<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Clock , weather module problems]]></title><description><![CDATA[<p dir="auto">I set the time format to 24 in the beginning, but it still goes to the 12 format on both sides. Now my question is how to change both of them to 24 and since I already have a clock module on the left I don’t know what it needs to be on the right in weather ( it even goes 1 hour and 30 min faster than actual clock so I have no idea whats wrong with it ) . <img src="/assets/uploads/files/1509200591812-22883241_1924553824461575_1424527918_n.jpg" alt="0_1509200607720_22883241_1924553824461575_1424527918_n.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/5374/clock-weather-module-problems</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 18:18:45 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5374.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Oct 2017 14:23:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Clock , weather module problems on Sat, 28 Oct 2017 20:58:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/akzariel" aria-label="Profile: Akzariel">@<bdi>Akzariel</bdi></a> said in <a href="/post/30282">Clock , weather module problems</a>:</p>
<p dir="auto">the time format is still pm/am</p>
<p dir="auto">Well, the module is supposed to default to your config.js <code>timeFormat: 24,</code> as I pointed out in the picture earlier. Have you set that to 24? I just changed 3 different machines and they all displayed the 24 hour time format when that is set to 24</p>
]]></description><link>https://forum.magicmirror.builders/post/30284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30284</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 28 Oct 2017 20:58:15 GMT</pubDate></item><item><title><![CDATA[Reply to Clock , weather module problems on Sat, 28 Oct 2017 16:20:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> No, sir I didn’t … I just corrected that currentweather problem with the code you gave me , the time format is still pm/am</p>
]]></description><link>https://forum.magicmirror.builders/post/30282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30282</guid><dc:creator><![CDATA[Akzariel]]></dc:creator><pubDate>Sat, 28 Oct 2017 16:20:12 GMT</pubDate></item><item><title><![CDATA[Reply to Clock , weather module problems on Sat, 28 Oct 2017 15:44:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/akzariel" aria-label="Profile: Akzariel">@<bdi>Akzariel</bdi></a></p>
<p dir="auto">I assume you corrected the time format?</p>
<p dir="auto">All the configuration options available for the currentweather module are at the bottom of the readme, here.<br />
<a href="https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather</a>.</p>
<p dir="auto">I believe that adding this to the currentweather entry in your config will do what you are asking.<br />
<code>onlyTemp: true,</code></p>
<p dir="auto">If you want to target just the sunset timer and icon you would have to do that via custom.css. It’s not recommended that you edit the currentweather.js.</p>
<p dir="auto">In the future, if you would post your code in a code block instead of a picture, it would be easier for others to see and to help you.</p>
<p dir="auto">Cheers, mate.</p>
]]></description><link>https://forum.magicmirror.builders/post/30280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30280</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 28 Oct 2017 15:44:50 GMT</pubDate></item><item><title><![CDATA[Reply to Clock , weather module problems on Sat, 28 Oct 2017 15:24:15 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1509204243760-ef61ae8bda7bf4ad8cd917115365bd86.png" alt="0_1509204259917_ef61ae8bda7bf4ad8cd917115365bd86.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The whole config.js file , sir :)</p>
]]></description><link>https://forum.magicmirror.builders/post/30278</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30278</guid><dc:creator><![CDATA[Akzariel]]></dc:creator><pubDate>Sat, 28 Oct 2017 15:24:15 GMT</pubDate></item><item><title><![CDATA[Reply to Clock , weather module problems on Sat, 28 Oct 2017 15:08:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/akzariel" aria-label="Profile: Akzariel">@<bdi>Akzariel</bdi></a></p>
<p dir="auto">Have you set your time format in the config.js file to 24 hour?<br />
<img src="/assets/uploads/files/1509203335392-121.jpg" alt="0_1509203347484_121.JPG" class=" img-fluid img-markdown" /></p>
<p dir="auto">The time in the weather module is not a clock. It shows the time of sunrise and sunset. Notice the little sunset icon to the left of 5:51 pm in your picture</p>
]]></description><link>https://forum.magicmirror.builders/post/30277</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30277</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 28 Oct 2017 15:08:57 GMT</pubDate></item></channel></rss>
