<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-xiaomi - Temperature and Humidity from your smarthome]]></title><description><![CDATA[<h1>Description</h1>
<p dir="auto">Hi guys,</p>
<p dir="auto">just made a small module to display temperature and humidity from your Xiaomi smarthome sensors. Pretty basic so far, but hugely helpful to me to monitor heating and ventilation (humidity!).</p>
<h1>Screenshots</h1>
<p dir="auto">Sensors look like this and cost around 8 €:<br />
<img src="https://gadgetflowcdn.com/wp-content/uploads/2016/05/Original-Xiaomi-Mi-Smart-Temperature-and-Humidity-Sensor-01.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Here a sample from the module:<br />
<img src="https://camo.githubusercontent.com/b601117662d3df8835e283cc9c04cdde61f071b8/68747470733a2f2f696d6167652e6962622e636f2f656d565848622f42696c6473636869726d666f746f5f323031375f31315f31315f756d5f31335f32355f33372e706e67" alt="alt text" class=" img-fluid img-markdown" /></p>
<h1>Download</h1>
<p dir="auto">[card:mirko3000/MMM-xiaomi]</p>
]]></description><link>https://forum.magicmirror.builders/topic/5084/mmm-xiaomi-temperature-and-humidity-from-your-smarthome</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 19:57:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5084.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Oct 2017 21:39:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Wed, 21 Sep 2022 18:44:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
can anyone tell me if this module still works?  If yes, which gateway should I purchase to make sure I can view sensor data with the MM?</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/104669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/104669</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Wed, 21 Sep 2022 18:44:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Fri, 14 May 2021 17:28:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smotx" aria-label="Profile: smotx">@<bdi>smotx</bdi></a></p>
<p dir="auto">Thank you Mirko3000 for this great module.<br />
I was finally able to retrieve the Device IDs via the Aqara gateway, and the tokens from the gateway and vacuum in the Miio Mac application.<br />
I can correctly display the temperature and humidity of my different rooms in the house. The same for my vaccum via the Xiaomi-vaccum module.<br />
The only thing I can’t do is to declare the door sensors and the sensory sensors.<br />
What should I declare in the configuration file?</p>
<p dir="auto">What script should be entered to display all the sensors in this way?</p>
<p dir="auto">Thank you in advance for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/91458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91458</guid><dc:creator><![CDATA[ectovito]]></dc:creator><pubDate>Fri, 14 May 2021 17:28:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Fri, 07 May 2021 02:49:05 GMT]]></title><description><![CDATA[<p dir="auto">If there is no humidity sensor in the room, but there is a sensor for opening windows and doors, how does it look like?</p>
]]></description><link>https://forum.magicmirror.builders/post/91306</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91306</guid><dc:creator><![CDATA[Nosaer]]></dc:creator><pubDate>Fri, 07 May 2021 02:49:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Wed, 05 May 2021 19:29:45 GMT]]></title><description><![CDATA[<p dir="auto">You have no plans to increase the functionality of the module and add more sensors for display?</p>
]]></description><link>https://forum.magicmirror.builders/post/91273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91273</guid><dc:creator><![CDATA[Nosaer]]></dc:creator><pubDate>Wed, 05 May 2021 19:29:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Thu, 25 Mar 2021 20:12:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi mirko3000</p>
<p dir="auto">Thanks for a great module.<br />
What gateway are you using?</p>
