<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Assistant Error]]></title><description><![CDATA[<pre><code>Starting MagicMirror: v2.1.3
Loading config ...
Loading module helpers ...
Initializing mm-music-player module helper ...
WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/electron-v1.7-linux-arm-glibc/grpc_node.node'
App threw an error during load
    at Module._resolveFilename (module.js:470:15)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
    at Function.Module._load (module.js:418:25)
    at Module.require (module.js:498:17)
    at require (internal/module.js:20:19)
    at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/grpc_extension.js:30:15)
    at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/grpc_extension.js:34:3)
    at Module._compile (module.js:571:32)
    at Object.Module._extensions..js (module.js:580:10)
    at Module.load (module.js:488:32)
{ Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/electron-v1.7-linux-arm-glibc/grpc_node.node'
    at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
Launching application.
]]></description><link>https://forum.magicmirror.builders/topic/5575/assistant-error</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 14:54:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5575.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Nov 2017 07:39:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Assistant Error on Tue, 15 May 2018 03:02:14 GMT]]></title><description><![CDATA[<p dir="auto">@sean <a class="plugin-mentions-user plugin-mentions-a" href="/user/shep99" aria-label="Profile: shep99">@<bdi>shep99</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/acogkenf" aria-label="Profile: acogkenf">@<bdi>acogkenf</bdi></a></p>
<p dir="auto">Hello I have solved this problem this way.</p>
<p dir="auto">“npm install --runtime=electron --target=YOUR_ELECTRON_VERSION”</p>
<p dir="auto">Specify the environment and version and you can load grpc in proper way</p>
]]></description><link>https://forum.magicmirror.builders/post/39495</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/39495</guid><dc:creator><![CDATA[wonjerry]]></dc:creator><pubDate>Tue, 15 May 2018 03:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Mon, 19 Mar 2018 14:58:52 GMT]]></title><description><![CDATA[<p dir="auto">Just want to tell everyone that this module works very well.<br />
I had some initial compile issues and trying to get the correct GA authentication, but after that it worked.</p>
<p dir="auto">Now, I’m looking at Alexa, since I’d like both Alexa and GA + MM working.<br />
Please see the github issue for solution in case you missed it.</p>
]]></description><link>https://forum.magicmirror.builders/post/37203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37203</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Mon, 19 Mar 2018 14:58:52 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Fri, 16 Mar 2018 09:00:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shep99" aria-label="Profile: shep99">@<bdi>shep99</bdi></a> Can you please post your ALSA config?</p>
<pre><code class="language-bash">cat ~/.asoundrc
cat /proc/asound/modules
cat /proc/asound/devices
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/37069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/37069</guid><dc:creator><![CDATA[E3V3A]]></dc:creator><pubDate>Fri, 16 Mar 2018 09:00:49 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Sun, 14 Jan 2018 16:36:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shep99" aria-label="Profile: shep99">@<bdi>shep99</bdi></a><br />
Frankly, I have also <code>pmdl</code> problem. When I use <code>umdl</code>, everything is ok. But, <code>pmdl</code> is not worked properly, I don’t know why.</p>
]]></description><link>https://forum.magicmirror.builders/post/33927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33927</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 14 Jan 2018 16:36:16 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Mon, 08 Jan 2018 22:10:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shep99" aria-label="Profile: shep99">@<bdi>shep99</bdi></a> said in <a href="/post/33431">Assistant Error</a>:</p>
<p dir="auto">Just wanted to repost here, @sean thanks and got it going. This is an INCREDIBLE module and thank you. My problem was with my MIC after setup. If anyone else is coming across this, this link here helped to get my MIC setup properly:</p>
<p dir="auto"><a href="https://snowboy.kitt.ai/docs" target="_blank" rel="noopener noreferrer nofollow ugc">https://snowboy.kitt.ai/docs</a></p>
<p dir="auto">Great module @sean absolutely incredible! Thanks</p>
<p dir="auto">Hello,</p>
<p dir="auto">I still have problems to use despite several unsuccessful attempts.</p>
<p dir="auto">Could you detail the installation procedure you used?</p>
<p dir="auto">Thank you in advance,</p>
]]></description><link>https://forum.magicmirror.builders/post/33630</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33630</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Mon, 08 Jan 2018 22:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Mon, 08 Jan 2018 03:28:14 GMT]]></title><description><![CDATA[<p dir="auto">@sean is it possible you can elaborate on these settings in config? I only want to use Google assistant, so have commented out the “MIRROR” hotword, but sometime the MIC picks up on words that are not like my trained model, and sits on the assistant logo waiting for something, and there’s no way to get out of it without restarting the mirror. ie, these settings in particular:</p>
<p dir="auto">sensitivity:</p>
<pre><code>        {
          file: "resources/google.pmdl",
          sensitivity: 0.7,
          hotwords : "ASSISTANT" //One of models should be "ASSISTANT"
<p dir="auto">silence and verbose:</p>
<pre><code>    record: {
      threshold: 0, //Ignore this. I think you don't need to change this.
