<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Remote-Control - Disable auto monitor off]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">Whenever I activate the wonderful MMM-Remote-Control and either start or refresh my mirror, I have to manually use the remote-control to turn on my monitor again.</p>
<p dir="auto">Is there any way to disable this auto turn off HDMI feature?</p>
<p dir="auto">Cheers from Denmark!</p>
]]></description><link>https://forum.magicmirror.builders/topic/4867/mmm-remote-control-disable-auto-monitor-off</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 01:12:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4867.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Sep 2017 19:35:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Remote-Control - Disable auto monitor off on Sat, 16 Sep 2017 20:30:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skanderup" aria-label="Profile: Skanderup">@<bdi>Skanderup</bdi></a> It looks so weird. I cannot find any suspicious thing on git codes. There seems no point to control hdmi except <code>tvservice</code> but I’ve never heard that could make this kind of issue.<br />
Hmmmm. Maybe I can install this module by myself and examine. But today is an holiday so I can try next Monday. I wish you could find solution before then. Good luck!<br />
(You’d better ask the module developer on github directly.)</p>
]]></description><link>https://forum.magicmirror.builders/post/28162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28162</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 16 Sep 2017 20:30:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control - Disable auto monitor off on Sat, 16 Sep 2017 20:15:01 GMT]]></title><description><![CDATA[<p dir="auto">@Sean</p>
<p dir="auto">Thank you for helping Sean.</p>
<p dir="auto">The problem is that when the remote-control module is loaded by MagicMirror somewhere in the code it says disable HDMI. So whenever my screen powers up and loads the magicmirror everything works fine until the remote-control module is loaded, then my monitor goes from showing the magicmirror to “searching for input source”.</p>
<p dir="auto">What I want the remote module to do is just be enabled in the background without disabling the rpi HDMI automatically from the beginning.</p>
<p dir="auto">Makes sense? :)</p>
]]></description><link>https://forum.magicmirror.builders/post/28161</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28161</guid><dc:creator><![CDATA[Skanderup]]></dc:creator><pubDate>Sat, 16 Sep 2017 20:15:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control - Disable auto monitor off on Sat, 16 Sep 2017 20:08:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skanderup" aria-label="Profile: Skanderup">@<bdi>Skanderup</bdi></a> I’m not using this module, so I read code now. It seems using tvservice. So what is your problem? Whenever you include this module, the monitor is powered off from beginning so you should turn it on by yourself with this module?<br />
Or whenever you use this module, the screen power-save mode is on automatically not as your intend? More detailed info is needed.<br />
So, describe <em>what you might expect</em> and <em>what you get really</em>, <em>which condition you had</em> please.</p>
]]></description><link>https://forum.magicmirror.builders/post/28160</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28160</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 16 Sep 2017 20:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control - Disable auto monitor off on Sat, 16 Sep 2017 19:57:49 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
Hi Sean</p>
<p dir="auto">It’s the Remote-Control module that automatically disables the HDMI. If I don’t enable the remote-control module in my config.js, the screen stays on as it should.</p>
]]></description><link>https://forum.magicmirror.builders/post/28159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28159</guid><dc:creator><![CDATA[Skanderup]]></dc:creator><pubDate>Sat, 16 Sep 2017 19:57:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Remote-Control - Disable auto monitor off on Sat, 16 Sep 2017 19:55:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/skanderup" aria-label="Profile: Skanderup">@<bdi>Skanderup</bdi></a> are you using raspbian desktop? Check <code>xset dpms</code> setting. I think <code>xset dpms off</code> And  <code>xset dpms 0 0 0</code> Will work.</p>
]]></description><link>https://forum.magicmirror.builders/post/28158</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28158</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sat, 16 Sep 2017 19:55:44 GMT</pubDate></item></channel></rss>
