<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Display modules in a carousel]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/barnabycolby/MMM-Carousel" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/barnabycolby/MMM-Carousel</a></p>
<p dir="auto">Instead of displaying all of the modules at once, each one is displayed for a configurable amount of time before displaying the next in the list. This is useful on smaller screens, where there is not enough space to display more than a single module.</p>
]]></description><link>https://forum.magicmirror.builders/topic/516/display-modules-in-a-carousel</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 10:35:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/516.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Aug 2016 21:40:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Display modules in a carousel on Fri, 03 Feb 2017 23:49:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/izanbard" aria-label="Profile: izanbard">@<bdi>izanbard</bdi></a> said in <a href="/post/13487">Display modules in a carousel</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a> yes you can, but you do it by position. Read the config above and see if you can work out in the positional settings you ignore modules per position. Hint it is between enabled and overrideTransitionInterval.</p>
<p dir="auto">Working fine ;)<br />
That’s perfect!</p>
<p dir="auto">thanks mate!</p>
]]></description><link>https://forum.magicmirror.builders/post/13488</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13488</guid><dc:creator><![CDATA[PointPubMedia]]></dc:creator><pubDate>Fri, 03 Feb 2017 23:49:44 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Fri, 03 Feb 2017 23:48:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a> yes you can, but you do it by position. Read the config above and see if you can work out in the positional settings you ignore modules per position. Hint it is between enabled and overrideTransitionInterval.</p>
]]></description><link>https://forum.magicmirror.builders/post/13487</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13487</guid><dc:creator><![CDATA[izanbard]]></dc:creator><pubDate>Fri, 03 Feb 2017 23:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Fri, 03 Feb 2017 22:36:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/izanbard" aria-label="Profile: izanbard">@<bdi>izanbard</bdi></a> But with positional I can’t ignore module ?</p>
]]></description><link>https://forum.magicmirror.builders/post/13479</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13479</guid><dc:creator><![CDATA[PointPubMedia]]></dc:creator><pubDate>Fri, 03 Feb 2017 22:36:06 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 02 Feb 2017 20:28:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/izanbard" aria-label="Profile: izanbard">@<bdi>izanbard</bdi></a></p>
<p dir="auto">works great, thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/13367</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13367</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Thu, 02 Feb 2017 20:28:28 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 02 Feb 2017 18:07:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a> yes, if all your iframes are in the same “position” (say top_left)on the page then this config should do it:</p>
<pre><code>        {
            module: 'MMM-Carousel',
                transitionInterval: 10000,
                mode: 'positional',
                top_left: {enabled: true, ignoreModules: [], overrideTransitionInterval: 10000},
]]></description><link>https://forum.magicmirror.builders/post/13361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13361</guid><dc:creator><![CDATA[izanbard]]></dc:creator><pubDate>Thu, 02 Feb 2017 18:07:59 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 02 Feb 2017 17:56:23 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!</p>
<p dir="auto">Is it possible to rotate multiple module definition of the same name ?   I mean I’m using MMM-iFrame couple of time on the screen but would like to have only 1 place with multiple iFrame rotating…</p>
]]></description><link>https://forum.magicmirror.builders/post/13360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13360</guid><dc:creator><![CDATA[PointPubMedia]]></dc:creator><pubDate>Thu, 02 Feb 2017 17:56:23 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 02 Feb 2017 16:02:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> have a look at the latest version, I think it will have some of the features you are looking for</p>
]]></description><link>https://forum.magicmirror.builders/post/13358</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13358</guid><dc:creator><![CDATA[izanbard]]></dc:creator><pubDate>Thu, 02 Feb 2017 16:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 02 Feb 2017 15:59:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/cnelso24" aria-label="Profile: cnelso24">@<bdi>cnelso24</bdi></a> Hey, I have just had a PR accepted that adds several config options that should help you</p>
]]></description><link>https://forum.magicmirror.builders/post/13357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13357</guid><dc:creator><![CDATA[izanbard]]></dc:creator><pubDate>Thu, 02 Feb 2017 15:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 02 Feb 2017 03:22:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a></p>
<p dir="auto">Did you ever figure this out? I’m interested in the same thing</p>
]]></description><link>https://forum.magicmirror.builders/post/13316</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13316</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Thu, 02 Feb 2017 03:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Sat, 10 Dec 2016 13:28:56 GMT]]></title><description><![CDATA[<p dir="auto">I’m saying that i’m using the swap code from the URL you gave me!  But this works like a charm for different module at the same location!  What I’m trying to do it’s to rotate the same module with different configuration at the same place!</p>
<p dir="auto">I’m using the iFrame module to display some graphic from Grafana and I would need to “rotate” a couple of them on MM at the same location!  So instead of having 3-4 iFrame at the same time, I will alternate all of them at the same location to save on space!</p>
]]></description><link>https://forum.magicmirror.builders/post/9137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9137</guid><dc:creator><![CDATA[PointPubMedia]]></dc:creator><pubDate>Sat, 10 Dec 2016 13:28:56 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Sat, 10 Dec 2016 04:58:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a><br />
Sorry - what are you trying to ask me?   I can send you “my” module (basically hacked KirAsh’s a bit - works like a charm). I’m actually trying to use the “Carousel” right now…</p>
]]></description><link>https://forum.magicmirror.builders/post/9126</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9126</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Sat, 10 Dec 2016 04:58:29 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Sat, 10 Dec 2016 02:36:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> Really like the version of <a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a>  …</p>
