<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compliments color]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a></p>
<p dir="auto">Hello, after updating MM, your color changes for compliments wont work? set up exactly as before but for some reason it stays white?</p>
<p dir="auto">.compliments .morning {<br />
color: #f83e07;<br />
}<br />
.compliments .afternoon {<br />
color: #5607ff;<br />
}<br />
.compliments .evening {<br />
color: #5408cc;<br />
}</p>
<p dir="auto">is this due to the update, or is something new to be done?</p>
<p dir="auto">Thank you</p>
]]></description><link>https://forum.magicmirror.builders/topic/4827/compliments-color</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 01:46:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4827.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Sep 2017 00:24:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compliments color on Mon, 11 Sep 2017 02:51:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/damian" aria-label="Profile: Damian">@<bdi>Damian</bdi></a> it’s always on github! :)</p>
]]></description><link>https://forum.magicmirror.builders/post/27943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27943</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 11 Sep 2017 02:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to Compliments color on Mon, 11 Sep 2017 02:20:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a><br />
Thank you, yes when I did the update it did throw the usual warn about compliments and clock that I changed, and I just ended up doing the “remove” option, because I was in a rush, thinking I could just simply C&amp;P the small changes over, but not quite that simple :-(  so will keep your .js file somewhere safe.</p>
]]></description><link>https://forum.magicmirror.builders/post/27936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27936</guid><dc:creator><![CDATA[Damian]]></dc:creator><pubDate>Mon, 11 Sep 2017 02:20:47 GMT</pubDate></item><item><title><![CDATA[Reply to Compliments color on Mon, 11 Sep 2017 02:10:09 GMT]]></title><description><![CDATA[<p dir="auto">If you do an update to MM you’ll have to recopy the compliments.js file from here to your compliments module folder…</p>
<p dir="auto">Unless you do a git stash</p>
<p dir="auto">I realize some people like the ability to use color… I do like the white myself but some don’t.</p>
<p dir="auto">I did a pull request for this eons ago but it was ignored…</p>
]]></description><link>https://forum.magicmirror.builders/post/27935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27935</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 11 Sep 2017 02:10:09 GMT</pubDate></item><item><title><![CDATA[Reply to Compliments color on Mon, 11 Sep 2017 00:56:56 GMT]]></title><description><![CDATA[<p dir="auto">Check here to see if you’ve overwritten the changes…</p>
<p dir="auto"><a href="https://github.com/cowboysdude/compliments/blob/master/compliments.js" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/cowboysdude/compliments/blob/master/compliments.js</a></p>
]]></description><link>https://forum.magicmirror.builders/post/27932</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27932</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 11 Sep 2017 00:56:56 GMT</pubDate></item></channel></rss>
