<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with MMM-ResRobot, it wont start(?)]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/730/mmm-resrobot-public-transport-information-for-sweden">MMM-ResRobot - Public transport information for Sweden</a><br />
Are there any problems now with MMM-ResRobot, I cant it to work at all?<br />
I have reinstalled it 2 times and configure it but the module don’t start at all, no errors, nothing on the screen.</p>
<p dir="auto">BR<br />
Niklas</p>
]]></description><link>https://forum.magicmirror.builders/topic/4760/problem-with-mmm-resrobot-it-wont-start</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 12:33:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4760.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Sep 2017 08:04:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Sat, 20 Jan 2018 15:19:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ayeball" aria-label="Profile: ayeball">@<bdi>ayeball</bdi></a><br />
Bra att det funkar.<br />
Du ska bara behöva ändra i den config.js som ligger i MagicMirror-mappen, inte i de andra.</p>
<p dir="auto">För att ange flera rutter lägger du bara till en ny rad med:<br />
{from:“”, to:“”},</p>
<p dir="auto">På din config ser det ut som att fu använger en gammal version. Gör en git pull för att uppdatera. En av ändringarna är just formatet för att ange flera rutter. Se <a href="http://README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a> för dokumentation.</p>
]]></description><link>https://forum.magicmirror.builders/post/34324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34324</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Sat, 20 Jan 2018 15:19:20 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Sat, 20 Jan 2018 15:08:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alvinger" aria-label="Profile: Alvinger">@<bdi>Alvinger</bdi></a>  {</p>
<p dir="auto">Fick det att funka nu ! . Va tydligen 3 ställen jag fick ändra cfg till id för stationerna samt app id . i config.js / mmm-resrobot.js och mmm-resrobot som ligger i mmm-resrobot master mappen .</p>
<p dir="auto">Om jag vill ha en till tillagd som är det bara och upprepa följande kommando nedanför eller ? ;) Mvh</p>
<p dir="auto">from: “station id”,   // ResRobot Station ID (or a comma-separated string of IDs)<br />
to: “station id”, // ResRobot Station ID of destination (or a comma-separated string of IDs)</p>
<pre><code>    module: "MMM-ResRobot",
    position: "left",
    header: "Spårvagn från Ejdergatan",
        from: "740025622",   // ResRobot Station ID (or a comma-separated string of IDs)
        to: "740025673", // ResRobot Station ID of destination (or a comma-separated string of IDs)
        maximumEntries: 6,  // Number of departures to show on screen
        truncateAfter: 5,   // A value &gt; 0 will truncate direction name at first space after  characters. 0 = no truncation
        apiKey:"f1109bf4-187c-49e2-95ce-1ba1b6062388"  // Your ResRobot apiKey
]]></description><link>https://forum.magicmirror.builders/post/34322</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34322</guid><dc:creator><![CDATA[ayeball]]></dc:creator><pubDate>Sat, 20 Jan 2018 15:08:50 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Sat, 20 Jan 2018 13:46:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ayeball" aria-label="Profile: ayeball">@<bdi>ayeball</bdi></a><br />
Please post the appropriate part of config.js</p>
Klipp in den relevanta delen av config.js så kan vi kolla på den.
