<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What VLT work best for this?]]></title><description><![CDATA[<p dir="auto">What visible light transmittance (VLT) work best for the magic mirror? Witch one did you use on yours?</p>
]]></description><link>https://forum.magicmirror.builders/topic/4865/what-vlt-work-best-for-this</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 23:05:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4865.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Sep 2017 19:00:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What VLT work best for this? on Mon, 18 Sep 2017 20:40:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j.e.f.f" aria-label="Profile: j.e.f.f">@<bdi>j.e.f.f</bdi></a> Thank you, info was very helpful</p>
]]></description><link>https://forum.magicmirror.builders/post/28226</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28226</guid><dc:creator><![CDATA[alfonsopagan]]></dc:creator><pubDate>Mon, 18 Sep 2017 20:40:06 GMT</pubDate></item><item><title><![CDATA[Reply to What VLT work best for this? on Sun, 17 Sep 2017 22:18:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alfonsopagan" aria-label="Profile: alfonsopagan">@<bdi>alfonsopagan</bdi></a> it depends on a few factors… if your room is very bright, then you might want something with about 50% transparency.  If the mirror won’t get any direct sunlight, then 15-20% should work fine.</p>
<p dir="auto">However this also depends on the brightness of the screen you use.  If you’re using an old or inexpensive monitor that isn’t particularly bright, then you might want to opt for a higher light transmittance.</p>
<p dir="auto">you want to find a balance where the details on the screen will be plainly visible on your mirror, without the outline of the screen being apparent (e.g. the “brightness” of the monitor’s black level).  If you have the option to do so, order a few samples of various light transmittance to find the one that works well for your particular situation.</p>
<p dir="auto">In my case, I’m using a recent TV screen in a position that doesn’t get direct sunlight.  So 20% worked for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/28207</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28207</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Sun, 17 Sep 2017 22:18:32 GMT</pubDate></item></channel></rss>
