<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Setting up Magic Mirror remotely?]]></title><description><![CDATA[<p dir="auto">Today I tried setting up my pi remotely from a laptop, It went thru a lot of stuff then all of a sudden gave two warnings, something about something needed loaded with -g. I didnt screen capture it. Do I have to have the hdmi screen hooked up and do it from there, or is doing it remotely ok?</p>
]]></description><link>https://forum.magicmirror.builders/topic/5358/setting-up-magic-mirror-remotely</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 09:41:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5358.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Oct 2017 08:11:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Sun, 25 Mar 2018 03:43:33 GMT]]></title><description><![CDATA[<p dir="auto">NEVER MIND…FIGURED IT OUT :)</p>
]]></description><link>https://forum.magicmirror.builders/post/37402</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37402</guid><dc:creator><![CDATA[Mikgabo]]></dc:creator><pubDate>Sun, 25 Mar 2018 03:43:33 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Sun, 25 Mar 2018 03:19:41 GMT]]></title><description><![CDATA[<p dir="auto">Hey guys,</p>
<p dir="auto">Noob question…</p>
<p dir="auto">So, I’m running MM2 on my Pi Zero W and can’t figure out home to get to my config.js through terminal.  Can someone help me out???</p>
<p dir="auto">Cheers,<br />
Mike</p>
]]></description><link>https://forum.magicmirror.builders/post/37401</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37401</guid><dc:creator><![CDATA[Mikgabo]]></dc:creator><pubDate>Sun, 25 Mar 2018 03:19:41 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 07:21:14 GMT]]></title><description><![CDATA[<p dir="auto">@Sean It ended up being one of the changes I made to set up the pi for the screensaver edit. I did try passwd though. thanks eveyone. I got it up and running. I have another post for a module problem, once I get that figured out, I will start on the hardware.</p>
]]></description><link>https://forum.magicmirror.builders/post/30243</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30243</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 07:21:14 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 07:11:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a><br />
<code>SSH is enabled and the default password for the ‘pi’ user has not been changed. This is a security risk - please login as the ‘pi’ user and type passwd to set a new password.</code><br />
It means as written. Change your password with command <code>passwd</code>.<br />
just try <code>passwd</code> in your terminal.</p>
]]></description><link>https://forum.magicmirror.builders/post/30242</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30242</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 27 Oct 2017 07:11:28 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 02:51:30 GMT]]></title><description><![CDATA[<p dir="auto">fixed the light display thing by rebooting with hdmi unplugged, then repluging it in, then rebooting, but the ssh message still there</p>
]]></description><link>https://forum.magicmirror.builders/post/30238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30238</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 02:51:30 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 02:22:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a></p>
<p dir="auto">I’ve never encountered that before. Maybe, revert the changes you just made, get your mirror running, then try them again, 1 at a time</p>
]]></description><link>https://forum.magicmirror.builders/post/30236</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30236</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 27 Oct 2017 02:22:30 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 02:16:34 GMT]]></title><description><![CDATA[<p dir="auto">I got it to work, but then I went through the pi setup stuff to turn on the screensaver and wifi sleep, now when i tried to reboot, it says</p>
<p dir="auto">[FAILED] Failed to start Light Display Manager<br />
SSH is enabled and the default password for the ‘pi’ user has not been changed. This is a security risk - please login as the ‘pi’ user and type passwd to set a new password.<br />
pi@raspberrypi:  $</p>
<p dir="auto">How do i get it to continue to the desktop screen?</p>
]]></description><link>https://forum.magicmirror.builders/post/30235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30235</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 02:16:34 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 01:03:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a></p>
