<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[GETTING STARTED : HELP !!]]></title><description><![CDATA[<p dir="auto">Hi everyone ive recently come across this site. I have ran the main installation to my pi via ssh i have manually gone onto the pi file manager and into the directory or MagicMirror and tried running index.html</p>
<p dir="auto">BUT</p>
<p dir="auto">I have a message come up saying about the config file?? I am currectly stuck and unsure on what to do.</p>
<p dir="auto">I would appreciate any help please.</p>
]]></description><link>https://forum.magicmirror.builders/topic/5021/getting-started-help</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 09:17:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5021.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Oct 2017 17:19:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Tue, 03 Oct 2017 19:48:45 GMT]]></title><description><![CDATA[<p dir="auto">@PCPAYN3 said in <a href="/post/28950">GETTING STARTED : HELP !!</a>:</p>
<p dir="auto">Is there a html file to edit so i can add a google calender to it?</p>
<p dir="auto">In your config.js file, in the calendar module entry, you can either add this OR edit the existing entry for US-Holidays. If you do not want the US Holidays calendar then simply change the end of the url to UK-Holidays.ics.</p>
<pre><code>{
symbol: "calendar-check-o ",
url: "webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics"
},</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/28959</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28959</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 03 Oct 2017 19:48:45 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Tue, 03 Oct 2017 17:49:07 GMT]]></title><description><![CDATA[<p dir="auto">@PCPAYN3 Instructions for setting up autostart here: <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/28952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28952</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Tue, 03 Oct 2017 17:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Tue, 03 Oct 2017 17:30:16 GMT]]></title><description><![CDATA[<p dir="auto">After reinstalling i now have it working thankyou. I just have a few more questions:<br />
How do i edit it to show UK holidays etc?<br />
Is there a html file to edit so i can add a google calender to it? And how to i get it to autoload on boot?</p>
]]></description><link>https://forum.magicmirror.builders/post/28950</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28950</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 03 Oct 2017 17:30:16 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Tue, 03 Oct 2017 16:47:14 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1507049200250-sgrab.png" alt="0_1507049198415_sgrab.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I have tried reinstalling &amp; I am now getting this from the terminal</p>
]]></description><link>https://forum.magicmirror.builders/post/28946</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28946</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 03 Oct 2017 16:47:14 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Tue, 03 Oct 2017 15:21:22 GMT]]></title><description><![CDATA[<p dir="auto">Terminal:<br />
pi@raspberrypi:~ $ npm start<br />
npm ERR! Linux 4.9.35-v7+<br />
npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”<br />
npm ERR! node v6.11.3<br />
npm ERR! npm  v3.10.10<br />
npm ERR! path /home/pi/package.json<br />
npm ERR! code ENOENT<br />
npm ERR! errno -2<br />
npm ERR! syscall open</p>
<p dir="auto">npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’<br />
npm ERR! enoent This is most likely not a problem with npm itself<br />
npm ERR! enoent and is related to npm not being able to find a file.<br />
npm ERR! enoent</p>
<p dir="auto">npm ERR! Please include the following file with any support request:<br />
npm ERR!     /home/pi/npm-debug.log</p>
<p dir="auto">Config File:<br />
/* Magic Mirror Config<br />
*</p>
<ul>
<li>By Michael Teeuw <a href="http://michaelteeuw.nl" target="_blank" rel="noopener noreferrer nofollow ugc">http://michaelteeuw.nl</a></li>
<li>MIT Licensed.</li>
<li></li>
<li>For more information how you can configurate this file</li>
<li>See <a href="https://github.com/MichMich/MagicMirror#configuration" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror#configuration</a></li>
<li></li>
</ul>
<p dir="auto">*/</p>
<p dir="auto">var config = {<br />
address: “localhost”, // Address to listen on, can be:<br />
// - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface<br />
// - another specific IPv4/6 to listen on a specific interface<br />
// - “”, “0.0.0.0”, “::” to listen on any interface<br />
// Default, when address config is left out, is “localhost”<br />
port: 8080,<br />
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses<br />
// or add a specific IPv4 of 192.168.1.4 :<br />
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],<br />
// or IPv4 range of 192.168.3.0 --&gt; 192.168.3.15 use CIDR format :<br />
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],</p>
<pre><code>language: "en",
timeFormat: 12,
units: "metric",
		module: "alert",
		module: "updatenotification",
		position: "top_bar"
		module: "clock",
		position: "top_left"
		header: "US Holidays",
					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
		module: "compliments",
		position: "lower_third"
		module: "currentweather",
			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
			appid: "YOUR_OPENWEATHER_API_KEY"
		module: "weatherforecast",
		header: "Weather Forecast",
			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
		module: "newsfeed",
		position: "bottom_bar",
			feeds: [
					title: "New York Times",
			showSourceTitle: true,