]]></description><link>https://forum.magicmirror.builders/post/34315</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34315</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Sat, 20 Jan 2018 13:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Sat, 20 Jan 2018 12:58:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alvinger" aria-label="Profile: Alvinger">@<bdi>Alvinger</bdi></a></p>
<p dir="auto">Re: [Problem with MMM-ResRobot]</p>
<p dir="auto">I have also problem with MMM-Resrobot . I use API-Key ResRobot - Stolptidtabeller 2. !<br />
I got it to work now but i get stockholm stations … And i have use “ejdergatan"740025622” to redbergsplatsen" 740025673" Göteborg .</p>
<p dir="auto">any idea?  Kan svara på svenska också ;) Mvh</p>
]]></description><link>https://forum.magicmirror.builders/post/34314</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34314</guid><dc:creator><![CDATA[ayeball]]></dc:creator><pubDate>Sat, 20 Jan 2018 12:58:10 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Fri, 19 Jan 2018 18:20:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gailby" aria-label="Profile: Gailby">@<bdi>Gailby</bdi></a><br />
Great to hear! (Jag dokumenterade på engelska så alla kunde förstå men då blir ju svenskar lite förvirrade! :-)<br />
Maybe I should add the swedish name of the API key to the documentation as well.</p>
]]></description><link>https://forum.magicmirror.builders/post/34279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34279</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Fri, 19 Jan 2018 18:20:58 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Fri, 19 Jan 2018 17:34:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alvinger" aria-label="Profile: Alvinger">@<bdi>Alvinger</bdi></a> Thanx a lot, that did it! I got confused about the english translation of “ResRobot - Pole Schedules 2” and used  ResRobot - Reseplanerare. My Bad :/</p>
]]></description><link>https://forum.magicmirror.builders/post/34277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34277</guid><dc:creator><![CDATA[Gailby]]></dc:creator><pubDate>Fri, 19 Jan 2018 17:34:19 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Thu, 18 Jan 2018 16:12:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gailby" aria-label="Profile: Gailby">@<bdi>Gailby</bdi></a> I copied your first config but used my API key and it worked with no issues at all.<br />
Verify that you are using the correct API key.<br />
The 400 status code is usually because you are using the wrong key.</p>
]]></description><link>https://forum.magicmirror.builders/post/34198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34198</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Thu, 18 Jan 2018 16:12:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Thu, 18 Jan 2018 14:55:06 GMT]]></title><description><![CDATA[<p dir="auto">Ok, seems it didn’t want to handle several departures like previous post but only one:</p>
<pre><code>            {
                    header: "Departures",
                            routes: [
                                    {from: "740000765", to: "740000284"}    // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
                                    skipMinutes: 0,         // Skip departures that happens within the next  minutes.
                                    apiKey: "1c01e8b8-92d0-4e05-86dc-a112d743ba5a"  // Your ResRobot apiKey
<p dir="auto">Still get error response:<br />
node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“<a href="https://api.resrobot.se/v2/departureBoard?format=json&amp;passlist=0%22,%22apiKey%22:%221c01e8b8-92d0-4e05-86dc-a112d743ba5a%22,%22routes%22:%5B%7B%22from%22:%22740000765%22,%22to%22:%22740000284%22%7D%5D,%22skipMinutes%22:0,%22maximumEntries%22:6,%22truncateAfter%22:5,%22iconTable%22:%7B%22B%22:%22fa" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.resrobot.se/v2/departureBoard?format=json&amp;passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740000765”,“to”:“740000284”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa</a> fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}<br />
Fetching new departure data for module: MMM-ResRobot</p>
<p dir="auto">node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“<a href="https://api.resrobot.se/v2/departureBoard?format=json&amp;passlist=0%22,%22apiKey%22:%221c01e8b8-92d0-4e05-86dc-a112d743ba5a%22,%22routes%22:%5B%7B%22from%22:%22740021656%22,%22to%22:%22740020749%22%7D%5D,%22skipMinutes%22:0,%22maximumEntries%22:6,%22truncateAfter%22:5,%22iconTable%22:%7B%22B%22:%22fa" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.resrobot.se/v2/departureBoard?format=json&amp;passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740021656”,“to”:“740020749”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa</a> fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}<br />
MMM-ResRobot : Error: got 400 response</p>
]]></description><link>https://forum.magicmirror.builders/post/34196</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34196</guid><dc:creator><![CDATA[Gailby]]></dc:creator><pubDate>Thu, 18 Jan 2018 14:55:06 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Thu, 18 Jan 2018 14:39:05 GMT]]></title><description><![CDATA[<p dir="auto">I can not get it working either, says fetching for quite some time now. I get a “MMM-ResRobot : Error: got 400 response” on starting server… strange. Anyone recognize the same output?</p>
<pre><code>            {
                            routes: [
                                    {from: "740021656", to: "740020749"},   // ResRobot Station IDs of starting and destination station(s). At least one route must be defined.
