<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Screencast with mobile]]></title><description><![CDATA[<p dir="auto">Hi All,<br />
Do we have any module to screencast any mobile phone with magic mirror?</p>
<p dir="auto">Thanks in advance.</p>
]]></description><link>https://forum.magicmirror.builders/topic/5430/screencast-with-mobile</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 10:56:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5430.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Nov 2017 05:01:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Screencast with mobile on Wed, 02 Mar 2022 11:17:56 GMT]]></title><description><![CDATA[<p dir="auto">A module to cast to the MagicMirror. Currently, only YouTube casting is supported. You can try following module for screencast.<br />
Navigate to the modules directory via the follow command: cd MagicMirror/modules<br />
Clone the module from github: git clone <a href="https://github.com/kevinatown/MMM-Screencast.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/kevinatown/MMM-Screencast.git</a><br />
Navigate to the MMM-Screencast directory: cd MMM-Screencast<br />
Install the dependencies: npm install<br />
Add the following configuration to the modules array in the config/config.js file:<br />
For More detail follow Below Link<br />
<a href="https://github.com/kevinatown/MMM-Screencast" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/kevinatown/MMM-Screencast</a></p>
]]></description><link>https://forum.magicmirror.builders/post/100050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100050</guid><dc:creator><![CDATA[roybaxter]]></dc:creator><pubDate>Wed, 02 Mar 2022 11:17:56 GMT</pubDate></item><item><title><![CDATA[Reply to Screencast with mobile on Fri, 28 Jan 2022 10:34:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mlombardi" aria-label="Profile: mlombardi">@<bdi>mlombardi</bdi></a><br />
Hi did you find  how to stop it after watching im having the same issue</p>
]]></description><link>https://forum.magicmirror.builders/post/99093</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99093</guid><dc:creator><![CDATA[Lobb]]></dc:creator><pubDate>Fri, 28 Jan 2022 10:34:57 GMT</pubDate></item><item><title><![CDATA[Reply to Screencast with mobile on Mon, 01 Mar 2021 00:06:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sokhals" aria-label="Profile: sokhals">@<bdi>sokhals</bdi></a> Hello,</p>
<p dir="auto">I got mine to work, but how to i get it to go away after watching</p>
]]></description><link>https://forum.magicmirror.builders/post/89019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89019</guid><dc:creator><![CDATA[mlombardi]]></dc:creator><pubDate>Mon, 01 Mar 2021 00:06:58 GMT</pubDate></item><item><title><![CDATA[Reply to Screencast with mobile on Mon, 12 Mar 2018 22:23:08 GMT]]></title><description><![CDATA[<p dir="auto">Open Youtube app in phone or laptop and click on the cast button.<br />
Then select the raspberryPi and it will play there.</p>
<p dir="auto">+1 very nice module</p>
]]></description><link>https://forum.magicmirror.builders/post/36948</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/36948</guid><dc:creator><![CDATA[sokhals]]></dc:creator><pubDate>Mon, 12 Mar 2018 22:23:08 GMT</pubDate></item><item><title><![CDATA[Reply to Screencast with mobile on Sat, 13 Jan 2018 18:35:56 GMT]]></title><description><![CDATA[<p dir="auto">I have installed this Module but now I can’t seem to figure what to cast from.<br />
]]></description><link>https://forum.magicmirror.builders/post/33883</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33883</guid><dc:creator><![CDATA[aandrew7]]></dc:creator><pubDate>Sat, 13 Jan 2018 18:35:56 GMT</pubDate></item><item><title><![CDATA[Reply to Screencast with mobile on Sat, 18 Nov 2017 19:33:07 GMT]]></title><description><![CDATA[<p dir="auto">Trying…  will update you.<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/31328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31328</guid><dc:creator><![CDATA[g_nandagpl]]></dc:creator><pubDate>Sat, 18 Nov 2017 19:33:07 GMT</pubDate></item><item><title><![CDATA[Reply to Screencast with mobile on Mon, 06 Nov 2017 12:06:55 GMT]]></title><description><![CDATA[<p dir="auto">That’s a cool idea! As far as I can tell there’s nothing like it at the moment, but I did some some cursory googling and, while I’m far out of my range of expertise, it looks like you <em>might</em> be able to use something like <a href="https://github.com/DeMille/url-cast-receiver" target="_blank" rel="noopener noreferrer nofollow ugc">this homebrew chromecast receiver</a> and use somehow display it in an iFrame, which there are several modules for. I’m not sure how it’d work with various size constraints, but from what I’ve found, that’s the most promising option.</p>
<p dir="auto">If you’re on iOS, there’s maybe something you could do with either Airserver or <a href="http://www.airsquirrels.com/reflector/features/mac/" target="_blank" rel="noopener noreferrer nofollow ugc">Reflector 2</a> (which is what I use). Either way, it may actually be easier to have a separate machine running whatever is receiving the content and then streaming it to one of the streaming video player modules. Heads-up though, that’ll likely require some horsepower on the server you’re doing it with, or you’re liable to end up with some real frustrating latency.</p>
<p dir="auto">However you end up going, please post updates – this is a really cool idea and I’d like very much to see how it works out!</p>
]]></description><link>https://forum.magicmirror.builders/post/30775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30775</guid><dc:creator><![CDATA[pyrosmiley]]></dc:creator><pubDate>Mon, 06 Nov 2017 12:06:55 GMT</pubDate></item></channel></rss>