<p dir="auto">Look at the bottom left of my post. Click on <strong>Create a working config</strong></p>
]]></description><link>https://forum.magicmirror.builders/post/30231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30231</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 27 Oct 2017 01:03:02 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 01:00:58 GMT]]></title><description><![CDATA[<p dir="auto">ok read some on the repository, was able to run the serveronly and got this<br />
Magic Mirror2<br />
Please create a config file.<br />
See README for more information.<br />
If you get this message while your config file is already<br />
created, your config file probably contains an error.<br />
Use a JavaScript linter to validate your file.</p>
<p dir="auto">what next?</p>
]]></description><link>https://forum.magicmirror.builders/post/30230</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30230</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 01:00:58 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 00:38:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a> said in <a href="/post/30228">Setting up Magic Mirror remotely?</a>:</p>
<p dir="auto">throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)</p>
<p dir="auto">Terminal is telling what happened and you what to do here.</p>
<p dir="auto">Go into your MagicMirror folder, then into the node_modules folder, then DELETE the electron folder.</p>
<p dir="auto">Then run <code>npm install</code> again in the MagicMirror directory</p>
]]></description><link>https://forum.magicmirror.builders/post/30229</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30229</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 27 Oct 2017 00:38:55 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 00:23:29 GMT]]></title><description><![CDATA[<p dir="auto">Went back to the website and read, and found something about npm install, so ran that, it looked like it installed something, then ran npm start again and got:</p>
<p dir="auto">magicmirror@2.1.3 start /home/pi/MagicMirror<br />
sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a><br />
/home/pi/MagicMirror/node_modules/electron/index.js:9<br />
throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)<br />
^<br />
Error: Electron failed to install correctly, please delete node_modules/electron and try installing again<br />
at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)<br />
at Module._compile (module.js:570:32)<br />
at Object.Module._extensions…js (module.js:579:10)<br />
at Module.load (module.js:487:32)<br />
at tryModuleLoad (module.js:446:12)<br />
at Function.Module._load (module.js:438:3)<br />
at Module.require (module.js:497:17)<br />
at require (internal/module.js:20:19)<br />
at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)<br />
npm ERR! Linux 4.9.35-v7+<br />
npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “start”<br />
npm ERR! node v6.11.5<br />
npm ERR! npm  v3.10.10<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! magicmirror@2.1.3 start: <code>sh run-start.sh</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.1.3 start script ‘sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>’.<br />
npm ERR! Make sure you have the latest version of node.js and npm installed.<br />
npm ERR! If you do, this is most likely a problem with the magicmirror package,<br />
npm ERR! not with npm itself.<br />
npm ERR! Tell the author that this fails on your system:<br />
npm ERR!     sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a><br />
npm ERR! You can get information on how to open an issue for this project with:<br />
npm ERR!     npm bugs magicmirror<br />
npm ERR! Or if that isn’t available, you can get their info via:<br />
npm ERR!     npm owner ls magicmirror<br />
npm ERR! There is likely additional logging output above.<br />
npm ERR! Please include the following file with any support request:<br />
npm ERR!     /home/pi/MagicMirror/npm-debug.log<br />
pi@raspberrypi:~/MagicMirror $</p>
<p dir="auto">npm-debug.log<br />
0 info it worked if it ends with ok<br />
1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]<br />
2 info using npm@3.10.10<br />
3 info using node@v6.11.5<br />
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]<br />
5 info lifecycle magicmirror@2.1.3~prestart: magicmirror@2.1.3<br />
6 silly lifecycle magicmirror@2.1.3~prestart: no script for prestart, continuing<br />
7 info lifecycle magicmirror@2.1.3~start: magicmirror@2.1.3<br />
8 verbose lifecycle magicmirror@2.1.3~start: unsafe-perm in lifecycle true<br />
9 verbose lifecycle magicmirror@2.1.3~start: PATH: /usr/lib/node_modules/npm/bi$<br />
10 verbose lifecycle magicmirror@2.1.3~start: CWD: /home/pi/MagicMirror<br />
