<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[McSorley's Mirror]]></title><description><![CDATA[<p dir="auto">Hey everyone,</p>
<p dir="auto">Found out about MagicMirror’s from the few viral posts thats I’ve seen on reddit and last month decided to give it a go.</p>
<p dir="auto">I no longer used my dual monitor desktop so decided to take one apart and see how difficult making the mirror could be.</p>
<p dir="auto">It was an HP 2011x 20inch Monitor and bought the a RaspberryPi 3 to attempt the programming.</p>
<p dir="auto">I am an IT technician by profession so I am happy to get my hands in taking stuff apart and putting it back together again.</p>
<p dir="auto">I bought the 2 way reflective plastic from<br />
<a href="http://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror</a><br />
which has a really good service and works well for builders in the UK.</p>
<p dir="auto">My dad is the handyman. Joiner for 40 years. He helped out with building the frame and casing for the mirror. Made out of mahogany and plywood for support.</p>
<p dir="auto"><img src="http://i.imgur.com/KSc2hj0.jpg" alt="End Result!" class=" img-fluid img-markdown" /><br />
<img src="http://i.imgur.com/LV3y1Oh.jpg" alt="With the mirror off" class=" img-fluid img-markdown" /></p>
<p dir="auto">There is the one issue because of the type of monitor the DVI connection is facing outwards rather than down. Anyone able to suggest an alternative circuit that would be compatible or a way that this could be mounted to a wall?<br />
<img src="http://i.imgur.com/UADEKra.jpg" alt="DVI cable issue" class=" img-fluid img-markdown" /><br />
<img src="http://i.imgur.com/8sheGRB.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Not added much in terms of modules apart from the IP showing which is handy for remote connections.</p>
<p dir="auto">Let me know what you all think! :D</p>
<p dir="auto">Cheers,<br />
McSorley</p>
]]></description><link>https://forum.magicmirror.builders/topic/550/mcsorley-s-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 14:03:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/550.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Aug 2016 16:42:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to McSorley's Mirror on Thu, 01 Sep 2016 08:55:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitchfarino" aria-label="Profile: Mitchfarino">@<bdi>Mitchfarino</bdi></a> said in <a href="/post/4261">McSorley's Mirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcsorley" aria-label="Profile: McSorley">@<bdi>McSorley</bdi></a> Did you completely gut the monitor?</p>
<p dir="auto">I’ve taken the plastic frame off and left everything else, so it’s just all the metal exposed</p>
<p dir="auto">Yep. Bare bones. Leave the metal frame on of course, you might bleed the monitor trying to remove it.</p>
]]></description><link>https://forum.magicmirror.builders/post/4262</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4262</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Thu, 01 Sep 2016 08:55:11 GMT</pubDate></item><item><title><![CDATA[Reply to McSorley's Mirror on Thu, 01 Sep 2016 08:29:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mcsorley" aria-label="Profile: McSorley">@<bdi>McSorley</bdi></a> Did you completely gut the monitor?</p>
]]></description><link>https://forum.magicmirror.builders/post/4261</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4261</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Thu, 01 Sep 2016 08:29:50 GMT</pubDate></item><item><title><![CDATA[Reply to McSorley's Mirror on Wed, 31 Aug 2016 17:52:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitchfarino" aria-label="Profile: Mitchfarino">@<bdi>Mitchfarino</bdi></a> said in <a href="/post/4176">McSorley's Mirror</a>:</p>
<p dir="auto">I haven’t bought my acrylic yet.</p>
<p dir="auto">I’ll be going with the same site that you have used, so I feel better now I have seen what it looks like!</p>
<p dir="auto">Nice work!</p>
<p dir="auto">Make sure you get it cut to the right size. Its not very easily to play with.</p>
]]></description><link>https://forum.magicmirror.builders/post/4200</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4200</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Wed, 31 Aug 2016 17:52:56 GMT</pubDate></item><item><title><![CDATA[Reply to McSorley's Mirror on Wed, 31 Aug 2016 11:51:30 GMT]]></title><description><![CDATA[<p dir="auto">I haven’t bought my acrylic yet.</p>
]]></description><link>https://forum.magicmirror.builders/post/4176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4176</guid><dc:creator><![CDATA[Mitchfarino]]></dc:creator><pubDate>Wed, 31 Aug 2016 11:51:30 GMT</pubDate></item><item><title><![CDATA[Reply to McSorley's Mirror on Sat, 27 Aug 2016 07:49:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gshimself" aria-label="Profile: gshimself">@<bdi>gshimself</bdi></a> said in <a href="/post/3990">McSorley's Mirror</a>:</p>
<p dir="auto">Looks really good man! Any thoughts to add any more modules later on or are you happy as it is? :)</p>
<p dir="auto">I’ve been on the lookout for more on the forums but nothing has really caught my eye yet. For sure though, certainly want to keep adding and improving it.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> said in <a href="/post/3992">McSorley's Mirror</a>:</p>
<p dir="auto"><a href="https://www.amazon.co.uk/HDE-Plated-Degree-Female-Adapter/dp/B0080ID9ZW/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.co.uk/HDE-Plated-Degree-Female-Adapter/dp/B0080ID9ZW/</a></p>
<p dir="auto"><a href="https://www.amazon.co.uk/StarTech-Degree-Angled-DVI-D-Monitor/dp/B0035PS586/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.co.uk/StarTech-Degree-Angled-DVI-D-Monitor/dp/B0035PS586/</a></p>
<p dir="auto">Exactly what i’ve been looking for! Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/4001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4001</guid><dc:creator><![CDATA[McSorley]]></dc:creator><pubDate>Sat, 27 Aug 2016 07:49:36 GMT</pubDate></item><item><title><![CDATA[Reply to McSorley's Mirror on Sat, 27 Aug 2016 01:52:42 GMT]]></title><description><![CDATA[<p dir="auto">Looks awesome!!</p>
]]></description><link>https://forum.magicmirror.builders/post/3994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3994</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sat, 27 Aug 2016 01:52:42 GMT</pubDate></item><item><title><![CDATA[Reply to McSorley's Mirror on Fri, 26 Aug 2016 21:01:45 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://www.amazon.co.uk/HDE-Plated-Degree-Female-Adapter/dp/B0080ID9ZW/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.amazon.co.uk/HDE-Plated-Degree-Female-Adapter/dp/B0080ID9ZW/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/3992</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3992</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 26 Aug 2016 21:01:45 GMT</pubDate></item><item><title><![CDATA[Reply to McSorley's Mirror on Fri, 26 Aug 2016 20:42:31 GMT]]></title><description><![CDATA[<p dir="auto">Looks really good man! Any thoughts to add any more modules later on or are you happy as it is? :)</p>
]]></description><link>https://forum.magicmirror.builders/post/3990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3990</guid><dc:creator><![CDATA[gshimself]]></dc:creator><pubDate>Fri, 26 Aug 2016 20:42:31 GMT</pubDate></item></channel></rss>
