<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM restarts all the time after a few settings]]></title><description><![CDATA[<p dir="auto">Hello Guys i have a Problem i set up my Magic Mirror and it works fine and after the settings from this side: <a href="https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi</a></p>
<p dir="auto">my Raspi allways restarts after a while… sometimes 30seconds some times 5 minutes :( i cant define the problem better :(</p>
<p dir="auto">How can i log the crashes?  or someone have the same issues?</p>
<p dir="auto">I think its the power cable its an bad one… sometimes i see a flash on  the top right</p>
]]></description><link>https://forum.magicmirror.builders/topic/5299/mm-restarts-all-the-time-after-a-few-settings</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 03:33:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5299.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Oct 2017 20:07:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM restarts all the time after a few settings on Tue, 17 Oct 2017 20:25:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/terades" aria-label="Profile: terades">@<bdi>terades</bdi></a> said in <a href="/post/29711">MM restarts all the time after a few settings</a>:</p>
<p dir="auto">The “flash on the top right” is telling you that you have insufficient power going to the Pi. Standard power for the Pi is 5V 2.0A to 5V 2.5A. Are you using a power adapter or are you using a USB cable from a USB port?</p>
]]></description><link>https://forum.magicmirror.builders/post/29715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29715</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 17 Oct 2017 20:25:59 GMT</pubDate></item></channel></rss>
