<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Hive - error loading data]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/4576/mmm-hive">MMM-Hive</a><br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/mongo116" aria-label="Profile: mongo116">@<bdi>mongo116</bdi></a> Recently I seem to be getting ‘Error loading data’ for the hive module. Sometimes it loads (although the outside temperature is ‘null’).</p>
<p dir="auto">Enabling debug gives me the message:<br />
<em>“MMM-Hive received notification: UNKNOWN_ERROR - Payload: Error found within get postcode data: undefined Body: undefined”</em></p>
<p dir="auto">Tried to change postcode, put in a blank one etc but still get the issue.</p>
<p dir="auto">I did note that if I manually go to the outside url that it throws a SSL cert error so maybe that’s related?</p>
<p dir="auto">Any ideas what the issue could be? Is yours running ok?</p>
]]></description><link>https://forum.magicmirror.builders/topic/5419/mmm-hive-error-loading-data</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 11:32:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5419.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Nov 2017 15:05:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Hive - error loading data on Fri, 03 Nov 2017 16:00:37 GMT]]></title><description><![CDATA[<p dir="auto">Temporary fix seems to be using outside url with http instead of https.</p>
]]></description><link>https://forum.magicmirror.builders/post/30639</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30639</guid><dc:creator><![CDATA[randomnoise]]></dc:creator><pubDate>Fri, 03 Nov 2017 16:00:37 GMT</pubDate></item></channel></rss>