			showPublishDate: true
<p dir="auto">};</p>
<p dir="auto">/*************** DO NOT EDIT THE LINE BELOW ***************/<br />
if (typeof module !== “undefined”) {module.exports = config;}</p>
]]></description><link>https://forum.magicmirror.builders/post/28936</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28936</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 03 Oct 2017 15:21:22 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Mon, 02 Oct 2017 12:31:49 GMT]]></title><description><![CDATA[<p dir="auto">@PCPAYN3</p>
<p dir="auto">@PCPAYN3 said in <a href="/post/28848">GETTING STARTED : HELP !!</a>:</p>
<p dir="auto">is there a command i should be running when the pi boots? As i have been going into the folder and loading the index.html file from there.</p>
<p dir="auto">I’m not really sure what you’re asking. The index.html file isn’t going to launch the mirror. Open a terminal, cd into the MagicMirror directory and run npm start. If you get the config error, we’ll take it from there once you post your terminal and config here</p>
]]></description><link>https://forum.magicmirror.builders/post/28850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28850</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 02 Oct 2017 12:31:49 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Mon, 02 Oct 2017 12:02:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> is there a command i should be running when the pi boots? As i have been going into the folder and loading the index.html file from there.</p>
]]></description><link>https://forum.magicmirror.builders/post/28848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28848</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 02 Oct 2017 12:02:45 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Mon, 02 Oct 2017 12:00:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> hi yes it is in that folder as shown on my screen grab from winscp i will copy the code from the file tonight and paste it on here for you to see.</p>
]]></description><link>https://forum.magicmirror.builders/post/28847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28847</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 02 Oct 2017 12:00:18 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Mon, 02 Oct 2017 11:57:56 GMT]]></title><description><![CDATA[<p dir="auto">@PCPAYN3</p>
<p dir="auto">Check that the config.js file is inside the MagicMirror/config/ folder. Unless you made changes to the sample file itself before copying and renaming, that should work.</p>
<p dir="auto">Your terminal, where you run your commands to launch the mirror. You would copy and paste the information in that window here. It’s probably a good idea for you to copy and paste your config.js file here as well.</p>
<p dir="auto">Please select the code block option when pasting <code>&lt;/&gt;</code></p>
]]></description><link>https://forum.magicmirror.builders/post/28846</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28846</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 02 Oct 2017 11:57:56 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Mon, 02 Oct 2017 09:45:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> yes thats correct. What do you mean by post terminal output? Sorry im a newbie at this.</p>
]]></description><link>https://forum.magicmirror.builders/post/28843</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28843</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 02 Oct 2017 09:45:51 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Mon, 02 Oct 2017 01:45:06 GMT]]></title><description><![CDATA[<p dir="auto">@PCPAYN3</p>
<p dir="auto">So, you made a <strong>copy</strong> of the config.js.sample file and renamed it to config.js, and then you run the mirror and it says your config is missing or has errors?</p>
<p dir="auto">Can you post your terminal output here?</p>
]]></description><link>https://forum.magicmirror.builders/post/28837</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28837</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 02 Oct 2017 01:45:06 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Sun, 01 Oct 2017 17:58:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a> I have tried renaming the file that is in that folder to just say config.js and restarted the pi but still getting the same issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/28780</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28780</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 01 Oct 2017 17:58:28 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Sun, 01 Oct 2017 17:49:30 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1506880117180-sshot.png" alt="0_1506880118230_sshot.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is a screen shot of the directory from github (left) and then what files are on the pi (right) is this correct?</p>
]]></description><link>https://forum.magicmirror.builders/post/28778</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28778</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 01 Oct 2017 17:49:30 GMT</pubDate></item><item><title><![CDATA[Reply to GETTING STARTED : HELP !! on Sun, 01 Oct 2017 17:29:57 GMT]]></title><description><![CDATA[<p dir="auto">Did you copy the <code>config.js.sample</code> file in the <code>/config</code> folder to <code>config.js</code>, as described in the <a href="https://github.com/MichMich/MagicMirror#configuration" target="_blank" rel="noopener noreferrer nofollow ugc">documentation</a>?</p>
]]></description><link>https://forum.magicmirror.builders/post/28774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28774</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Sun, 01 Oct 2017 17:29:57 GMT</pubDate></item></channel></rss>