<p dir="auto">But how to rotate the “same” module ?   I’m using the iframe module more than one time, and I would like to rotate all of them…</p>
]]></description><link>https://forum.magicmirror.builders/post/9121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9121</guid><dc:creator><![CDATA[PointPubMedia]]></dc:creator><pubDate>Sat, 10 Dec 2016 02:36:47 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Fri, 09 Dec 2016 04:33:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a><br />
I like <a class="plugin-mentions-user plugin-mentions-a" href="/user/barnabycolby" aria-label="Profile: barnabycolby">@<bdi>barnabycolby</bdi></a> 's version (ie exempting all but the ones you want to rotate) a lot.<br />
But here is something KirAsh4 made for me a while ago<br />
<a href="https://forum.magicmirror.builders/topic/373/alternating-modules-to-save-on-real-estate/3">https://forum.magicmirror.builders/topic/373/alternating-modules-to-save-on-real-estate/3</a><br />
that will do the job too - and it will let you learn a bit java along the way</p>
<p dir="auto">Enjoy</p>
]]></description><link>https://forum.magicmirror.builders/post/9075</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9075</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Fri, 09 Dec 2016 04:33:37 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 08 Dec 2016 21:21:45 GMT]]></title><description><![CDATA[<p dir="auto">Yep, <a class="plugin-mentions-user plugin-mentions-a" href="/user/frog" aria-label="Profile: frog">@<bdi>frog</bdi></a> is correct. Include the name of all modules in the ignoreModules configuration option EXCEPT from the two modules you wish to rotate.</p>
]]></description><link>https://forum.magicmirror.builders/post/9067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9067</guid><dc:creator><![CDATA[barnabycolby]]></dc:creator><pubDate>Thu, 08 Dec 2016 21:21:45 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 08 Dec 2016 17:02:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a><br />
Once I get home, i can post MY <em>CRUDE</em> hack for that…<br />
I am on pacific time, though. So give me at least 10 hours</p>
]]></description><link>https://forum.magicmirror.builders/post/9059</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9059</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Thu, 08 Dec 2016 17:02:08 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 08 Dec 2016 16:22:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pointpubmedia" aria-label="Profile: PointPubMedia">@<bdi>PointPubMedia</bdi></a> Don’t you need to just put the ones you don’t want to rotate in IgnoreModules? I haven’t installed it, but that looks like the intent…</p>
]]></description><link>https://forum.magicmirror.builders/post/9058</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9058</guid><dc:creator><![CDATA[frog]]></dc:creator><pubDate>Thu, 08 Dec 2016 16:22:55 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Thu, 08 Dec 2016 15:27:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barnabycolby" aria-label="Profile: barnabycolby">@<bdi>barnabycolby</bdi></a> will need some help with your module…</p>
<p dir="auto">How to use it to ONLY rotate 2 modules instead of all of them ?</p>
<p dir="auto">I have for the moment 10 modules displayed on the screen and would like to rotate only 1 of them with another one…</p>
]]></description><link>https://forum.magicmirror.builders/post/9055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9055</guid><dc:creator><![CDATA[PointPubMedia]]></dc:creator><pubDate>Thu, 08 Dec 2016 15:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Tue, 25 Oct 2016 19:18:42 GMT]]></title><description><![CDATA[<p dir="auto">Many thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/6896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6896</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 25 Oct 2016 19:18:42 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Tue, 25 Oct 2016 19:15:49 GMT]]></title><description><![CDATA[<p dir="auto">You need to modify your config.js file, a sample configuration that uses MMM-Carousel can be found <a href="https://github.com/barnabycolby/MMM-Carousel/blob/master/config.sample.js" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
]]></description><link>https://forum.magicmirror.builders/post/6895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6895</guid><dc:creator><![CDATA[barnabycolby]]></dc:creator><pubDate>Tue, 25 Oct 2016 19:15:49 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Mon, 24 Oct 2016 15:09:43 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/barnabycolby/MMM-Carousel" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/barnabycolby/MMM-Carousel</a></p>
<p dir="auto">Ok think i have working as only have one thing showing at a time… how can i define to specific things for specific times?</p>
]]></description><link>https://forum.magicmirror.builders/post/6803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6803</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 24 Oct 2016 15:09:43 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Sun, 23 Oct 2016 17:51:07 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, tell me can you not just download all the modules and put them in the directory manually rather than using terminal? Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/6737</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6737</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 23 Oct 2016 17:51:07 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Sun, 23 Oct 2016 17:49:55 GMT]]></title><description><![CDATA[<p dir="auto">Instructions can be found here: <a href="https://github.com/barnabycolby/MMM-Carousel" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/barnabycolby/MMM-Carousel</a></p>
<p dir="auto">The instructions should work on a Mac. In short, you want to clone the github repository into the modules directory and modify the magic mirror configuration to use the module.</p>
]]></description><link>https://forum.magicmirror.builders/post/6736</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6736</guid><dc:creator><![CDATA[barnabycolby]]></dc:creator><pubDate>Sun, 23 Oct 2016 17:49:55 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Sun, 23 Oct 2016 17:43:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi, how to install on Mac Book Air (have the mirror installed) just not clued up on the module installs via terminal… many thanks…</p>
]]></description><link>https://forum.magicmirror.builders/post/6733</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6733</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 23 Oct 2016 17:43:54 GMT</pubDate></item><item><title><![CDATA[Reply to Display modules in a carousel on Fri, 30 Sep 2016 19:31:24 GMT]]></title><description><![CDATA[<p dir="auto">I completely agree, I’ve opened a <a href="https://github.com/barnabycolby/MMM-Carousel/issues/5" target="_blank" rel="noopener noreferrer nofollow ugc">GitHub issue</a>, but as you can see from the previous conversation, it will take me a while to get around to it. Pull requests welcome :)</p>
]]></description><link>https://forum.magicmirror.builders/post/5589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/5589</guid><dc:creator><![CDATA[barnabycolby]]></dc:creator><pubDate>Fri, 30 Sep 2016 19:31:24 GMT</pubDate></item></channel></rss>
