<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[is there a module for classic RGB(W) LED-strip?]]></title><description><![CDATA[<p dir="auto">Hey there,</p>
<p dir="auto">I am planning my first magic mirror, so I’m not familiar with all the modules available out there. I have seen modules for these chipped LED strips, but I want to use one of those classic RGB or RGBW strips.<br />
As those need PWM for dimming I need 4 Pins. One way would be to use software PWM, but I have no experience with that. The other would be to use serial output to an arduino and use of of his PWM pins to controll the dimming. I have seen the MMM-gesture module which uses this way of communication, but only arduino-&gt;rpi. Is this also  possible the other way around? Which way is easier to implement?<br />
As I will probably use MMM-gesture there will be an arduino in any case, so additional hardware will be no problem.</p>
<p dir="auto">Thanks a lot for your input.<br />
Anduril</p>
]]></description><link>https://forum.magicmirror.builders/topic/5400/is-there-a-module-for-classic-rgb-w-led-strip</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 01:37:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5400.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Oct 2017 10:13:47 GMT</pubDate><ttl>60</ttl></channel></rss>
