<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing CSS icons?]]></title><description><![CDATA[<p dir="auto">Hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/paviro" aria-label="Profile: paviro">@<bdi>paviro</bdi></a>, are you missing some icons?<br />
<img src="/uploads/files/1462568549741-missing_css.png" alt="0_1462568506008_missing_css.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/53/missing-css-icons</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 00:48:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/53.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 May 2016 21:02:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Missing CSS icons? on Tue, 10 May 2016 08:13:37 GMT]]></title><description><![CDATA[<p dir="auto">Yeah, I hear you there. I’ve been trying to recreate the problems on my end but … no such luck. It runs flawlessly on my server, both as a super user as well as an unprivileged user. So something happened on his end with he switched things … maybe permissions … maybe something else. We’re trying to figure that out. You … you keep your focus on MM. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/386</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/386</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Tue, 10 May 2016 08:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Tue, 10 May 2016 08:11:23 GMT]]></title><description><![CDATA[<p dir="auto">I’m so happy <a class="plugin-mentions-user plugin-mentions-a" href="/user/paviro" aria-label="Profile: paviro">@<bdi>paviro</bdi></a> put all the effort in setting up this forum … 😂 If I had to deal with all the forum issues, MM would no longer be maintained. ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/385</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/385</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Tue, 10 May 2016 08:11:23 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Mon, 09 May 2016 19:46:31 GMT]]></title><description><![CDATA[<p dir="auto">Myah, you have slow connections somewhere. From the log you sent me, I want to say the socket isn’t responding fast enough … why, who knows. Still need investigating …</p>
<p dir="auto"><img src="/uploads/files/1462823134717-notispin.png" alt="0_1462823096296_NotiSpin.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I had to force refresh the page, then let it sit there for a bit before the notification icon popped up again, as well as the ‘Unread’ notification. Definitely some delay/timeout somewhere.</p>
]]></description><link>https://forum.magicmirror.builders/post/361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/361</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 09 May 2016 19:46:31 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:57:59 GMT]]></title><description><![CDATA[<p dir="auto">Looking at stylesheet.css, there’s a big portion of it that’s mangled. The content: “” line is simply a square box. That tells me something didn’t translate right, either when you originally installed it, or when files were copied over, possibly from a different OS that mangled the file types …</p>
]]></description><link>https://forum.magicmirror.builders/post/271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/271</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Fri, 06 May 2016 21:57:59 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:57:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> node is serving the pages :/ nginx only acts as a proxy but I will send you its logs via email.</p>
]]></description><link>https://forum.magicmirror.builders/post/270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/270</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Fri, 06 May 2016 21:57:27 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:52:18 GMT]]></title><description><![CDATA[<p dir="auto">That’s node logs. You need the actual web server logs, whatever is serving those the pages …</p>
]]></description><link>https://forum.magicmirror.builders/post/269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/269</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Fri, 06 May 2016 21:52:18 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:44:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> I can access the node logs, yeah.</p>
<p dir="auto">The only thing it logged in the last hours is:</p>
<pre><code>6/5 07:30 [27307] - error: /sitemap/pages.xml
 undefined
6/5 09:45 [27307] - error: /sitemap/topics.1.xml
 undefined
6/5 18:32 [27307] - error: /sitemap/topics.1.xml
 undefined
6/5 19:41 [27307] - error: /sitemap/categories.xml
 undefined
6/5 22:19 [27307] - error: /sitemap/pages.xml
 undefined
]]></description><link>https://forum.magicmirror.builders/post/268</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/268</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Fri, 06 May 2016 21:44:29 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:41:38 GMT]]></title><description><![CDATA[<p dir="auto">Do you have access to the actual web server logs? That may shed some light, particularly in the error logs.</p>
]]></description><link>https://forum.magicmirror.builders/post/267</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/267</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Fri, 06 May 2016 21:41:38 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:41:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> Same thought but no idea why the content is missing… Will check the next couple of days and may open an issue on their GitHub.</p>
]]></description><link>https://forum.magicmirror.builders/post/266</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/266</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Fri, 06 May 2016 21:41:01 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:39:46 GMT]]></title><description><![CDATA[<p dir="auto">I see that when I’m on my phone. I believe that’s a notification popup but it’s missing the contents … whatever it may be.</p>
]]></description><link>https://forum.magicmirror.builders/post/265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/265</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Fri, 06 May 2016 21:39:46 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:36:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> Any idea why that could be? There also is this strange white box sometimes when there are new posts in a topic:<br />
<img src="/uploads/files/1462570558186-img_0231.jpg" alt="0_1462570536435_IMG_0231.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/264</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Fri, 06 May 2016 21:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:30:37 GMT]]></title><description><![CDATA[<p dir="auto">Looks like the content that’s supposed to be there got mangled in the CSS file:<br />
<img src="/uploads/files/1462570228674-content.png" alt="0_1462570185390_content.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/263</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Fri, 06 May 2016 21:30:37 GMT</pubDate></item><item><title><![CDATA[Reply to Missing CSS icons? on Fri, 06 May 2016 21:19:27 GMT]]></title><description><![CDATA[<p dir="auto">Yes already noticed that but no idea why…<br />
Will check once I have time.</p>
]]></description><link>https://forum.magicmirror.builders/post/262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/262</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Fri, 06 May 2016 21:19:27 GMT</pubDate></item></channel></rss>
