<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I Need your Help]]></title><description><![CDATA[<p dir="auto">So, my Problem is that the MagicMirror always says that i need a config file when i startet, he says the same when i use the  standart config file without changing. YES i Change the name to “config.js” from “config.js.sample”.<br />
If i type "npm start in the Termminal he says many error:</p>
<p dir="auto">err: Linux 4.9.41-v7+<br />
errargv “/usr/bin/node” “/usr/bin/npm” “start”<br />
err: node v6.11.5<br />
err: npm v3.10.10<br />
err: code ELIFECYCLE<br />
err: Mmagicmirror@2.1.3 start: ‘sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>’<br />
err: EXIT Status 1<br />
err:<br />
err: FAild at the magicmirror@2.1.3 start script ‘sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a>’<br />
err: Make sure you have the lates version of node.js and npm installed.<br />
err: If you do, this most likely a problem with the magicmirror package,<br />
err: not with npm itself<br />
err: Tell the author that this fails on your system:<br />
err: sh <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a><br />
err: You can get information on how to open issue forthis project with<br />
err: npm bugs magicmirror<br />
err: Or if that isn’t available, you can get their info via:<br />
err: There is likely additional logging output above.</p>
<p dir="auto">err: Please include the following file with any support request:<br />
err: /home/pi/MagicMirror/npm-debug.log<br />
Now i need your Help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/5401/i-need-your-help</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 09:29:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5401.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Oct 2017 13:51:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I Need your Help on Fri, 03 Nov 2017 17:34:48 GMT]]></title><description><![CDATA[<p dir="auto">Guys Good News,<br />
i install today Rasbian OS Jessie for my Raspberry pi 3 model B and what happends hoooola nothing. haha<br />
No Error nothing fail.</p>
<p dir="auto">MagicMirror install all without a Error, OS Stretch sucks for the MagicMirro so Guys never Use that. Use OS Jessie for The MagicMirror. PEACE!!</p>
<p dir="auto">It works now YUHUUUUU.</p>
<p dir="auto">Thank you all for helping me  :D   now i build the Frame and install a few Modules.</p>
<p dir="auto">Thank YOU ALL!!</p>
]]></description><link>https://forum.magicmirror.builders/post/30645</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30645</guid><dc:creator><![CDATA[Nawid]]></dc:creator><pubDate>Fri, 03 Nov 2017 17:34:48 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Thu, 02 Nov 2017 23:06:31 GMT]]></title><description><![CDATA[<p dir="auto">@Sean said in <a href="/post/30611">I Need your Help</a>:</p>
<p dir="auto">I’m using pure OSX for development.</p>
<p dir="auto">I ran into some problems with the iMac, MacOS 10.7.5, so I opted for the dual boot option. I’m sure a newer Mac with the latest OS is fantastic, but I’m stuck with what have</p>
]]></description><link>https://forum.magicmirror.builders/post/30612</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30612</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 02 Nov 2017 23:06:31 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Thu, 02 Nov 2017 22:48:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
I’m using pure OSX for development. Except some specific features like GPIO, MM works well on OSX.</p>
]]></description><link>https://forum.magicmirror.builders/post/30611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30611</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 02 Nov 2017 22:48:16 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Thu, 02 Nov 2017 21:27:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nawid" aria-label="Profile: Nawid">@<bdi>Nawid</bdi></a> said in <a href="/post/30599">I Need your Help</a>:</p>
<p dir="auto">Which OS is the Best for the MagicMirror²?</p>
<p dir="auto">On a Pi? Raspbian Jessie, without a doubt in my mind.</p>
<p dir="auto">On a PC? I’ve only used Windows 7 but it’s rock solid.</p>
<p dir="auto">On a Compaq Presario CQ57? Ditch Windows and run it as a Linux machine. Install uBuntu and MM for best performance.</p>
<p dir="auto">On a Core Duo MacBook? uBuntu v14.04 and MM run amazingly well.</p>
<p dir="auto">On a Core 2 Duo iMac? Dual boot so you don’t lose a decent Mac OS. Install uBuntu along side the MacOS and MM will be very happy.</p>
]]></description><link>https://forum.magicmirror.builders/post/30606</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30606</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 02 Nov 2017 21:27:53 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Thu, 02 Nov 2017 18:00:30 GMT]]></title><description><![CDATA[<p dir="auto">Which OS is the Best for the MagicMirror²?</p>
]]></description><link>https://forum.magicmirror.builders/post/30599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30599</guid><dc:creator><![CDATA[Nawid]]></dc:creator><pubDate>Thu, 02 Nov 2017 18:00:30 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Wed, 01 Nov 2017 21:25:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nawid" aria-label="Profile: Nawid">@<bdi>Nawid</bdi></a><br />
Ok. We can step forward somehow.<br />
I’m not using Stretch so i cannot assure, but as i know, there is some problem for auto installation with Stretch. You can get detailed info by searching for it.<br />
I suggest you to install Mm and dependencies manually instead of auto installer.</p>
]]></description><link>https://forum.magicmirror.builders/post/30510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30510</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 01 Nov 2017 21:25:54 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Thu, 02 Nov 2017 09:32:41 GMT]]></title><description><![CDATA[<p dir="auto">i have</p>
<ul>
<li>rpi 3 model b</li>
<li>OS Stretch</li>
<li>i change nothing with the account</li>
<li>I install magicmirror Automatic installer,  yes he shows a suspicious messages  today if i install magicmirror automatic.  He say “Unable to install dependencies” at the end  after  the error wich i wirte yetesday.</li>
<li>conncect it the machine direct to RPI with Keyboard an mouse</li>
</ul>
<p dir="auto">I think it  i had the problem because he displays the error message " Unable to install dependencies".</p>
