<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[added new module&#x2F;not showing up]]></title><description><![CDATA[<p dir="auto">Added the module to the config file, it shows in the list below that is there, but says no helper, What is this and how do I fix it?</p>
<p dir="auto">Starting MagicMirror: v2.1.3<br />
Loading config …<br />
Loading module helpers …<br />
No helper found for module: alert.<br />
Initializing new module helper …<br />
Module helper loaded: updatenotification<br />
No helper found for module: clock.<br />
Module helper loaded: calendar<br />
No helper found for module: compliments.<br />
No helper found for module: MMM-JEOPARDY.<br />
No helper found for module: currentweather.<br />
No helper found for module: weatherforecast.<br />
Module helper loaded: newsfeed<br />
All module helpers loaded.<br />
Starting server on port 8080 …<br />
Server started …<br />
Connecting socket for: updatenotification<br />
Connecting socket for: calendar<br />
Starting node helper for: calendar<br />
Connecting socket for: newsfeed<br />
Starting module: newsfeed<br />
Sockets connected &amp; modules started …</p>
<p dir="auto">Ready to go! Please point your browser to: <a href="http://localhost:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080</a><br />
Create new calendar fetcher for url: <a href="http://www.calendarlabs.com/templates/ical/US-Holidays.ics" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.calendarlabs.com/templates/ical/US-Holidays.ics</a> - Interval: 300000<br />
Create new news fetcher for url: <a href="http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml</a> - Interval: 300000</p>
]]></description><link>https://forum.magicmirror.builders/topic/5371/added-new-module-not-showing-up</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:25:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5371.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Oct 2017 03:41:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Sat, 28 Oct 2017 04:28:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Thanks everyone, got it all together, got the New York Times feed at the bottom, interesting quotes in the middle. Time, date, calendar on left top. Weather top right. Now on to find a screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/30273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30273</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Sat, 28 Oct 2017 04:28:51 GMT</pubDate></item><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Sat, 28 Oct 2017 00:35:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a></p>
<p dir="auto">First, when you do post your code here, please post in a code block so that it is easier to read. My old eyes can’t look at that!</p>
<p dir="auto">Second, I don’t use the stock module. However, I did read recently that there was some problem with it. A forum search found this</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4806/stock-module-problem">https://forum.magicmirror.builders/topic/4806/stock-module-problem</a></p>
]]></description><link>https://forum.magicmirror.builders/post/30272</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30272</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 28 Oct 2017 00:35:26 GMT</pubDate></item><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Fri, 27 Oct 2017 23:55:25 GMT]]></title><description><![CDATA[<p dir="auto">ok got that one to work, now trying to get stocks put in. the following is the config file,<br />
/* Magic Mirror Config Sample<br />
*</p>
<ul>
<li>By Michael Teeuw <a href="http://michaelteeuw.nl" target="_blank" rel="noopener noreferrer nofollow ugc">http://michaelteeuw.nl</a></li>
<li>MIT Licensed.</li>
<li></li>
<li>For more information how you can configurate this file</li>
<li>See <a href="https://github.com/MichMich/MagicMirror#configuration" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror#configuration</a></li>
<li></li>
</ul>
<p dir="auto">*/</p>
<p dir="auto">var config = {<br />
address: “localhost”, // Address to listen on, can be:<br />
// - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface<br />
// - another specific IPv4/6 to listen on a specific interface<br />
// - “”, “0.0.0.0”, “::” to listen on any interface<br />
// Default, when address config is left out, is “localhost”<br />
port: 8080,<br />
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses<br />
// or add a specific IPv4 of 192.168.1.5 :<br />
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],<br />
// or IPv4 range of 192.168.3.0 --&gt; 192.168.3.15 use CIDR format :<br />
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],</p>
<pre><code>language: "en",
timeFormat: 24,
units: "imperial",
		module: "alert",
		module: "updatenotification",
		position: "top_bar"
		module: "clock",
		position: "top_left"
<p dir="auto">{<br />
module: “calendar”,<br />
header: “US Holidays”,<br />
position: “top_left”,<br />
config: {<br />
calendars: [<br />
{<br />
symbol: "calendar-check-o ",<br />
url: “webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics”<br />
}<br />
]<br />
}<br />
},</p>
module: “currentweather”,<br />
position: “top_right”,<br />
config: {<br />
locationID: “”,  //ID from <a href="http://www.openweathermap.org/help/city_list.txt" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.openweathermap.org/help/city_list.txt</a><br />
appid: “6ed9d867d3ba972c013edecdef1e685a”<br />
}<br />
},<br />
{<br />
module: “weatherforecast”,<br />
header: “Weather Forecast”,<br />
config: {<br />
}<br />
},<br />
{<br />
module: ‘stocks’,<br />
position: ‘middle_center’,<br />
