<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t access from external browser. (RPI zero non-W)]]></title><description><![CDATA[<p dir="auto">I can’t access magic mirror running on my raspberry pi zero from my computer. In config I granted all IP’s by “ipWhitelist: []” but I dont think the problem is here because browser on my computer says " refused to connect". I don’t have installed apache2.</p>
]]></description><link>https://forum.magicmirror.builders/topic/5246/can-t-access-from-external-browser-rpi-zero-non-w</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 13:53:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5246.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Oct 2017 19:58:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 13:24:59 GMT]]></title><description><![CDATA[<p dir="auto">And the " marks your have posted are the wrong type as well.</p>
<p dir="auto">" " and not “ ”</p>
<p dir="auto">This is a common mistakes when using word editors to alter your config file, Smart Quotes I think it’s called, and is not accepted in the code.</p>
]]></description><link>https://forum.magicmirror.builders/post/29430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29430</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Thu, 12 Oct 2017 13:24:59 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 12:26:29 GMT]]></title><description><![CDATA[<p dir="auto">Thanks guys it is working now… I dont know why but in the morning it wasnt working and now it is :D I didnt change everything except rebooted rpi so that may be the answer</p>
]]></description><link>https://forum.magicmirror.builders/post/29429</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29429</guid><dc:creator><![CDATA[ImTheBadWolf]]></dc:creator><pubDate>Thu, 12 Oct 2017 12:26:29 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 11:51:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/imthebadwolf" aria-label="Profile: ImTheBadWolf">@<bdi>ImTheBadWolf</bdi></a></p>
<p dir="auto">So then, this SHOULD work:</p>
<p dir="auto"><a href="http://192.168.1.20:8085" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.1.20:8085</a>    substitute your Pi’s ip address</p>
<p dir="auto">You took the language OUT of your config???</p>
]]></description><link>https://forum.magicmirror.builders/post/29428</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29428</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 12 Oct 2017 11:51:37 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 11:36:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
var config = {<br />
address: “0.0.0.0”,<br />
port: 8085,<br />
//ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.112”, “192.168.1.102”],<br />
ipWhitelist: [],<br />
language: “”,<br />
timeFormat: 24,<br />
units: “metric”</p>
]]></description><link>https://forum.magicmirror.builders/post/29427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29427</guid><dc:creator><![CDATA[ImTheBadWolf]]></dc:creator><pubDate>Thu, 12 Oct 2017 11:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 11:19:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/imthebadwolf" aria-label="Profile: ImTheBadWolf">@<bdi>ImTheBadWolf</bdi></a> said in <a href="/post/29420">Can’t access from external browser. (RPI zero non-W)</a>:</p>
<p dir="auto">Thanks for your answer but that doesnt work either :(</p>
<p dir="auto">Can you post the beginning portion of your config?</p>
<pre><code>var config = {
	port: 8080,
        address: "0.0.0.0",
	ipWhitelist: [],
	language: "en",
	timeFormat: 12,
	units: "imperial",
]]></description><link>https://forum.magicmirror.builders/post/29425</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29425</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 12 Oct 2017 11:19:04 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 10:02:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> Yes</p>
]]></description><link>https://forum.magicmirror.builders/post/29424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29424</guid><dc:creator><![CDATA[ImTheBadWolf]]></dc:creator><pubDate>Thu, 12 Oct 2017 10:02:28 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 09:28:49 GMT]]></title><description><![CDATA[<p dir="auto">You are specifying the port as well in the address?</p>
<p dir="auto">like this :<br />
<a href="http://192.168.0.2:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://192.168.0.2:8080</a></p>
]]></description><link>https://forum.magicmirror.builders/post/29422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29422</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Thu, 12 Oct 2017 09:28:49 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Thu, 12 Oct 2017 04:24:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Thanks for your answer but that doesnt work either :(</p>
]]></description><link>https://forum.magicmirror.builders/post/29420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29420</guid><dc:creator><![CDATA[ImTheBadWolf]]></dc:creator><pubDate>Thu, 12 Oct 2017 04:24:43 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t access from external browser. (RPI zero non-W) on Wed, 11 Oct 2017 21:19:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/imthebadwolf" aria-label="Profile: ImTheBadWolf">@<bdi>ImTheBadWolf</bdi></a></p>
<p dir="auto">Try adding the address line as seen below, or “localhost”:</p>
        address: "0.0.0.0",
	port: 8080,
	ipWhitelist: [],
<p dir="auto">That should do it.</p>
]]></description><link>https://forum.magicmirror.builders/post/29418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29418</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 11 Oct 2017 21:19:55 GMT</pubDate></item></channel></rss>
