<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mouse Cursor Visible On Reboot]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">Any suggestions to make the mouse cursor invisible on reboot?</p>
<p dir="auto">I’ve changed all my LXDE settings, meaning when i move the mouse it disappears.</p>
<p dir="auto">But when my mirror reboots and there is no mouse movement the cursor sits there right in the middle until I plug in a mouse and move it, then it goes?</p>
<p dir="auto">Any help would be greatly appreciated. Thanks</p>
<p dir="auto">Ollie</p>
]]></description><link>https://forum.magicmirror.builders/topic/542/mouse-cursor-visible-on-reboot</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 22:40:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/542.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Aug 2016 21:09:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mouse Cursor Visible On Reboot on Wed, 24 Aug 2016 13:57:15 GMT]]></title><description><![CDATA[<p dir="auto">Additional configuration tips can be found here: <a href="https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3954</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3954</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Wed, 24 Aug 2016 13:57:15 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Cursor Visible On Reboot on Wed, 24 Aug 2016 08:34:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gshimself" aria-label="Profile: gshimself">@<bdi>gshimself</bdi></a></p>
<p dir="auto">That’s worked perfectly thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/3944</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3944</guid><dc:creator><![CDATA[olliewarren411]]></dc:creator><pubDate>Wed, 24 Aug 2016 08:34:46 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Cursor Visible On Reboot on Wed, 24 Aug 2016 08:28:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/olliewarren411" aria-label="Profile: olliewarren411">@<bdi>olliewarren411</bdi></a> Okey. Well it was long ago I did install my rasp. so I’ve might forgot how I did it. But do you have “unclutter” installed?<br />
<a href="http://raspberrypi.stackexchange.com/questions/2092/hide-cursor-in-raspbian" target="_blank" rel="noopener noreferrer nofollow ugc">http://raspberrypi.stackexchange.com/questions/2092/hide-cursor-in-raspbian</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3943</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3943</guid><dc:creator><![CDATA[gshimself]]></dc:creator><pubDate>Wed, 24 Aug 2016 08:28:35 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Cursor Visible On Reboot on Wed, 24 Aug 2016 07:57:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gshimself" aria-label="Profile: gshimself">@<bdi>gshimself</bdi></a></p>
<p dir="auto">Thanks for your reply. I do have the LXDE-pi/autostart set correctly as you say as well as the LXDE/autostart.</p>
<p dir="auto">The mouse cursor does disappear but only when you try and move it.</p>
]]></description><link>https://forum.magicmirror.builders/post/3942</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3942</guid><dc:creator><![CDATA[olliewarren411]]></dc:creator><pubDate>Wed, 24 Aug 2016 07:57:38 GMT</pubDate></item><item><title><![CDATA[Reply to Mouse Cursor Visible On Reboot on Wed, 24 Aug 2016 05:05:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/olliewarren411" aria-label="Profile: olliewarren411">@<bdi>olliewarren411</bdi></a> you sure you have<br />
"@xset s off<br />
@xset -dpms<br />
@xset s noblank<br />
"<br />
in /etc/xdg/lxsession/LXDE-pi ? Mine works just fine with those values</p>
]]></description><link>https://forum.magicmirror.builders/post/3940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3940</guid><dc:creator><![CDATA[gshimself]]></dc:creator><pubDate>Wed, 24 Aug 2016 05:05:11 GMT</pubDate></item></channel></rss>
