<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Boot Magic Mirror on start up.]]></title><description><![CDATA[<p dir="auto">Hi guys.<br />
I’m a complete newb at this. Just found out about magic mirror 2 days ago, and I got i working perfectly with Git for windows.<br />
I just have one question, I’ve searched the interwebs and this forum, but with no luck.<br />
As I run this from windows 7 - 32 bit, I would like to have the MM to start up when I boot the pc.<br />
It’s quite easy to get Git Bash to run from the startup, but I guess I need to run a script to start up the actual MM.<br />
I tried my luck with PM2, but since I have no idea of what I’m actually doing, I hope that someone else in here can help me.</p>
]]></description><link>https://forum.magicmirror.builders/topic/5051/boot-magic-mirror-on-start-up</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 17:14:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5051.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Oct 2017 18:43:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Boot Magic Mirror on start up. on Sun, 07 Oct 2018 15:30:22 GMT]]></title><description><![CDATA[<p dir="auto">In Windows you don’t need to “sudo” and that command does not exist.  That is a *nix thing to say that you want to run with elevated privileges.</p>
<p dir="auto"><a href="https://www.xkcd.com/149/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.xkcd.com/149/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/45102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45102</guid><dc:creator><![CDATA[felafel]]></dc:creator><pubDate>Sun, 07 Oct 2018 15:30:22 GMT</pubDate></item><item><title><![CDATA[Reply to Boot Magic Mirror on start up. on Thu, 05 Oct 2017 15:42:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ranger33" aria-label="Profile: ranger33">@<bdi>ranger33</bdi></a><br />
For a start, I can’t use the command “sudo npm install -g pm2” - It gives back “bash: sudo: command not found”</p>
]]></description><link>https://forum.magicmirror.builders/post/29053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29053</guid><dc:creator><![CDATA[Angel_Od]]></dc:creator><pubDate>Thu, 05 Oct 2017 15:42:41 GMT</pubDate></item><item><title><![CDATA[Reply to Boot Magic Mirror on start up. on Thu, 05 Oct 2017 02:11:36 GMT]]></title><description><![CDATA[<p dir="auto">Did you follow this guide exactly? <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
<p dir="auto">First time I tried i missed the step where you copy paste the code provided by the script into the terminal! Pm2 can be a little finicky I find at first but once it is running smooth works like a charm!</p>
]]></description><link>https://forum.magicmirror.builders/post/29021</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29021</guid><dc:creator><![CDATA[ranger33]]></dc:creator><pubDate>Thu, 05 Oct 2017 02:11:36 GMT</pubDate></item></channel></rss>