]]></description><link>https://forum.magicmirror.builders/post/89901</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89901</guid><dc:creator><![CDATA[mag999]]></dc:creator><pubDate>Thu, 25 Mar 2021 20:12:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Sun, 10 Nov 2019 20:03:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mirko3000" aria-label="Profile: mirko3000">@<bdi>mirko3000</bdi></a> … oooh an update… what’s new? thx…</p>
]]></description><link>https://forum.magicmirror.builders/post/64127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/64127</guid><dc:creator><![CDATA[mydiva]]></dc:creator><pubDate>Sun, 10 Nov 2019 20:03:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Mon, 05 Aug 2019 18:51:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/norman" aria-label="Profile: norman">@<bdi>norman</bdi></a> I have the mii gateway with aqara sensors …works fine</p>
]]></description><link>https://forum.magicmirror.builders/post/59822</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59822</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Mon, 05 Aug 2019 18:51:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Mon, 05 Aug 2019 18:50:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/norman" aria-label="Profile: norman">@<bdi>norman</bdi></a> if you get the token from the Aqara gateway it should work …</p>
]]></description><link>https://forum.magicmirror.builders/post/59821</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59821</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Mon, 05 Aug 2019 18:50:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Mon, 05 Aug 2019 17:26:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello everyone,<br />
is there a chance to use this module with the Aqara Gateway and the Aqara Sensors?  I have a problem to find the sensors with miio. Thanks in advance!</p>
<p dir="auto">Best regards!</p>
]]></description><link>https://forum.magicmirror.builders/post/59818</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/59818</guid><dc:creator><![CDATA[norman]]></dc:creator><pubDate>Mon, 05 Aug 2019 17:26:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Sun, 26 May 2019 01:05:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mirko3000" aria-label="Profile: mirko3000">@<bdi>mirko3000</bdi></a> ,</p>
<p dir="auto">How to remove the ‘&gt;’ symbols which in front of the temperature and humidity?</p>
<p dir="auto"><img src="/assets/uploads/files/1558832312483-10344818-eeef-4b5a-ac89-aa44732dac4a-image.png" alt="0_1558832311773_10344818-eeef-4b5a-ac89-aa44732dac4a-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I try to set  <em><strong>showTend: false,</strong></em> but it does not work.</p>
<p dir="auto">Could you or anyone give me some suggestions? Thanks in advance.</p>
]]></description><link>https://forum.magicmirror.builders/post/57432</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/57432</guid><dc:creator><![CDATA[lovesicker]]></dc:creator><pubDate>Sun, 26 May 2019 01:05:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Tue, 09 Apr 2019 14:27:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/garbleflux" aria-label="Profile: garbleflux">@<bdi>garbleflux</bdi></a></p>
<p dir="auto">Yes, I can add two instances in config.js file at the same time.</p>
<p dir="auto">YOU ARE RIGHT!<br />
It’s not necessary. According to your suggestion, I register all of my sensors on ONE gateway. I can still fulfill all my needs.</p>
<p dir="auto">I’m stupid. I’ve made simple things complicated.</p>
<p dir="auto">Tanks again!<br />
Good luck.</p>
]]></description><link>https://forum.magicmirror.builders/post/55677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/55677</guid><dc:creator><![CDATA[lovesicker]]></dc:creator><pubDate>Tue, 09 Apr 2019 14:27:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Wed, 06 Mar 2019 21:23:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lovesicker" aria-label="Profile: lovesicker">@<bdi>lovesicker</bdi></a> OK. Did you try to start the module twice? Maybe this is the possibility to activate both gateways at the same time as you need it.<br />
Regards Mike</p>