<p dir="auto">electron@1.7.9 postinstall ‘node install.js’ he can’t intall this</p>
<p dir="auto">ERROR: read ECONNRESET<br />
at exports._errnoException (util.js:1020:11)<br />
at TLSWrap.onread (net.js:568:26)</p>
<p dir="auto">What can i do now?</p>
]]></description><link>https://forum.magicmirror.builders/post/30509</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30509</guid><dc:creator><![CDATA[Nawid]]></dc:creator><pubDate>Thu, 02 Nov 2017 09:32:41 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Wed, 01 Nov 2017 09:30:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nawid" aria-label="Profile: Nawid">@<bdi>Nawid</bdi></a><br />
There are too many points to guess which is the exact reason of your problem.</p>
<ol>
<li>Make all the things clearly. All of these might not be related to your real problem, but it might be help or not. Since we cannot inspect your environment, so more detailed information would be better to guess.</li>
</ol>
<ul>
<li>which rpi do you have? rpi 3 model B ?</li>
<li>which OS do you use? Jessie? Jessie Lite? Stretch? Armbian? or any other things?</li>
<li>Did you change your account from <code>pi(or any default account)</code> to anything else? In that case, did you give proper permission for that account?</li>
<li>how do you install MagicMirror? manually? or Automatic installer? Have you got any suspicious messages during installation? MM needs so many dependencies, all of the dependencies should be installed properly.</li>
<li>how do you connect to your machine for running MM? via SSH? or direct connect to RPI with keyboard and mouse?</li>
<li>how do you execute your MM? autostart with <code>pm2</code> or other way to use <code>npm</code>?</li>
<li>Have you tried <code>npm run config:check</code>? what is the result?</li>
</ul>
<ol start="2">
<li>Your first article about error logs seems not to be related <code>config.js missed</code>.<br />
When <code>config.js</code> is missed, the error logs will be like these something;</li>
</ol>
<pre><code>&gt; magicmirror@2.1.3 start /Users/eouia/Documents/nodeJS/MagicMirror
&gt; sh run-start.sh "dev"
Starting MagicMirror: v2.1.3
Loading config ...
WARNING! Could not find config file. Please create one. Starting with default configuration.
Loading module helpers ...
No helper found for module: helloworld.
<p dir="auto">But your logs were showing that you had something wrong with your installation. So, why do you think this is config missing?</p>
]]></description><link>https://forum.magicmirror.builders/post/30483</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30483</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 01 Nov 2017 09:30:20 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Wed, 01 Nov 2017 09:07:31 GMT]]></title><description><![CDATA[<p dir="auto">i do it often from begining, but every time the same problem with the config file. I start from the begining again.</p>
<ol>
<li>Install Rasbian</li>
<li>rasbian configuration for the magicmirror</li>
<li>install MagicMirror</li>
<li>copy and past the config file and rename it.</li>
<li>Test number 100.000.000.000 -.-</li>
</ol>
<p dir="auto">if you have a better step than tell it me</p>
]]></description><link>https://forum.magicmirror.builders/post/30482</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30482</guid><dc:creator><![CDATA[Nawid]]></dc:creator><pubDate>Wed, 01 Nov 2017 09:07:31 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Tue, 31 Oct 2017 23:54:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a><br />
I don’t know exactly. Frankly said, I recommend install again from begining.</p>
]]></description><link>https://forum.magicmirror.builders/post/30468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30468</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 31 Oct 2017 23:54:28 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Tue, 31 Oct 2017 21:18:02 GMT]]></title><description><![CDATA[<p dir="auto">@Sean</p>
<p dir="auto">If MM is reporting “Create a config” then isn’t  his installation ok?</p>
]]></description><link>https://forum.magicmirror.builders/post/30461</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30461</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 31 Oct 2017 21:18:02 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Tue, 31 Oct 2017 21:06:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nawid" aria-label="Profile: Nawid">@<bdi>Nawid</bdi></a><br />
It seems you’d missed something in installation steps.</p>
<pre><code>cd ~/MagicMirror
npm install
<p dir="auto">Or just begin from first again.</p>
]]></description><link>https://forum.magicmirror.builders/post/30460</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30460</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 31 Oct 2017 21:06:45 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Tue, 31 Oct 2017 20:08:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nawid" aria-label="Profile: Nawid">@<bdi>Nawid</bdi></a></p>
<pre><code>cd ~/MagicMirror/config
ls -al
<p dir="auto">What is the result of above?</p>
]]></description><link>https://forum.magicmirror.builders/post/30456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30456</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 31 Oct 2017 20:08:57 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Tue, 31 Oct 2017 17:27:35 GMT]]></title><description><![CDATA[<p dir="auto">@sean   cd ~/MagicMirror</p>
<p dir="auto">MagicMirror doesen’t find my config.js file. I do it how MichMich explained for beginners, but MagiMirror told me every time create a config file.</p>
]]></description><link>https://forum.magicmirror.builders/post/30450</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30450</guid><dc:creator><![CDATA[Nawid]]></dc:creator><pubDate>Tue, 31 Oct 2017 17:27:35 GMT</pubDate></item><item><title><![CDATA[Reply to I Need your Help on Tue, 31 Oct 2017 16:25:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nawid" aria-label="Profile: Nawid">@<bdi>Nawid</bdi></a><br />
In which directory, did you command?</p>
<pre><code>cd ~
pm2 start mm.sh
<p dir="auto">Or</p>
npm start
<p dir="auto">Try them.</p>
]]></description><link>https://forum.magicmirror.builders/post/30447</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30447</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 31 Oct 2017 16:25:47 GMT</pubDate></item></channel></rss>
