<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[my raspberry pi 3 has a os installed but]]></title><description><![CDATA[<p dir="auto">everytime i try to change time and date it wont save and keep even though i push the right buttons and push save and reboot</p>
<p dir="auto">i bought this</p>
<p dir="auto">LoveRPi 8GB Raspbian NOOBS UHS-I MicroSD Card with SD Adapter for Raspberry Pi</p>
<p dir="auto">So i haveit plugged in but even without it plugged in it went straight to desktop so my pi already has a OS installed so why cant i make it save the time and date and why isnt this os working ???</p>
]]></description><link>https://forum.magicmirror.builders/topic/518/my-raspberry-pi-3-has-a-os-installed-but</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:22:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/518.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Aug 2016 00:13:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to my raspberry pi 3 has a os installed but on Tue, 23 Aug 2016 12:50:39 GMT]]></title><description><![CDATA[<p dir="auto">i got a new sd card and i installed it manually and everything was working it seemed for a while but when i went to work to work on this it showed wrong time but not date</p>
]]></description><link>https://forum.magicmirror.builders/post/3912</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3912</guid><dc:creator><![CDATA[bubbax666]]></dc:creator><pubDate>Tue, 23 Aug 2016 12:50:39 GMT</pubDate></item><item><title><![CDATA[Reply to my raspberry pi 3 has a os installed but on Mon, 22 Aug 2016 08:54:41 GMT]]></title><description><![CDATA[<p dir="auto">So you bought your Raspberry with a preinstalled sd card, right?</p>
<ul>
<li>
<p dir="auto">ListenpunktIs your raspberry connected to the internet automatically?</p>
</li>
<li>
<p dir="auto">ListenpunktDid you perform an update of your system afterwards? Please look at this instruction: <a href="https://www.raspberrypi.org/documentation/raspbian/updating.md" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/raspbian/updating.md</a></p>
</li>
</ul>
<p dir="auto">I installed the raspbian os manually (downloaded the latest Jessi image, flashed it to the sd card and performed the update described above. If I remember correctly I had some trouble with date/time before the updates, after the update everything is fine.</p>
]]></description><link>https://forum.magicmirror.builders/post/3869</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3869</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Mon, 22 Aug 2016 08:54:41 GMT</pubDate></item><item><title><![CDATA[Reply to my raspberry pi 3 has a os installed but on Fri, 19 Aug 2016 06:25:29 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/uploads/files/1471587925959-picsart_08-19-01.25.05.jpg" alt="0_1471587919856_PicsArt_08-19-01.25.05.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/3809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3809</guid><dc:creator><![CDATA[bubbax666]]></dc:creator><pubDate>Fri, 19 Aug 2016 06:25:29 GMT</pubDate></item><item><title><![CDATA[Reply to my raspberry pi 3 has a os installed but on Fri, 19 Aug 2016 06:20:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bubbax666" aria-label="Profile: bubbax666">@<bdi>bubbax666</bdi></a> All of the raspberry pi’s don’t have an RTC (<a href="https://en.wikipedia.org/wiki/Real-time_clock" target="_blank" rel="noopener noreferrer nofollow ugc">Real Time Clock</a>) on them.</p>
]]></description><link>https://forum.magicmirror.builders/post/3808</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3808</guid><dc:creator><![CDATA[jtyle6]]></dc:creator><pubDate>Fri, 19 Aug 2016 06:20:39 GMT</pubDate></item></channel></rss>
