<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PIR sensor does not work properly]]></title><description><![CDATA[<p dir="auto">Hi,<br />
since the last update, the MMM-PIR module does not work properly anymore. After a reboot it works a while. Then it takes very long until the mirror goes into the quiet mode, or he wakes up without a movement is registered. At the config was nothing changed and before the update everything worked perfectly. Someone an idea?</p>
<p dir="auto">Greeting Jörg</p>
]]></description><link>https://forum.magicmirror.builders/topic/5244/mmm-pir-sensor-does-not-work-properly</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:13:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5244.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Oct 2017 15:12:38 GMT</pubDate><ttl>60</ttl></channel></rss>
