<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WiFi drops and reconnects regularly...]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I happen to find some strange entries in my logs. I’m not sure, if they are MM2 related, but perhaps someone can Point me in the right direction.<br />
I’m running MM2 (latest) on a raspberry Pi 3 model B (Hardware BCM2835, Revision a02082) and seemingly the WiFi disconnects on a regular base (sometimes around an hour, sometimes 20min) and at times won’t reconnect:</p>
<p dir="auto">/var/log/messages</p>
<pre><code>Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304393] usb 1-1: USB disconnect, device number 6
Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304419] usb 1-1.1: USB disconnect, device number 7
Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304833] smsc95xx 1-1.1:1.0 enxb827eb395566: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.304927] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
Nov  8 07:39:09 MagicMirror2 kernel: [ 3490.554214] Indeed it is in host mode hprt0 = 00021501
Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.754068] usb 1-1: new high-speed USB device number 8 using dwc_otg
Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.754318] Indeed it is in host mode hprt0 = 00001101
Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.984336] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.984355] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.985385] hub 1-1:1.0: USB hub found
Nov  8 07:39:10 MagicMirror2 kernel: [ 3490.985487] hub 1-1:1.0: 5 ports detected
Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.324025] usb 1-1.1: new high-speed USB device number 9 using dwc_otg
Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.465152] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.465186] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.469158] smsc95xx v1.0.5
Nov  8 07:39:10 MagicMirror2 mtp-probe: checking bus 1, device 9: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Nov  8 07:39:10 MagicMirror2 mtp-probe: bus: 1, device: 9 was not an MTP device
Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.568590] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:39:55:66
Nov  8 07:39:10 MagicMirror2 kernel: [ 3491.600462] smsc95xx 1-1.1:1.0 enxb827eb395566: renamed from eth0
Nov  8 07:39:11 MagicMirror2 kernel: [ 3491.976302] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
Nov  8 07:39:11 MagicMirror2 kernel: [ 3491.976719] IPv6: ADDRCONF(NETDEV_UP): enxb827eb395566: link is not ready
Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.310923] usb 1-1: USB disconnect, device number 8
Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.310952] usb 1-1.1: USB disconnect, device number 9
Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.311373] smsc95xx 1-1.1:1.0 enxb827eb395566: unregister 'smsc95xx' usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet
Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.311472] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
Nov  8 08:33:09 MagicMirror2 kernel: [ 6730.580643] Indeed it is in host mode hprt0 = 00021501
Nov  8 08:33:10 MagicMirror2 kernel: [ 6730.790635] usb 1-1: new high-speed USB device number 10 using dwc_otg
Nov  8 08:33:10 MagicMirror2 kernel: [ 6730.790867] Indeed it is in host mode hprt0 = 00001101
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.021176] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.021204] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.022487] hub 1-1:1.0: USB hub found
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.022594] hub 1-1:1.0: 5 ports detected
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.340631] usb 1-1.1: new high-speed USB device number 11 using dwc_otg
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.470918] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.470937] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.474357] smsc95xx v1.0.5
Nov  8 08:33:10 MagicMirror2 mtp-probe: checking bus 1, device 11: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1"
Nov  8 08:33:10 MagicMirror2 mtp-probe: bus: 1, device: 11 was not an MTP device
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.565397] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:39:55:66
Nov  8 08:33:10 MagicMirror2 kernel: [ 6731.595975] smsc95xx 1-1.1:1.0 enxb827eb395566: renamed from eth0
Nov  8 08:33:11 MagicMirror2 kernel: [ 6731.864586] smsc95xx 1-1.1:1.0 enxb827eb395566: hardware isn't capable of remote wakeup
Nov  8 08:33:11 MagicMirror2 kernel: [ 6731.865091] IPv6: ADDRCONF(NETDEV_UP): enxb827eb395566: link is not ready
<p dir="auto">/var/log/syslog</p>
Nov  8 07:39:09 MagicMirror2 dhcpcd[384]: enxb827eb395566: removing interface
Nov  8 07:39:11 MagicMirror2 dhcpcd[384]: enxb827eb395566: waiting for carrier
<p dir="auto">Somebody got the same errors?</p>
]]></description><link>https://forum.magicmirror.builders/topic/5445/wifi-drops-and-reconnects-regularly</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 08:59:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5445.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Nov 2017 08:05:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Wed, 08 Nov 2017 09:49:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barnosch" aria-label="Profile: barnosch">@<bdi>barnosch</bdi></a> hmmm… Thanks! I just replaced the 1,5A with a 2A one as I lack a 2,5A one. I’ll Keep that in mind, though!</p>
