<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to apply changes on the MM other than reboot? ftp?]]></title><description><![CDATA[<p dir="auto">Is it possible to install ftp on the raspberry to access and edit the config files etc easier on your computer, or you’re stuck with making all the changes through ssh.<br />
After changes how do you apply the settings, what I’ve done so far is reboot the Rpi  :(<br />
Using Raspberry Pi 1 Model B.</p>
]]></description><link>https://forum.magicmirror.builders/topic/5320/how-to-apply-changes-on-the-mm-other-than-reboot-ftp</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 23:04:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5320.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Oct 2017 20:33:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 22:41:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noorm91" aria-label="Profile: noorm91">@<bdi>noorm91</bdi></a> said in <a href="/post/29903">How to apply changes on the MM other than reboot? ftp?</a>:</p>
<p dir="auto">Thanks again for trying, I will look it up tomorrow and try before reinstall.</p>
<p dir="auto">Ok, keep me posted. I’ve never used anything other than a Pi 3 B or better, nor have I ever ran MM as node server only, but I am interested in knowing how you get it running.</p>
]]></description><link>https://forum.magicmirror.builders/post/29905</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29905</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 20 Oct 2017 22:41:43 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 21:55:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
Thanks again for trying, I will look it up tomorrow and try before reinstall. I think it is best to get a clean installation after everything I’ve tested now, <a href="http://start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">start.sh</a> might even be wrong at this moment. All I get when I reboot is localhost:8080 error something…</p>
<p dir="auto">This is what I got after those commands though, npm start gives me electron error, I read somewhere before about rpi zero/1 can´t handle electron.js somehow I think.</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 nohup npm start &amp;<br />
[1] 890<br />
pi@raspberrypi:~/MagicMirror $ nohup: ignoring input and appending output to ‘nohup.out’<br />
^C<br />
[1]+  Exit 1                  DISPLAY=:0 nohup npm start<br />
pi@raspberrypi:~/MagicMirror $ ^C<br />
pi@raspberrypi:~/MagicMirror $<br />
pi@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.1.0 start /home/pi/MagicMirror<br />
electron js/electron.js</p>
<p dir="auto">/home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory</p>
<p dir="auto">npm ERR! Linux 4.4.34+<br />
npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”<br />
npm ERR! node v4.2.1<br />
npm ERR! npm  v2.14.7<br />
npm ERR! file sh<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! errno ENOENT<br />
npm ERR! syscall spawn<br />
npm ERR! magicmirror@2.1.0 start: <code>electron js/electron.js</code><br />
npm ERR! spawn ENOENT<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.<br />
npm ERR! This is most likely a problem with the magicmirror package,<br />
npm ERR! not with npm itself.<br />
npm ERR! Tell the author that this fails on your system:<br />
npm ERR!     electron js/electron.js<br />
npm ERR! You can get their info via:<br />
npm ERR!     npm owner ls magicmirror<br />
npm ERR! There is likely additional logging output above.</p>
<p dir="auto">npm ERR! Please include the following file with any support request:<br />
npm ERR!     /home/pi/MagicMirror/npm-debug.log</p>
]]></description><link>https://forum.magicmirror.builders/post/29903</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29903</guid><dc:creator><![CDATA[noorm91]]></dc:creator><pubDate>Fri, 20 Oct 2017 21:55:58 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 21:41:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noorm91" aria-label="Profile: noorm91">@<bdi>noorm91</bdi></a></p>
<p dir="auto">Ok, there is a command specific to starting server only I think. Lemme see if I can find it for you before you reinstall anything.</p>
<p dir="auto"><strong>EDIT</strong></p>
<p dir="auto">I think this is what you need<br />
<a href="https://forum.magicmirror.builders/topic/2321/magicmirror-fails-to-start-after-fresh-install">https://forum.magicmirror.builders/topic/2321/magicmirror-fails-to-start-after-fresh-install</a></p>
]]></description><link>https://forum.magicmirror.builders/post/29900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29900</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 20 Oct 2017 21:41:33 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 21:10:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
Yes Rpi zero and 1 only supports server only at this moment. What I’ve figured out so far and no I’m using Tera Term (almost like PuTTY) accessing it with SSH. But I connected my mouse and keyboard to find the mouse cursor, so I saw the X button on the Midori browser and closed it.</p>
]]></description><link>https://forum.magicmirror.builders/post/29898</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29898</guid><dc:creator><![CDATA[noorm91]]></dc:creator><pubDate>Fri, 20 Oct 2017 21:10:35 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 21:07:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noorm91" aria-label="Profile: noorm91">@<bdi>noorm91</bdi></a> said in <a href="/post/29894">How to apply changes on the MM other than reboot? ftp?</a>:</p>
<p dir="auto">I get electron.js failed at MM start script when using npm start.</p>
<p dir="auto">Wait, are you using VNC, because you CAN use npm start using that. Are you running server only?</p>
]]></description><link>https://forum.magicmirror.builders/post/29897</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29897</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 20 Oct 2017 21:07:02 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 21:04:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
Ok thank you! I get electron.js failed at MM start script when using npm start.<br />
I will try reinstalling the MM instead tomorrow!</p>
]]></description><link>https://forum.magicmirror.builders/post/29894</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29894</guid><dc:creator><![CDATA[noorm91]]></dc:creator><pubDate>Fri, 20 Oct 2017 21:04:20 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 20:59:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noorm91" aria-label="Profile: noorm91">@<bdi>noorm91</bdi></a></p>
<p dir="auto">Ok, this is how I do it.<br />
While viewing the Pi via VNC, I press the <code>Alt</code> key<br />
This drops a menu bar down at the top of MM.<br />
You may not see your mouse/cursor until you move it all the way up into the menu bar.<br />
The far left menu has <code>Quit</code> in it.</p>
<p dir="auto">Relaunch the way you normally would launch MM</p>
]]></description><link>https://forum.magicmirror.builders/post/29891</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29891</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 20 Oct 2017 20:59:24 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 21:00:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
I followed this guide <a href="https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/8?page=1">https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/8?page=1</a> everything went pretty well mostly…but I still haven’t figured out how to quit and relaunch the MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/29890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29890</guid><dc:creator><![CDATA[noorm91]]></dc:creator><pubDate>Fri, 20 Oct 2017 21:00:04 GMT</pubDate></item><item><title><![CDATA[Reply to How to apply changes on the MM other than reboot? ftp? on Fri, 20 Oct 2017 20:51:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/noorm91" aria-label="Profile: noorm91">@<bdi>noorm91</bdi></a></p>
<p dir="auto">There’s VNC that’s standard  with Pi3 and Jessie. I don’t know about the Pi1’s abilities. “Putty” seems to be a favorite of many although I’ve never used it. At least with VNC, you can send and receive files to the Pi, edit them locally, and send them back, but I would only do that for major changes or at least large changes. If I were just adding a module for example, I would just do it remotely. It’s a personal preference.</p>
<p dir="auto">Assuming you’re talking about applying changes to the MM software, you can simply quit MM, make your changes and relaunch, no?</p>
]]></description><link>https://forum.magicmirror.builders/post/29889</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/29889</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 20 Oct 2017 20:51:47 GMT</pubDate></item></channel></rss>