]]></description><link>https://forum.magicmirror.builders/post/53799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53799</guid><dc:creator><![CDATA[garbleflux]]></dc:creator><pubDate>Wed, 06 Mar 2019 21:23:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Tue, 05 Mar 2019 08:19:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/garbleflux" aria-label="Profile: garbleflux">@<bdi>garbleflux</bdi></a> thank you for your discussion.</p>
<p dir="auto">It’s difficult to explain. Let me try. Maybe my scenario is very different with yours.</p>
<p dir="auto">There are one Xiaomi temperature sensor, one Xiaomi air conditioning companion (gateway) and one Xiaomi intelligent clock (integrated partial AI function) in EACH bedroom.</p>
<p dir="auto">When I speak to the clock, “Hi Xiaoai, please tell me the room temperature” or “temperature”, the clock tell me the correct number of degrees via the RIGHT gateway. When I say “power on the air conditioning”,  the same thing happen.</p>
<p dir="auto">It’s unsuitable that I say "tell me CHILDROOM temperature " or “power off CHILDROOM air conditioning” when I’m in my bedroom. Although I know it is realizable.</p>
<p dir="auto">I’m not sure I clearly explain the reason. Anyway, I need two gateways in my house.</p>
]]></description><link>https://forum.magicmirror.builders/post/53684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53684</guid><dc:creator><![CDATA[lovesicker]]></dc:creator><pubDate>Tue, 05 Mar 2019 08:19:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Tue, 05 Mar 2019 06:51:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lovesicker" aria-label="Profile: lovesicker">@<bdi>lovesicker</bdi></a> Hi,<br />
why do you use two gateways? It’s not necessary. I use one gateway for my complete house. I use 10 temperature and humity sensors. Have a closer look to my config.<br />
Regards Mike.</p>
]]></description><link>https://forum.magicmirror.builders/post/53681</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53681</guid><dc:creator><![CDATA[garbleflux]]></dc:creator><pubDate>Tue, 05 Mar 2019 06:51:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Tue, 05 Mar 2019 03:05:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/garbleflux" aria-label="Profile: garbleflux">@<bdi>garbleflux</bdi></a> First, thank you for your reply.<br />
I have two different rooms. There are a temperature sensor and a gateway in each room! So I  have to add two gateways in config.js file.</p>
]]></description><link>https://forum.magicmirror.builders/post/53674</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53674</guid><dc:creator><![CDATA[lovesicker]]></dc:creator><pubDate>Tue, 05 Mar 2019 03:05:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Mon, 04 Mar 2019 19:33:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lovesicker" aria-label="Profile: lovesicker">@<bdi>lovesicker</bdi></a> Hi,<br />
I think you are on the wrong way: You use gatewayIP and gatewayToken twice. Thats not necessary.<br />
Look to my configuration - this works fine:<br />
{<br />
module: ‘MMM-xiaomi’,<br />
position: ‘bottom_left’,<br />
colored: true,		<br />
header: ‘Temperatur / Luftfeuchtigkeit’,  // This is optional<br />
config: {<br />
gatewayIP: ‘192.168.160.xx’,<br />
outsideSensorId: ‘15xxx0201dxxx’,<br />
gatewayToken: ‘cd857eee1fc760d029767709cd50xxxx’,<br />
showWindow: true,<br />
showVentilation: true,<br />
showLights: false,<br />
showTend: false,<br />
showNotifications: false,			<br />
audioNotifications: false,</p>
<pre><code>                    rooms:  [
		minTemperature : 15,
                    maxTemperature : 35,
                    sortOrder: 1,
		devices : ['158d0001c2cxxx']
		sortOrder: 20,
                    devices : ['15xxx00201d4xxx']
                    sortOrder: 2,
                    sortOrder: 3,
                    maxTemperature : 30,
                    devices : ['1xxx000201dxxx', '15xxx001f49xxx']
                    sortOrder: 4,
                    devices : ['1xxd0001c14xxx']
                    sortOrder: 5,
		devices : ['15xxx01f54xxx']
                    minTemperature : 10,
                    sortOrder: 7,
		devices : ['15xxx002029xxx']