config: {<br />
stocks: ‘.DJI,MSFT,AAPL,GOOG,INTC,CICS,TSLA,FB’, // stock symbols<br />
updateInterval: 37000 // update interval in milliseconds<br />
}<br />
},<br />
{<br />
module: “newsfeed”,<br />
position: “bottom_bar”,<br />
config: {<br />
feeds: [<br />
{<br />
title: “New York Times”,<br />
url: “<a href="http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml</a>”<br />
}<br />
],<br />
showSourceTitle: true,<br />
showPublishDate: true<br />
}<br />
},<br />
]</p>
<p dir="auto">};</p>
<p dir="auto">[<br />
{<br />
position: “top_right”,	// This can be any of the regions.<br />
// Best results in left or right regions.<br />
config: {<br />
// See ‘Configuration options’ for more information.<br />
locationID: “”, //Location ID from <a href="http://openweathermap.org/help/city_list.txt" target="_blank" rel="noopener noreferrer nofollow ugc">http://openweathermap.org/help/city_list.txt</a><br />
appid: “abcde12345abcde12345abcde12345ab” <a href="//openweathermap.org" target="_blank" rel="noopener noreferrer nofollow ugc">//openweathermap.org</a> API key.<br />
}<br />
}<br />
]</p>
<p dir="auto">/*************** DO NOT EDIT THE LINE BELOW ***************/<br />
if (typeof module !== “undefined”) {module.exports = config;}</p>
<p dir="auto">And the node start<br />
Module helper loaded: stocks<br />
Connecting socket for: stocks<br />
stocks helper started …<br />
Create new news fetcher for url: <a href="http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml</a> - Interval: 300000<br />
. it looks like it has started the stock helper and socket, but not showing on node screen, I changed the position to middle_center</p>
]]></description><link>https://forum.magicmirror.builders/post/30271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30271</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 23:55:25 GMT</pubDate></item><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Fri, 27 Oct 2017 11:34:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a></p>
<p dir="auto">Ok, weather won’t show without an API key, just so you know. The directions are in the readme for the module</p>
]]></description><link>https://forum.magicmirror.builders/post/30253</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30253</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 27 Oct 2017 11:34:54 GMT</pubDate></item><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Fri, 27 Oct 2017 11:32:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> no the weather module. used the link on the main page , I copied the code and inserted it in the config.js. and its not showing up. I can copy it and put it on here later tonight.<br />
But I think i dropped the jeopardy one in there to, so i will check and up date when I get back to that project tonight.</p>
]]></description><link>https://forum.magicmirror.builders/post/30252</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30252</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 11:32:22 GMT</pubDate></item><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Fri, 27 Oct 2017 11:14:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a> said in <a href="/post/30244">added new module/not showing up</a>:</p>
<p dir="auto">That module is not showing up on the screen though. I put the code in the config file with the {  } on either end.</p>
<p dir="auto">Are you talking about MMM-JEOPARDY? I just checked it and it’s working  normally. I did a minor fix at the same time so <code>git pull</code> in the MagicMirror/modules/MMM-Jeopardy directory for that update. The entire config.js entry for MMM-JEOPARDY is as follows:</p>
<pre><code>{
    module: 'MMM-JEOPARDY',
    position: 'top_left',                  // Works well anywhere
	    useHeader: false,              // true if you want a header
            header: "This is Jeopardy!",   // Any text you want
	    maxWidth: "250px",             // Stretch or constrain according to region
	    animationSpeed: 3000,          // New clue fades in and out
<p dir="auto">Pay particular attention to the last <code>}</code> It has a comma after it</p>
]]></description><link>https://forum.magicmirror.builders/post/30249</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30249</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 27 Oct 2017 11:14:28 GMT</pubDate></item><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Fri, 27 Oct 2017 07:23:20 GMT]]></title><description><![CDATA[<p dir="auto">@Sean That module is not showing up on the screen though. I put the code in the config file with the {  } on either end. so will have to look into it further when I have time.</p>
]]></description><link>https://forum.magicmirror.builders/post/30244</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30244</guid><dc:creator><![CDATA[navyvette87]]></dc:creator><pubDate>Fri, 27 Oct 2017 07:23:20 GMT</pubDate></item><item><title><![CDATA[Reply to added new module&#x2F;not showing up on Fri, 27 Oct 2017 07:07:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/navyvette87" aria-label="Profile: navyvette87">@<bdi>navyvette87</bdi></a><br />
You don’t need to mind <code>No helper found for module</code>. It means just that module has no <code>node_helper.js</code> to execute. And usually, that is not a bug unless developer made some mistake. (some modules work enough without <code>node_helper.js</code>)</p>
]]></description><link>https://forum.magicmirror.builders/post/30241</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30241</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 27 Oct 2017 07:07:56 GMT</pubDate></item></channel></rss>