]]></description><link>https://forum.magicmirror.builders/post/30852</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30852</guid><dc:creator><![CDATA[binderth]]></dc:creator><pubDate>Wed, 08 Nov 2017 09:49:41 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Fri, 27 Sep 2019 20:07:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barnosch" aria-label="Profile: barnosch">@<bdi>barnosch</bdi></a><br />
I am also having the same issue. I tried this method, But still i am facing this issue. Any other solutions.</p>
]]></description><link>https://forum.magicmirror.builders/post/61773</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/61773</guid><dc:creator><![CDATA[mukulb]]></dc:creator><pubDate>Fri, 27 Sep 2019 20:07:27 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Thu, 09 Nov 2017 09:10:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/binderth" aria-label="Profile: binderth">@<bdi>binderth</bdi></a> I found that 2A isn’t enough for the pi3, when under heavy load it would fail. The raspberry 2,5A power unit is highly recommended.</p>
]]></description><link>https://forum.magicmirror.builders/post/30896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30896</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Thu, 09 Nov 2017 09:10:41 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Wed, 08 Nov 2017 13:06:20 GMT]]></title><description><![CDATA[<p dir="auto">Just a short information, after changing the powersupply to 5V/2A instead 5V/1,5A it now seems stable. I now only get a rekeying-message every 10mins in the syslog, which I suppose is my FritzBox. :)</p>
<p dir="auto">I’m using the internal WiFi - apparently withou power saving off. But seems OK.</p>
]]></description><link>https://forum.magicmirror.builders/post/30863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30863</guid><dc:creator><![CDATA[binderth]]></dc:creator><pubDate>Wed, 08 Nov 2017 13:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Wed, 08 Nov 2017 12:32:05 GMT]]></title><description><![CDATA[<p dir="auto">Honestly I think this happens when you update the Pi…I don’t believe it’s MM doing this.</p>
]]></description><link>https://forum.magicmirror.builders/post/30861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30861</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Wed, 08 Nov 2017 12:32:05 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Wed, 08 Nov 2017 12:24:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/binderth" aria-label="Profile: binderth">@<bdi>binderth</bdi></a></p>
<p dir="auto">Have you?</p>
<p dir="auto">Disable WiFi Power Save</p>
<h1>Disable power saving</h1>
<p dir="auto">For Raspberry Pi 3<br />
Edit /etc/network/interfaces</p>
<p dir="auto">sudo nano /etc/network/interfaces<br />
Add the following line under the wlan0 section</p>
<p dir="auto">wireless-power off<br />
Reboot your PI</p>
<p dir="auto">sudo reboot</p>
]]></description><link>https://forum.magicmirror.builders/post/30860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30860</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 08 Nov 2017 12:24:52 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Wed, 08 Nov 2017 12:12:35 GMT]]></title><description><![CDATA[<p dir="auto">the only “original” RaspPi3 powersupply they sell has 5V/2.5A<br />
But i guess a 2A is good to go.<br />
If the old one has some problems or drops the voltage from time to time, the issues you have can happen easily.<br />
Just try with the other one?<br />
You are using the internal Wifi or with a external USB-Wlan Dongle?</p>
]]></description><link>https://forum.magicmirror.builders/post/30859</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30859</guid><dc:creator><![CDATA[barnosch]]></dc:creator><pubDate>Wed, 08 Nov 2017 12:12:35 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Wed, 08 Nov 2017 09:49:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/barnosch" aria-label="Profile: barnosch">@<bdi>barnosch</bdi></a> hmmm… Thanks! I just replaced the 1,5A with a 2A one as I lack a 2,5A one. I’ll Keep that in mind, though!</p>
]]></description><link>https://forum.magicmirror.builders/post/30852</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30852</guid><dc:creator><![CDATA[binderth]]></dc:creator><pubDate>Wed, 08 Nov 2017 09:49:41 GMT</pubDate></item><item><title><![CDATA[Reply to WiFi drops and reconnects regularly... on Wed, 08 Nov 2017 08:20:33 GMT]]></title><description><![CDATA[<p dir="auto">First step i would do, is a replacement with another power supply.<br />
Does it have enough power. At least 2.5A is recommened i guess!?</p>
<p dir="auto">I guess it is not related to the MM itself, its a Pi problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/30848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/30848</guid><dc:creator><![CDATA[barnosch]]></dc:creator><pubDate>Wed, 08 Nov 2017 08:20:33 GMT</pubDate></item></channel></rss>