                    sortOrder: 10,
                    devices : ['15xxx001c1xxx']
                    sortOrder: 9,
                    devices : ['15xxx001c2axxx']
                    sortOrder: 8,
                    devices : ['15xxx001c1axxx']
                    minTemperature : 18,
                    sortOrder: 6,
                    devices : ['15xxx001c2cxxx']
<p dir="auto">]</p>
]]></description><link>https://forum.magicmirror.builders/post/53654</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53654</guid><dc:creator><![CDATA[garbleflux]]></dc:creator><pubDate>Mon, 04 Mar 2019 19:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Mon, 04 Mar 2019 13:35:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">I have two temperature sensors. Each sensor registers with a gateway. Could anyone tell me how to add the two gateways in config.js file?</p>
<p dir="auto">I try to add the following codes in config.js:</p>
<p dir="auto">{<br />
position: ‘top_right’,<br />
header: ‘Temperature / Humidity’,<br />
config: {<br />
gatewayIP: ‘192.168.186.181’,<br />
gatewayToken: ‘xxxxxxxx-ceec093b30b1775dc741a7’,<br />
audioNotifications: true,<br />
rooms: [<br />
{<br />
sortOrder: 20,<br />
devices : [‘158d000xxxx9f’]<br />
}<br />
],<br />
gatewayIP: ‘192.168.186.166’,<br />
gatewayToken: ‘xxxxxxxx–927e2d20b22c22b007194c’,<br />
rooms: [<br />
{<br />
sortOrder: 30,<br />
devices : [‘158d000xxxx4f6’]<br />
}<br />
]<br />
}<br />
}</p>
<p dir="auto">but MagicMirror always display the last sensor, which registers with the secondary gateway in config.js file.</p>
<p dir="auto"><img src="https://user-images.githubusercontent.com/48181152/53735589-4db81d00-3ec2-11e9-90ad-e894dc952560.png" alt="image" class=" img-fluid img-markdown" /></p>
<p dir="auto">Could anyone give me some suggestions? Thanks in advance!</p>
]]></description><link>https://forum.magicmirror.builders/post/53639</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/53639</guid><dc:creator><![CDATA[lovesicker]]></dc:creator><pubDate>Mon, 04 Mar 2019 13:35:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Sun, 23 Dec 2018 14:19:24 GMT]]></title><description><![CDATA[<p dir="auto">I can’t find what needs to be changed in CSS to change the font color of the temperature and humidity numbers.</p>
]]></description><link>https://forum.magicmirror.builders/post/48463</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/48463</guid><dc:creator><![CDATA[Serg]]></dc:creator><pubDate>Sun, 23 Dec 2018 14:19:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Mon, 10 Dec 2018 16:41:42 GMT]]></title><description><![CDATA[<p dir="auto">after this command :</p>
<pre><code>miio tokens update 567xxxxx --token 6xxxxxxxxxxxxxxxxxxxxxxxxxxx
<p dir="auto">mine to work again a few days, <strong>and now is KO again</strong>… for the third time… :face_with_steam_from_nose:   Token has not changed, ip has not changed…</p>
]]></description><link>https://forum.magicmirror.builders/post/47928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47928</guid><dc:creator><![CDATA[Smotx]]></dc:creator><pubDate>Mon, 10 Dec 2018 16:41:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Wed, 05 Dec 2018 16:17:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/smotx" aria-label="Profile: smotx">@<bdi>smotx</bdi></a> said in <a href="/post/46617">MMM-xiaomi - Temperature and Humidity from your smarthome</a>:</p>
<p dir="auto">hi,</p>
<p dir="auto">Same problem here too</p>
<p dir="auto">I have changed my router, so i have change wifi of Xiaomi hub</p>
<p dir="auto">On magicmirror config  i have set new ip <a href="http://192.168.2.xxx" target="_blank" rel="noopener noreferrer nofollow ugc">192.168.2.xxx</a> (before <a href="http://192.168.1.xxx" target="_blank" rel="noopener noreferrer nofollow ugc">192.168.1.xxx</a>).</p>
<p dir="auto">But always nothing on MagicMirror after reboot.</p>
<p dir="auto">perhaps token has changed with new router… So, on the rasp i launch command ```<br />
miio discover</p>
<pre><code class="language-,">
` $ sudo miio discover
 INFO  Discovering devices. Press Ctrl+C to stop.
