<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t access magic mirror via http ?]]></title><description><![CDATA[<p dir="auto">Hey experts<br />
I was able to perform http request on my magic mirror but after some time it stopped working .i can’t access the remote from my mobile . Any idea how can I access from my extremal devices?</p>
<p dir="auto">Regards Saif</p>
]]></description><link>https://forum.magicmirror.builders/topic/5025/can-t-access-magic-mirror-via-http</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 22:52:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5025.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Oct 2017 10:18:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Thu, 04 Jan 2018 23:34:16 GMT]]></title><description><![CDATA[<p dir="auto">So I have the same issues. I was wondering if there has been any developments on this subject over the past few months. Have any workarounds been discovered so I can finally remote access my Magic Mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/33366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33366</guid><dc:creator><![CDATA[chaseb1357]]></dc:creator><pubDate>Thu, 04 Jan 2018 23:34:16 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Fri, 06 Oct 2017 07:35:33 GMT]]></title><description><![CDATA[<p dir="auto"><strong>TLDR</strong>: You need to enable listening to all addresses (see the <a href="https://github.com/Jopyth/MMM-Remote-Control/issues/55#issuecomment-334476707" target="_blank" rel="noopener noreferrer nofollow ugc">comment on the Github issue</a>) in addition to the usual adaptation of the <code>ipWhitelist</code>. Add this line to your <code>config.js</code>:</p>
<pre><code>address: "0.0.0.0",
<p dir="auto"><a href="/topic/5015">Related topic</a>.</p>
<hr />
<p dir="auto">Since MagicMirror 2.1.3, the webserver only listens to the loopback interface be default. This removes any possible attack on the webserver for most users (not that their are any known attacks right now, but in times of <a href="https://en.wikipedia.org/wiki/Mirai_(malware)" target="_blank" rel="noopener noreferrer nofollow ugc">mirai</a> it is a good thing!), but unfortunately also effectively stops accessing the MagicMirror through HTTP and how the remote module currently works. If any developer has a good idea how to combine the best of both worlds, please let me know.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saifkazi" aria-label="Profile: saifkazi">@<bdi>saifkazi</bdi></a> I suggest you update again and try it out.</p>
]]></description><link>https://forum.magicmirror.builders/post/29072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29072</guid><dc:creator><![CDATA[Jopyth]]></dc:creator><pubDate>Fri, 06 Oct 2017 07:35:33 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Mon, 02 Oct 2017 16:54:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saifkazi" aria-label="Profile: saifkazi">@<bdi>saifkazi</bdi></a> said in <a href="/post/28872">Can’t access magic mirror via http ?</a>:</p>
<p dir="auto">Where I can get the link for magic mirror other version</p>
<p dir="auto"><a href="https://github.com/MichMich/MagicMirror/releases" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/releases</a></p>
]]></description><link>https://forum.magicmirror.builders/post/28877</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28877</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 02 Oct 2017 16:54:33 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Mon, 02 Oct 2017 15:43:02 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
Just downgraded and all Is working good . Where I can get the link for magic mirror other version because my current version 2.1.0 doesn’t support modules like facial recognition</p>
<p dir="auto">Regards saif</p>
]]></description><link>https://forum.magicmirror.builders/post/28872</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28872</guid><dc:creator><![CDATA[saifkazi]]></dc:creator><pubDate>Mon, 02 Oct 2017 15:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Mon, 02 Oct 2017 14:42:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saifkazi" aria-label="Profile: saifkazi">@<bdi>saifkazi</bdi></a> Others reported the same issue about that. I think you’d better wait for this new upgrade being more stable. I believe <a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a> could make hotfix as soon.</p>
]]></description><link>https://forum.magicmirror.builders/post/28864</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28864</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 02 Oct 2017 14:42:56 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Mon, 02 Oct 2017 14:39:46 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
This problem started after updating mm and installing remote control</p>
]]></description><link>https://forum.magicmirror.builders/post/28863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28863</guid><dc:creator><![CDATA[saifkazi]]></dc:creator><pubDate>Mon, 02 Oct 2017 14:39:46 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Mon, 02 Oct 2017 14:36:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saifkazi" aria-label="Profile: saifkazi">@<bdi>saifkazi</bdi></a> If your mobile phone and MM are in same network, <code>ipWhitelist</code> in your config could be the problem. currently, many problems about ipWhitelist are reported. See the forum topics about that.(use  search about ‘ipWhitelist’)</p>
]]></description><link>https://forum.magicmirror.builders/post/28860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28860</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 02 Oct 2017 14:36:04 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Mon, 02 Oct 2017 14:35:03 GMT]]></title><description><![CDATA[<p dir="auto">@Sean<br />
No I am in the same network and I can’t access it with public IP of my router. I was able to access it before but now I can’t access it .</p>
]]></description><link>https://forum.magicmirror.builders/post/28859</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28859</guid><dc:creator><![CDATA[saifkazi]]></dc:creator><pubDate>Mon, 02 Oct 2017 14:35:03 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access magic mirror via http ? on Mon, 02 Oct 2017 14:28:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/saifkazi" aria-label="Profile: saifkazi">@<bdi>saifkazi</bdi></a> more detailed information is needed.</p>
<ol>
<li>Is your mobile phone is in the same network with your MM? (e.g. in your house)</li>
<li>If not, you need static IP or DDNS service for your MM for accessing from outside network.</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/28858</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28858</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 02 Oct 2017 14:28:21 GMT</pubDate></item></channel></rss>