11 silly lifecycle magicmirror@2.1.3~start: Args: [ ‘-c’, 'sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> "dev$<br />
12 silly lifecycle magicmirror@2.1.3~start: Returned: code: 1  signal: null<br />
13 info lifecycle magicmirror@2.1.3~start: Failed to exec start script<br />
14 verbose stack Error: magicmirror@2.1.3 start: <code>sh run-start.sh "dev"</code><br />
14 verbose stack Exit status 1<br />
14 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib$<br />
14 verbose stack     at emitTwo (events.js:106:13)<br />
14 verbose stack     at EventEmitter.emit (events.js:191:7)<br />
[ Read 45 lines ]</p>
]]></description><link>https://forum.magicmirror.builders/post/30228</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30228</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 00:23:29 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 00:08:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a> said in <a href="/post/30225">Setting up Magic Mirror remotely?</a>:</p>
<p dir="auto">tried starting npm remotely got this:<br />
pi@raspberrypi:~ $ npm start</p>
<p dir="auto">You would need to <code>cd MagicMirror</code>  to change into your MagicMirror directory first, then run <code>npm start</code></p>
]]></description><link>https://forum.magicmirror.builders/post/30227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30227</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 27 Oct 2017 00:08:39 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Fri, 27 Oct 2017 00:00:41 GMT]]></title><description><![CDATA[<p dir="auto">tried again today with the hdmi screen, it got to where it said something about it was loading a file that had 715 at the end and froze. so restarted removed the folder, and restarted installing remotely. it got to loading depandencies and gave me this :</p>
<p dir="auto">Installing dependencies …<br />
npm WARN prefer global coffee-script@1.10.0 should be installed with -g<br />
npm WARN prefer global jsonlint@1.6.2 should be installed with -g</p>
<p dir="auto">uws@0.14.5 install /home/pi/MagicMirror/node_modules/uws<br />
node-gyp rebuild &gt; build_log.txt 2&gt;&amp;1 || exit 0<br />
Unable to install dependencies!</p>
<p dir="auto">tried starting npm remotely got this:</p>
<p dir="auto">pi@raspberrypi:~ $ npm start<br />
npm ERR! path /home/pi/package.json<br />
npm ERR! code ENOENT<br />
npm ERR! errno -2<br />
npm ERR! syscall open<br />
npm ERR! enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’<br />
npm ERR! enoent This is most likely not a problem with npm itself<br />
npm ERR! enoent and is related to npm not being able to find a file.<br />
npm ERR! enoent<br />
npm ERR!     /home/pi/npm-debug.log</p>
<p dir="auto">tried starting from the hdmi screen same thing.</p>
<p dir="auto">tried starting from with the magicmirror folder, got this:</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm start</p>
^<br />
npm ERR!<br />
pi@raspberrypi:~/MagicMirror $<br />
Can anyone point me in the direction to correct? I have already upgraded Node.js so i know it cant be that.</p>
<p dir="auto">npm-bug.log:<br />
1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]<br />
11 silly lifecycle magicmirror@2.1.3~start: Args: [ ‘-c’, ‘sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>’ ]<br />
14 verbose stack Error: magicmirror@2.1.3 start: <code>sh run-start.sh</code><br />
]]></description><link>https://forum.magicmirror.builders/post/30225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30225</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 00:00:41 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Thu, 26 Oct 2017 08:20:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yawns" aria-label="Profile: yawns">@<bdi>yawns</bdi></a> Via VNC, It froze when it did the two warnings. the pi prompt never returned. I just shut it down. Had to leave. Will try again when I have time, next time via the hdmi screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/30175</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30175</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Thu, 26 Oct 2017 08:20:51 GMT</pubDate></item><item><title><![CDATA[Reply to Setting up Magic Mirror remotely? on Thu, 26 Oct 2017 08:13:54 GMT]]></title><description><![CDATA[<p dir="auto">Did you access your PI via ssh (putty for example)? Or did you use vnc to actually see the screen?<br />
Both ways should be fine for installation, only running the MagicMirror via ssh is a bit tricky as you have to tell MagicMirror which display to use.</p>
]]></description><link>https://forum.magicmirror.builders/post/30174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30174</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Thu, 26 Oct 2017 08:13:54 GMT</pubDate></item></channel></rss>
