<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Basic Setup Question]]></title><description><![CDATA[<p dir="auto">Alright, so this may seem beyond simple, but I have to ask…</p>
<p dir="auto">I’ve run through the install on a Pi2. The install gave me no problems. I go through the final reboot and…I’m looking at the Raspbian GUI.</p>
<p dir="auto">Can anyone suggest the (clearly extremely obvious) step that I must have missed?</p>
]]></description><link>https://forum.magicmirror.builders/topic/526/basic-setup-question</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 23:25:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/526.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Aug 2016 16:25:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Basic Setup Question on Sat, 20 Aug 2016 18:42:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/merijeek" aria-label="Profile: Merijeek">@<bdi>Merijeek</bdi></a></p>
<p dir="auto">Actually, reran yet again and (possibly) looking better.</p>
<p dir="auto">Once my card reader stops acting oddly I’ll probably do a reinstall and start again from scratch. Maybe figure out where I went wrong.</p>
]]></description><link>https://forum.magicmirror.builders/post/3847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3847</guid><dc:creator><![CDATA[Merijeek]]></dc:creator><pubDate>Sat, 20 Aug 2016 18:42:45 GMT</pubDate></item><item><title><![CDATA[Reply to Basic Setup Question on Sat, 20 Aug 2016 18:22:17 GMT]]></title><description><![CDATA[<p dir="auto">No, I was actually using this setup guide here, which is less complete, but sure shows up in searches more often: <a href="https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide</a></p>
<p dir="auto">Now, however, I’ve gone through the setup you linked and and have ended up with:</p>
<p dir="auto">Check current Node installation …<br />
Node currently installed. Checking version number.<br />
Minimum Node version: v5.1.0<br />
Installed Node version: v6.4.0<br />
No Node.js upgrade nessecery.<br />
It seems like MagicMirror is already installed.<br />
To prevent overwriting, the installer will be aborted.<br />
Please rename the ~/MagicMirror folder and try again.</p>
<p dir="auto">If you want to upgrade your installation run git pull from the ~/MagicMirror directory.</p>
<p dir="auto">pi@pi:~ $ cd ~/MagicMirror<br />
pi@pi:~/MagicMirror $ git pull<br />
Already up-to-date.<br />
pi@pi:~/MagicMirror $ cd $HOME/MagicMirror<br />
pi@pi:~/MagicMirror $<br />
pi@pi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.0.0 start /home/pi/MagicMirror<br />
electron js/electron.js</p>
<p dir="auto">npm ERR! Linux 4.4.18-v7+<br />
npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”<br />
npm ERR! node v6.4.0<br />
npm ERR! npm  v3.10.3<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! magicmirror@2.0.0 start: <code>electron js/electron.js</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.<br />
npm ERR! Make sure you have the latest version of node.js and npm installed.<br />
npm ERR! If you do, this is most likely a problem with the magicmirror package,<br />
npm ERR! not with npm itself.<br />
npm ERR! Tell the author that this fails on your system:<br />
npm ERR!     electron js/electron.js<br />
npm ERR! You can get information on how to open an issue for this project with:<br />
npm ERR!     npm bugs magicmirror<br />
npm ERR! Or if that isn’t available, you can get their info via:<br />
npm ERR!     npm owner ls magicmirror<br />
npm ERR! There is likely additional logging output above.</p>
<p dir="auto">npm ERR! Please include the following file with any support request:<br />
npm ERR!     /home/pi/MagicMirror/npm-debug.log</p>
]]></description><link>https://forum.magicmirror.builders/post/3845</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3845</guid><dc:creator><![CDATA[Merijeek]]></dc:creator><pubDate>Sat, 20 Aug 2016 18:22:17 GMT</pubDate></item><item><title><![CDATA[Reply to Basic Setup Question on Sat, 20 Aug 2016 17:54:47 GMT]]></title><description><![CDATA[<p dir="auto">You mean, you miss the autostart feature?<br />
Did you follow the instructions mentioned in the <a href="http://read.me" target="_blank" rel="noopener noreferrer nofollow ugc">read.me</a>?</p>
<p dir="auto">Configuration: <a href="https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi</a><br />
Autostart: <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3844</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3844</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sat, 20 Aug 2016 17:54:47 GMT</pubDate></item></channel></rss>