                                    {from: "740000765", to: "740000284"},   // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
]]></description><link>https://forum.magicmirror.builders/post/34195</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34195</guid><dc:creator><![CDATA[Gailby]]></dc:creator><pubDate>Thu, 18 Jan 2018 14:39:05 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Wed, 13 Dec 2017 08:46:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajomannen" aria-label="Profile: ajomannen">@<bdi>ajomannen</bdi></a> sorry, the curly braces got lost in my copying. I have updated my previous post.</p>
]]></description><link>https://forum.magicmirror.builders/post/32241</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32241</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Wed, 13 Dec 2017 08:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Wed, 13 Dec 2017 08:38:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajomannen" aria-label="Profile: ajomannen">@<bdi>ajomannen</bdi></a></p>
<p dir="auto">I got it to work by adding an extra level of curly brackets and a comma after the closing square bracket:</p>
<pre><code>{
		routes: [
		skipMinutes: 0,
		maximumEntries: 6,
		truncateAfter: 5,
		apiKey: "xxxx"
<p dir="auto">Is the example config on <a href="https://github.com/Alvinger/MMM-ResRobot" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Alvinger/MMM-ResRobot</a> incorrect?</p>
]]></description><link>https://forum.magicmirror.builders/post/32239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32239</guid><dc:creator><![CDATA[ajomannen]]></dc:creator><pubDate>Wed, 13 Dec 2017 08:38:30 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Wed, 13 Dec 2017 08:23:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alvinger" aria-label="Profile: Alvinger">@<bdi>Alvinger</bdi></a></p>
<p dir="auto">Hi there,</p>
<p dir="auto">I fail to get the new config format to work.</p>
<p dir="auto">I use the following block:</p>
<pre><code>{
		routes: [
		skipMinutes: 0,
		maximumEntries: 6,
		truncateAfter: 5,
		apiKey: "xxxxx"
<p dir="auto">but MagicMirror2 fails to start with following message:</p>
<p dir="auto">WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.</p>
<p dir="auto">(If I use the old config syntax for routes, the system starts up as before, but I get departures from some default location that seems like Stockholm C.)</p>
<p dir="auto">What could I have done wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/32238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32238</guid><dc:creator><![CDATA[ajomannen]]></dc:creator><pubDate>Wed, 13 Dec 2017 08:23:51 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Wed, 13 Dec 2017 08:45:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eburkis" aria-label="Profile: Eburkis">@<bdi>Eburkis</bdi></a> et al<br />
I’ve just pushed a long-overdue update to MMM-ResRobot to github.</p>
<p dir="auto">This new version has a completely reworked updating logic which should result in less “frozen” updates and also less API calls to Trafiklab/ResRobot over time.</p>
<p dir="auto">Note that there is a breaking change to the configuration as I’ve changed the way routes are defined.<br />
Previous configuration:</p>
<pre><code>from: "from1,from2,from3",
to: "to1,,to3"
<p dir="auto">New configuration:</p>
<pre><code>routes: [
  {from: "from1", to: "to1"},
  {from: "from2", to: ""},
  {from: "from3", to: "to3"},
<p dir="auto">Sorry for not pushing the update sooner but my mirror project has been delayed due to other things. Will try to update more frequently in the future. Please drop me a note if you encounter issues!</p>
]]></description><link>https://forum.magicmirror.builders/post/32200</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32200</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Wed, 13 Dec 2017 08:45:18 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 21:00:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eburkis" aria-label="Profile: Eburkis">@<bdi>Eburkis</bdi></a> said in <a href="/post/27682">Problem with MMM-ResRobot, it wont start(?)</a>:</p>
<p dir="auto">yeey somthing works now<br />
now when the MM boots it says Fetching data for almost 3 sec then it goes black and now its just “departures” and under that its empty. so its almost that it is no departures at all</p>
]]></description><link>https://forum.magicmirror.builders/post/27694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27694</guid><dc:creator><![CDATA[Eburkis]]></dc:creator><pubDate>Tue, 05 Sep 2017 21:00:40 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 20:32:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eburkis" aria-label="Profile: Eburkis">@<bdi>Eburkis</bdi></a> I sent you my config via PM. If you use that with your AKIKey it should work. Otherwise there must be a error with your key.</p>
<p dir="auto">Hm…could it be something with your router, could it block sites? I had a similar problems once and I had a familly filter active on my router.</p>
]]></description><link>https://forum.magicmirror.builders/post/27693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27693</guid><dc:creator><![CDATA[Nybbe67]]></dc:creator><pubDate>Tue, 05 Sep 2017 20:32:08 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 19:45:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/atd08001" aria-label="Profile: atd08001">@<bdi>atd08001</bdi></a><br />
now i want to completly give up… now with the new site id its still does not work. now it’s just black with no info at all.<br />
