<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[npm install error]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/5514/npm-install-error</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 09:14:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5514.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Nov 2017 12:08:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to npm install error on Thu, 16 Nov 2017 12:06:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/acogkenf" aria-label="Profile: acogkenf">@<bdi>acogkenf</bdi></a></p>
<p dir="auto">The two warnings can be ignored. They do not affect the operation on the MM software.</p>
<p dir="auto">It appears your dependencies did not install properly. It happens from time to time. Try this first:</p>
<ul>
<li>Delete the MagicMirror/node_modules/<strong>electron</strong> folder</li>
<li>cd into your MagicMirror directory</li>
<li>run <code>npm install</code></li>
<li>run <code>npm start</code></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/31219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31219</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 16 Nov 2017 12:06:35 GMT</pubDate></item><item><title><![CDATA[Reply to npm install error on Tue, 14 Nov 2017 12:30:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/acogkenf" aria-label="Profile: acogkenf">@<bdi>acogkenf</bdi></a></p>
<p dir="auto">Are you running <code>npm start</code> in the MagicMirror directory?</p>
]]></description><link>https://forum.magicmirror.builders/post/31096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31096</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 14 Nov 2017 12:30:51 GMT</pubDate></item></channel></rss>