Device ID: 567xxxx54
Model info: Unknown
Address: 192.168.2.xxx
Token: ???
Support: Unknown
Anybody know why ? :(.
<p dir="auto">I had the same problem. Meanwhile, I have found the solution. An update from Xiaomi changed the token in the gateway. This must now be read out via the smartphone. In my case  the miio discovery command did not work any more. I followed this instruktion to get the new token</p>
<p dir="auto"><strong><a href="https://forum.smartapfel.de/forum/thread/1219-xiaomi-mi-gateway-homebridge-mi-aqara/?postID=31779#post31779" target="_blank" rel="noopener noreferrer nofollow ugc">https://forum.smartapfel.de/forum/thread/1219-xiaomi-mi-gateway-homebridge-mi-aqara/?postID=31779#post31779</a></strong></p>
<p dir="auto">… and now all works fine again - I have all my sensors back  on the mirror.</p>
<p dir="auto">regards<br />
Mike</p>
]]></description><link>https://forum.magicmirror.builders/post/47746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/47746</guid><dc:creator><![CDATA[garbleflux]]></dc:creator><pubDate>Wed, 05 Dec 2018 16:17:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Sun, 18 Nov 2018 13:36:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gauka12345" aria-label="Profile: gauka12345">@<bdi>gauka12345</bdi></a></p>
<p dir="auto">I gave found new token on Mi home app android, it worked a few days, and then again it does not work anymore, it tells me ‘time out’ and in mioo discover there is nothing at all</p>
<p dir="auto">{ Error: Call to device timed out<br />
at retry (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:225:18)<br />
at _ensureToken.catch.err (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:238:8)<br />
at  code: ‘timeout’</p>
]]></description><link>https://forum.magicmirror.builders/post/46952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46952</guid><dc:creator><![CDATA[Smotx]]></dc:creator><pubDate>Sun, 18 Nov 2018 13:36:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Sat, 17 Nov 2018 14:15:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi<br />
You can get token by installing older version of mi home app on you mobile<br />
<a href="https://www.apkmirror.com/apk/xiaomi-inc/mihome/mihome-5-0-19-release/mihome-5-0-19-android-apk-download/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.apkmirror.com/apk/xiaomi-inc/mihome/mihome-5-0-19-release/mihome-5-0-19-android-apk-download/</a><br />
Then you will need to follow this tutorial to obtain the token<br />
<a href="https://www.youtube.com/watch?v=Q4QV8tMI8H4" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=Q4QV8tMI8H4</a><br />
however so far i have swap the tokens but with no luck. i think the device need to be discovered by MIiio.</p>
]]></description><link>https://forum.magicmirror.builders/post/46901</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46901</guid><dc:creator><![CDATA[gauka12345]]></dc:creator><pubDate>Sat, 17 Nov 2018 14:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Sun, 11 Nov 2018 12:47:31 GMT]]></title><description><![CDATA[<p dir="auto">hi,</p>
miio discover</p>
Model info: Unknown
Token: ???
Support: Unknown
Anybody know why ? :(.</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/46617</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46617</guid><dc:creator><![CDATA[Smotx]]></dc:creator><pubDate>Sun, 11 Nov 2018 12:47:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-xiaomi - Temperature and Humidity from your smarthome on Thu, 08 Nov 2018 21:31:17 GMT]]></title><description><![CDATA[<p dir="auto">pi@raspberrypi:~/miio $ miio discover<br />
INFO  Discovering devices. Press Ctrl+C to stop.</p>
<p dir="auto">Device ID: 72558327<br />
Model info: lumi.gateway.v3<br />
Address: 192.168.0.9<br />
Token: ???<br />
Support: At least generic</p>
]]></description><link>https://forum.magicmirror.builders/post/46540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/46540</guid><dc:creator><![CDATA[gauka12345]]></dc:creator><pubDate>Thu, 08 Nov 2018 21:31:17 GMT</pubDate></item></channel></rss>
