<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mirror Film Visible Light Transmittance Question]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am looking to use mirror film for my magic mirror. I’ve read a couple threads here and elsewhere and know that it is not ideal but does work. Unfortunately I cannot find a reasonable priced two way mirror in Canada :(.</p>
<p dir="auto">I am wondering if anyone knows what VLT I want? The mirror film I have found on ebay ranges from 15%, 20%, 70% Visible Light Transmittance. Anyone know what would be suitable?</p>
<p dir="auto">I am currently looking at this one specifically: <a href="http://www.ebay.com/itm/One-Way-Mirrored-Window-Film-Solar-Reflective-Silver-Layer-Tint-Wide-39-37/152611031512?_trkparms=aid%3D555019%26algo%3DPL.BANDIT%26ao%3D1%26asc%3D46673%26meid%3D5b545dca9a1e4c10b4a627cdd3e8addf%26pid%3D100753%26rk%3D1%26rkt%3D1%26&amp;_trksid=p2045573.c100753.m4841" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ebay.com/itm/One-Way-Mirrored-Window-Film-Solar-Reflective-Silver-Layer-Tint-Wide-39-37/152611031512?_trkparms=aid%3D555019%26algo%3DPL.BANDIT%26ao%3D1%26asc%3D46673%26meid%3D5b545dca9a1e4c10b4a627cdd3e8addf%26pid%3D100753%26rk%3D1%26rkt%3D1%26&amp;_trksid=p2045573.c100753.m4841</a></p>
<p dir="auto">Thanks,</p>
]]></description><link>https://forum.magicmirror.builders/topic/5083/mirror-film-visible-light-transmittance-question</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 20:16:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5083.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Oct 2017 19:56:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mirror Film Visible Light Transmittance Question on Mon, 09 Oct 2017 15:05:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> said in <a href="/post/29125">Mirror Film Visible Light Transmittance Question</a>:</p>
<p dir="auto">Visible Light Transmission or just light transmission, whatever they want to call it is basically how much of the light it lets through from the other side.</p>
<p dir="auto">with films you should also find the light reflection number, this will indicate if it would actually work as a mirror or just a shiny metal pot with somewhat of a reflection in it…</p>
<p dir="auto">Anyhow, the higher number the more you will see of the object behind. 70% is a big no, you will pretty much see everything, even if it’s turned off.<br />
I would suggest 15% or 20%, if the room you are going to place the mirror is bright/really bright, I would go with the higher number. If it’s darker I would go with 15%.</p>
<p dir="auto">And Have you actually asked any glass businesses if they can order it for you? Most major glass producers have a two-way mirror option.</p>
<p dir="auto">The room would be a bedroom so average brightness. I have emailed about 10 custom glass and window companies and waiting to here back. The one that did get back to me is $200+ for a 24x36" so its likely out of my budget.</p>
]]></description><link>https://forum.magicmirror.builders/post/29225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29225</guid><dc:creator><![CDATA[CupMan]]></dc:creator><pubDate>Mon, 09 Oct 2017 15:05:00 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Film Visible Light Transmittance Question on Mon, 09 Oct 2017 07:49:54 GMT]]></title><description><![CDATA[<p dir="auto">But if your frame is exactly fit for your LCD size, so there is no remained area beside LCD, higher transfer rate could be nicer. It could help clearer visibility. However, It depends on your conditions.</p>
]]></description><link>https://forum.magicmirror.builders/post/29198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29198</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 09 Oct 2017 07:49:54 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Film Visible Light Transmittance Question on Sun, 08 Oct 2017 20:44:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cupman" aria-label="Profile: CupMan">@<bdi>CupMan</bdi></a></p>
<p dir="auto">You would do well with 15% or 20%. Certainly not 70%.</p>
]]></description><link>https://forum.magicmirror.builders/post/29127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29127</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 08 Oct 2017 20:44:03 GMT</pubDate></item><item><title><![CDATA[Reply to Mirror Film Visible Light Transmittance Question on Sun, 08 Oct 2017 20:41:16 GMT]]></title><description><![CDATA[<p dir="auto">Visible Light Transmission or just light transmission, whatever they want to call it is basically how much of the light it lets through from the other side.</p>
]]></description><link>https://forum.magicmirror.builders/post/29125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29125</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 08 Oct 2017 20:41:16 GMT</pubDate></item></channel></rss>
