<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Exchange SD-card RPi with Zero W]]></title><description><![CDATA[<p dir="auto">MM installed on Raspberry Pi 3 works fine but when I take out the SD card and put it in a Raspberry Pi Zero W the MM will not start and reports there is something wrong within the config file. Is this a well known issue?</p>
]]></description><link>https://forum.magicmirror.builders/topic/4999/exchange-sd-card-rpi-with-zero-w</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 23:39:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/4999.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 28 Sep 2017 07:26:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Exchange SD-card RPi with Zero W on Thu, 28 Sep 2017 15:27:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ultimatum22" aria-label="Profile: Ultimatum22">@<bdi>Ultimatum22</bdi></a> Thanks, just gave up and use my RPi 3 ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/28631</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28631</guid><dc:creator><![CDATA[MM-Hans]]></dc:creator><pubDate>Thu, 28 Sep 2017 15:27:41 GMT</pubDate></item><item><title><![CDATA[Reply to Exchange SD-card RPi with Zero W on Thu, 28 Sep 2017 15:02:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mm-hans" aria-label="Profile: MM-Hans">@<bdi>MM-Hans</bdi></a> That is true, Mykle1 already said that. My post was after you swapped the SD card with an existing installation of MM on it.</p>
]]></description><link>https://forum.magicmirror.builders/post/28630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28630</guid><dc:creator><![CDATA[Ultimatum22]]></dc:creator><pubDate>Thu, 28 Sep 2017 15:02:13 GMT</pubDate></item><item><title><![CDATA[Reply to Exchange SD-card RPi with Zero W on Thu, 28 Sep 2017 14:37:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ultimatum22" aria-label="Profile: Ultimatum22">@<bdi>Ultimatum22</bdi></a> Thanks but it looks Zero is not supported. When I try to install directly on it the MM2 auto installation reports:</p>
<p dir="auto">“Sorry, your Raspberry Pi is not supported. Please run MagicMirror on a Raspberry Pi 2 or 3. If this is a Pi Zero, you are in the same boat as the original Raspberry Pi. You must run in server only mode.”</p>
]]></description><link>https://forum.magicmirror.builders/post/28629</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28629</guid><dc:creator><![CDATA[MM-Hans]]></dc:creator><pubDate>Thu, 28 Sep 2017 14:37:51 GMT</pubDate></item><item><title><![CDATA[Reply to Exchange SD-card RPi with Zero W on Thu, 28 Sep 2017 13:49:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mm-hans" aria-label="Profile: MM-Hans">@<bdi>MM-Hans</bdi></a> Check if this works, haven’t tried it myself but problems looks the same.</p>
<p dir="auto"><a href="https://blog.miniarray.com/installing-node-js-on-a-raspberry-pi-zero-21a1522db2bb" target="_blank" rel="noopener noreferrer nofollow ugc">https://blog.miniarray.com/installing-node-js-on-a-raspberry-pi-zero-21a1522db2bb</a></p>
]]></description><link>https://forum.magicmirror.builders/post/28627</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28627</guid><dc:creator><![CDATA[Ultimatum22]]></dc:creator><pubDate>Thu, 28 Sep 2017 13:49:21 GMT</pubDate></item><item><title><![CDATA[Reply to Exchange SD-card RPi with Zero W on Thu, 28 Sep 2017 11:50:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
It is not my intention to re-install on Zero but use my RPi3 installation via card swap. Reading your answer I understand this is not possible. When I enter “~/MagicMirror $ npm start” there is a segmentaion fault message shown.</p>
]]></description><link>https://forum.magicmirror.builders/post/28626</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28626</guid><dc:creator><![CDATA[MM-Hans]]></dc:creator><pubDate>Thu, 28 Sep 2017 11:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to Exchange SD-card RPi with Zero W on Thu, 28 Sep 2017 11:33:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mm-hans" aria-label="Profile: MM-Hans">@<bdi>MM-Hans</bdi></a></p>
<p dir="auto">If you do a simple search for <strong>Pi Zero</strong> using the magnifying glass icon at the top right of this window, you’ll find plenty of info on installing MM on that version of Pi.</p>
<p dir="auto">With that said, I’m pretty sure you can’t swap the SD card from a Pi3 installation into the Pi Zero.</p>
]]></description><link>https://forum.magicmirror.builders/post/28625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28625</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 28 Sep 2017 11:33:02 GMT</pubDate></item></channel></rss>