what should i do ?</p>
<pre><code>{
		position: "left",
			from: "740024784",		// ResRobot Station ID (or a comma-separated string of IDs)
			to: "740046172",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
			apiKey: "key here"		// Your ResRobot apiKey
]]></description><link>https://forum.magicmirror.builders/post/27692</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27692</guid><dc:creator><![CDATA[Eburkis]]></dc:creator><pubDate>Tue, 05 Sep 2017 19:45:56 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 18:57:26 GMT]]></title><description><![CDATA[<p dir="auto">i will try. tnx for the help, have a nice evening</p>
]]></description><link>https://forum.magicmirror.builders/post/27691</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27691</guid><dc:creator><![CDATA[Eburkis]]></dc:creator><pubDate>Tue, 05 Sep 2017 18:57:26 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 18:55:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eburkis" aria-label="Profile: Eburkis">@<bdi>Eburkis</bdi></a><br />
You should use “ResRobot - Reseplanerare" and create a API for that service instead of “platsuppslag”.<br />
i get ID: 740024784  and name “Lidingö Rudboda torg” when i search for Rudboda torg</p>
Andreas</p>
]]></description><link>https://forum.magicmirror.builders/post/27690</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27690</guid><dc:creator><![CDATA[atd08001]]></dc:creator><pubDate>Tue, 05 Sep 2017 18:55:24 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 18:49:36 GMT]]></title><description><![CDATA[<p dir="auto">if i use the api for “platsuppslag” then i get the answer that 2023 is Rudboda torg and when i look for gubbängen Tbana is 7956 so I wonder where you get your number from.</p>
<p dir="auto">and i get access denied with your link so that dont work for me sry</p>
]]></description><link>https://forum.magicmirror.builders/post/27689</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27689</guid><dc:creator><![CDATA[Eburkis]]></dc:creator><pubDate>Tue, 05 Sep 2017 18:49:36 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 17:53:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eburkis" aria-label="Profile: Eburkis">@<bdi>Eburkis</bdi></a> Hi,</p>
<p dir="auto">It looks like the Station ID is wrong. My “From station ID” for “Gubbängen” is 740021699.</p>
<p dir="auto">You can create a API for “ResRobot - Reseplanerare” and then type in this URL in the browser: <a href="https://api.resrobot.se/v2/location.name?key=**YOURE" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.resrobot.se/v2/location.name?key=**YOURE</a> API KEY**&amp;input=<strong>SEARCH WORD</strong></p>
<p dir="auto">Replace the bold parts, whit API-key and search word for exampel T-centralen<br />
You will get a XML response with all the possible results and the differnet ID (Stations ID)</p>
<p dir="auto">And then make sure you use the service “ResRobot - Stolptidtabeller 2” in the config.</p>
<p dir="auto">Good luck<br />
Andreas</p>
]]></description><link>https://forum.magicmirror.builders/post/27684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27684</guid><dc:creator><![CDATA[atd08001]]></dc:creator><pubDate>Tue, 05 Sep 2017 17:53:03 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 15:08:24 GMT]]></title><description><![CDATA[<p dir="auto">hmm i have not make the same typo as you did but something i still not working for me.</p>
<pre><code>	{
		position: "left",
		header: "Avgångar",
			from: "2023",		// ResRobot Station ID (or a comma-separated string of IDs)
			to: "1138",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
			truncateAfter: 2,	// A value &gt; 0 will truncate direction name at first space after  characters. 0 = no truncation
			apikey: "KEY HERE "		// Your ResRobot apiKey
]]></description><link>https://forum.magicmirror.builders/post/27682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27682</guid><dc:creator><![CDATA[Eburkis]]></dc:creator><pubDate>Tue, 05 Sep 2017 15:08:24 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 14:35:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eburkis" aria-label="Profile: Eburkis">@<bdi>Eburkis</bdi></a> copy <a class="plugin-mentions-user plugin-mentions-a" href="/user/atd08001" aria-label="Profile: atd08001">@<bdi>atd08001</bdi></a>’s config (above here) and replace your own, but use your own API key. Then it should work. My mistake was a typo, MMM_ResRobot, not MMM-ResRobot.</p>
]]></description><link>https://forum.magicmirror.builders/post/27680</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27680</guid><dc:creator><![CDATA[Nybbe67]]></dc:creator><pubDate>Tue, 05 Sep 2017 14:35:31 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 10:49:49 GMT]]></title><description><![CDATA[<p dir="auto">i cant get mine to work :/</p>
]]></description><link>https://forum.magicmirror.builders/post/27674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27674</guid><dc:creator><![CDATA[Eburkis]]></dc:creator><pubDate>Tue, 05 Sep 2017 10:49:49 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MMM-ResRobot, it wont start(?) on Tue, 05 Sep 2017 10:48:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eburkis" aria-label="Profile: Eburkis">@<bdi>Eburkis</bdi></a><br />
Yes, its working, thanks</p>
<p dir="auto">Best regards<br />
Niklas</p>
]]></description><link>https://forum.magicmirror.builders/post/27673</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27673</guid><dc:creator><![CDATA[Nybbe67]]></dc:creator><pubDate>Tue, 05 Sep 2017 10:48:08 GMT</pubDate></item></channel></rss>
