer_script);
    outer_script.onload = function(){
		console.log("Added the map script to document body");
    return wrapper;
getDom: function() {
    var commuteInfo = document.createElement('div');
    var routeName = document.createElement('div');
    // Map display
    if (!this.loaded) {
        console.log("[MMM-Traffic]Pre-loading invoked");
        //wrapper.innerHTML = this.config.loadingText;
		// Invoke adding the Google Maps base script to the dcoument.body
		// It needs to be invoked only once.
        wrapper.appendChild(this.createMap());
        return wrapper;
    if ((this.commute == '' || this.commute == '--') &amp;&amp; this.config.hideOffHours &amp;&amp; !this.config.allTime) {
        wrapper.innerHTML = '';
        return wrapper;
    // Obtain start/end co-ordinates
    var start_loc = this.start_location;
    var end_loc = this.end_location;
    console.log("Start lat "+start_loc.lat+" long "+start_loc.lng);
    wrapper.appendChild(this.createMap_area(this.start_location, this.end_location));
    //symbol
    var symbol = document.createElement('span');
    symbol.className = this.symbols[this.config.mode] + ' symbol';
    commuteInfo.appendChild(symbol);
    if (this.config.arrival_time == '') {
      //commute time
      var trafficInfo = document.createElement('span');
      trafficInfo.innerHTML = this.config.prependText + ' ' + this.commute;
      commuteInfo.appendChild(trafficInfo);
      //routeName
      if (this.config.route_name) {
        routeName.className = 'dimmed small';
        if (this.summary.length &gt; 0 &amp;&amp; this.config.show_summary){
          routeName.innerHTML = this.config.route_name + ' ' + this.config.summaryText + ' ' + this.summary;
        } else {
          routeName.innerHTML = this.config.route_name;
    } else {
      //leave-by time
      trafficInfo.innerHTML = this.config.leaveByText + ' ' + this.leaveBy;
      //routeName
          routeName.innerHTML = this.config.route_name + ' ' + this.config.summaryText + ' ' + this.summary + ' ' + this.config.arriveByText + ' ' + this.config.arrival_time.substring(0,2) + ":" + this.config.arrival_time.substring(2,4);
        } else {
      console.log(typeof this.config.arrival_time );
          routeName.innerHTML = this.config.route_name + ' ' + this.config.arriveByText + ' ' + this.config.arrival_time.substring(0,2) + ":" + this.config.arrival_time.substring(2,4);
    //change color if desired
    if (this.config.changeColor) {
      if (this.trafficComparison &gt;= 1 + (this.config.limitRed / 100)) {
        commuteInfo.className += ' red';
      } else if (this.trafficComparison &gt;= 1 + (this.config.limitYellow / 100)) {
        commuteInfo.className += ' yellow';
      } else if (this.config.showGreen) {
        commuteInfo.className += ' green';
    wrapper.appendChild(commuteInfo);
    wrapper.appendChild(routeName);
    return wrapper;
getParam_specific: function(origin, destination){
    var params = '?';
    params += 'mode=' + this.config.mode;
    params += '&amp;origin=' + origin;
    params += '&amp;destination=' + destination;
    params += '&amp;key=' + this.config.api_key;
    params += '&amp;traffic_model=' + this.config.traffic_model;
    params += '&amp;language=' + this.config.language;
    if (this.config.avoid.length &gt; 0) {
      params += '&amp;avoid=' + this.config.avoid;
    return params;
getParams: function() {
    var params = '?';
    params += '&amp;origin=' + this.config.origin;
    params += '&amp;destination=' + this.getTodaysDestination();
    return params;
getTodaysDestination: function() {
    var todays_destination = "";
    switch (new Date().getDay()) {
      case 1:
        todays_destination = this.config.mon_destination;
        break;
      case 2:
        todays_destination = this.config.tues_destination;
        break;
      case 3:
        todays_destination = this.config.wed_destination;
        break;
      case 4:
        todays_destination = this.config.thurs_destination;
        break;
      case 5:
        todays_destination = this.config.fri_destination;
        break;
      default:
        //to handle Sat and Sun (GoogleAPI may raise error if no destination set)
        todays_destination = this.config.destination;
    if(todays_destination === ""){ //if no weekday destinations defined in config.js, set to default
    return todays_destination;
    this.leaveBy = '';
    this.start_location = payload.start_location;
    this.end_location = payload.end_location;
    if (notification === 'TRAFFIC_COMMUTE' &amp;&amp; payload.url === this.url) {
        Log.info('received TRAFFIC_COMMUTE');
        this.commute = payload.commute;
        this.summary = payload.summary;
        this.trafficComparison = payload.trafficComparison;
        this.loaded = true;
        this.updateDom(1000);
    } else if (notification === 'TRAFFIC_TIMING' &amp;&amp; payload.url === this.url) {
        Log.info('received TRAFFIC_TIMING');
        this.leaveBy = payload.commute;
        this.commute = payload.commute; //support for hideOffHours
        this.loaded = true;
<p dir="auto">});</p>
]]></description><link>https://forum.magicmirror.builders/post/27137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27137</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Sun, 27 Aug 2017 17:07:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM &amp; Google Maps Traffic on Sun, 27 Aug 2017 16:03:31 GMT]]></title><description><![CDATA[<p dir="auto">Yes! I did it with the MMM-Traffic module. A bit of hacks and unclean code 😑 but yeah was able to get it working. Will try to share the same</p>
]]></description><link>https://forum.magicmirror.builders/post/27134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27134</guid><dc:creator><![CDATA[Mirrorolentia]]></dc:creator><pubDate>Sun, 27 Aug 2017 16:03:31 GMT</pubDate></item></channel></rss>
