<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM locked when include modules in config]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/1665/mmm-imagesphotos-show-images-from-a-directory">MMM-ImagesPhotos - Show images from a directory</a></p>
<p dir="auto">Hi,<br />
when include your module in config.js and start magic mirror is all black, nothing module work.<br />
Advise ?<br />
Thanks, Alberto</p>
]]></description><link>https://forum.magicmirror.builders/topic/5547/mm-locked-when-include-modules-in-config</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 06:14:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5547.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Nov 2017 17:21:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM locked when include modules in config on Sat, 25 Nov 2017 19:33:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alverman" aria-label="Profile: alverman">@<bdi>alverman</bdi></a> said in <a href="/post/31593">MM locked when include modules in config</a>:</p>
<p dir="auto">Solved !!</p>
<p dir="auto">So, how did you solve it? Other users may encounter the same issue and would benefit from a description of how your corrected it.</p>
<p dir="auto">I’m just saying. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/31594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31594</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 25 Nov 2017 19:33:24 GMT</pubDate></item><item><title><![CDATA[Reply to MM locked when include modules in config on Sat, 25 Nov 2017 19:31:14 GMT]]></title><description><![CDATA[<p dir="auto">Solved !!</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/31593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31593</guid><dc:creator><![CDATA[alverman]]></dc:creator><pubDate>Sat, 25 Nov 2017 19:31:14 GMT</pubDate></item><item><title><![CDATA[Reply to MM locked when include modules in config on Sun, 19 Nov 2017 21:55:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alverman" aria-label="Profile: alverman">@<bdi>alverman</bdi></a></p>
<p dir="auto">This module reads the images from the uploads directory inside the module. Directory: MagicMirror/modules/MMM-ImagesPhotos/uploads. Your images MUST be in this directory.</p>
<pre><code>{
	module: "MMM-ImagesPhotos",
	position: "middle_center",
		opacity: 0.9,
		animationSpeed: 500,
		updateInterval: 5000,
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners">https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners</a></p>
]]></description><link>https://forum.magicmirror.builders/post/31360</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31360</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 19 Nov 2017 21:55:04 GMT</pubDate></item></channel></rss>
