<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Proximity sensor &quot;switch&quot; behind  mirror?]]></title><description><![CDATA[<p dir="auto">Hello Team!</p>
<p dir="auto">i search for a sensor who is working through my mirror glas! I dont have any solution for that!</p>
<p dir="auto">I want to push a button (like proximity sensor behind the glas) who is detecting a finger or whatever a few mm or cm in front of the glas on a position. It dont have to be very acurate… its also enough when the sensor is working in a bigger area of a screen, but not like the mircorwave sensor who is working from 2-20m.</p>
<p dir="auto">Has anyone an idea?</p>
]]></description><link>https://forum.magicmirror.builders/topic/5134/proximity-sensor-switch-behind-mirror</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 01:41:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5134.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Oct 2017 10:51:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Proximity sensor &quot;switch&quot; behind  mirror? on Wed, 22 Nov 2017 08:33:28 GMT]]></title><description><![CDATA[<p dir="auto">Capacitive touch doesn’t work through mirrors.<br />
Mostly because the coating that gives you the reflection is almost always metallic.</p>
]]></description><link>https://forum.magicmirror.builders/post/31480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31480</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Wed, 22 Nov 2017 08:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to Proximity sensor &quot;switch&quot; behind  mirror? on Tue, 21 Nov 2017 20:51:23 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://www.chinasmartsensor.com/glass-lights-mirror-touch-switch-specially-design-for-lights-on-the-mirror-electrical-ap.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.chinasmartsensor.com/glass-lights-mirror-touch-switch-specially-design-for-lights-on-the-mirror-electrical-ap.html</a></p>
<p dir="auto">😁</p>
]]></description><link>https://forum.magicmirror.builders/post/31437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31437</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Tue, 21 Nov 2017 20:51:23 GMT</pubDate></item><item><title><![CDATA[Reply to Proximity sensor &quot;switch&quot; behind  mirror? on Tue, 21 Nov 2017 20:29:08 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://youtu.be/O8uL1oS-6Jg" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/O8uL1oS-6Jg</a> Researchtime :)</p>
]]></description><link>https://forum.magicmirror.builders/post/31431</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31431</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Tue, 21 Nov 2017 20:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to Proximity sensor &quot;switch&quot; behind  mirror? on Tue, 21 Nov 2017 18:57:36 GMT]]></title><description><![CDATA[<p dir="auto">I recently replaced the PIR sensor of my mirror with this microwave radar sensor:</p>
<p dir="auto"><a href="https://m.ebay.de/itm/5-8GHZ-Microwave-Radar-Sensor-6-9M-Smart-Switch-for-Home-Control-3-3-20V-DC-New/272851896102?hash=item3f873d8726:g:12cAAOSwk~NZv24a" target="_blank" rel="noopener noreferrer nofollow ugc">https://m.ebay.de/itm/5-8GHZ-Microwave-Radar-Sensor-6-9M-Smart-Switch-for-Home-Control-3-3-20V-DC-New/272851896102?hash=item3f873d8726:g:12cAAOSwk~NZv24a</a></p>
<p dir="auto">I mounted behind the mirror glass and it works like a charm. It’s compatible with @Paviros PIR module / can be used as drop in replacement fir the PIR sensor.</p>
<p dir="auto">:::</p>
<p dir="auto">Spoiler Text</p>
]]></description><link>https://forum.magicmirror.builders/post/31427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31427</guid><dc:creator><![CDATA[sero]]></dc:creator><pubDate>Tue, 21 Nov 2017 18:57:36 GMT</pubDate></item><item><title><![CDATA[Reply to Proximity sensor &quot;switch&quot; behind  mirror? on Tue, 21 Nov 2017 15:58:04 GMT]]></title><description><![CDATA[<p dir="auto">Something like this? <a href="https://www.youtube.com/watch?v=iswUSatSe9E" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=iswUSatSe9E</a><br />
I´m working on a solution :P cause I want that too!</p>
<p dir="auto">An other solution is the ZX Distance sensor from sparksfun: <a href="https://www.sparkfun.com/products/13162" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.sparkfun.com/products/13162</a> underneath the frame</p>
]]></description><link>https://forum.magicmirror.builders/post/31421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31421</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Tue, 21 Nov 2017 15:58:04 GMT</pubDate></item><item><title><![CDATA[Reply to Proximity sensor &quot;switch&quot; behind  mirror? on Tue, 10 Oct 2017 23:17:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefanme" aria-label="Profile: StefanMe">@<bdi>StefanMe</bdi></a> Is there a particular reason why you want it to work through the glass?  If you buy a regular PIR sensor, you can just remove the dome, drill a small hole through your frame – 2 or 3mm is all you need – and mount the sensor behind the hole.  It has the added benefit of ONLY being triggered when someone stands right in front of the mirror.</p>
<p dir="auto">If your mirror is touch sensitive, then I believe there is a module which allows you to put touch regions on your mirror that do stuff, say like wake up the screen.  the name of the module escapes me, but I’m sure a search will bring it up.</p>
<p dir="auto">Short of either of these, you can install an actual button, then use the MMM-Buttons module to have it react whatever way you want when it is pressed.</p>
]]></description><link>https://forum.magicmirror.builders/post/29357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29357</guid><dc:creator><![CDATA[j.e.f.f]]></dc:creator><pubDate>Tue, 10 Oct 2017 23:17:05 GMT</pubDate></item></channel></rss>