      verbose:false, //true for checking recording status.
      recordProgram: 'arecord', //You can use 'rec', 'sox'. But I recommend use 'arecord'.
      silence: 2.0 //Ignore this. I think you don't need to change this.
<p dir="auto">Thanks again!</p>
]]></description><link>https://forum.magicmirror.builders/post/33567</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33567</guid><dc:creator><![CDATA[shep99]]></dc:creator><pubDate>Mon, 08 Jan 2018 03:28:14 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Sun, 07 Jan 2018 13:09:40 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I am trying to run this module but I am having problems.</p>
<p dir="auto">Indeed I installed it by following all your previous indications.</p>
<p dir="auto">The mirror is launched correctly and I have the beep module start.</p>
<p dir="auto">If I call the module with the keyword, it triggers. I ask my question and I only have a hatched voice in response.<br />
I did not have any problems of this type with open-jarvis which is also based on snowboy.<br />
I of course neutralize open jarvis to avoid conflicts on the sound card.</p>
<p dir="auto">I think I missed a step on the setup.</p>
<p dir="auto">The config.stt.auth.json file is placed in the resources folder or in the MMM-Assistant folder?</p>
<p dir="auto">When I go on the google developer console, I see requests for the google assistant API but no requests for Google Cloud Speech API.</p>
<p dir="auto">I add my boot log:</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm start dev
&gt; magicmirror@2.2.1 start /home/pi/MagicMirror
&gt; sh run-start.sh "dev"
Starting MagicMirror: v2.2.1
Loading config ...
No helper found for module: calendar_monthly.
Module helper loaded: MMM-MyCommute
Module helper loaded: MMM-Ratp
Module helper loaded: MMM-SoccerLiveScore
Module helper loaded: MMM-soccer
No helper found for module: MMM-Globe.
Module helper loaded: MMM-Remote-Control
Module helper loaded: mmm-suncalc
Module helper loaded: MMM-WunderGround
Module helper loaded: MMM-NOAA
No helper found for module: mmm-wu-moonphase.
Module helper loaded: MMM-Assistant
Module helper loaded: MMM-Tools
No helper found for module: MMM-Snow.
All module helpers loaded.
Server started ...
Connecting socket for: MMM-MyCommute
====================== Starting node_helper for module [MMM-MyCommute]
Connecting socket for: MMM-Ratp
MMM-Ratp- NodeHelper started
Connecting socket for: MMM-SoccerLiveScore
MMM-SoccerLiveScore helper started...
Connecting socket for: MMM-soccer
Starting module: MMM-soccer
Connecting socket for: MMM-Remote-Control
Starting node helper for: MMM-Remote-Control
Connecting socket for: mmm-suncalc
Starting node_helper for mmm-suncalc:
Connecting socket for: MMM-WunderGround
MMM-WunderGround helper started ...
Connecting socket for: MMM-NOAA
Starting module: MMM-NOAA
Connecting socket for: MMM-Assistant
Connecting socket for: MMM-Tools
Starting module: newsfeed
Sockets connected &amp; modules started ...
Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXX/private-XXX/basic.ics - Interval: 300000
Get league table for url http://api.football-data.org/v1/competitions/450/leagueTable
GET_WUNDERGROUND
[ASSTNT] Snowboy Activated
Create new news fetcher for url: http://www.leparisien.fr/actualites-a-la-une.rss.xml#xtor=RSS-1481423633 - Interval: 300000
[ASSTNT] Assistant Activated
[ASSTNT] GA Transcription:  don't wanna meet you to do now
<p dir="auto">as well as my config file:</p>
<pre><code>		{
			module: "MMM-Assistant",
				assistant: {
				auth: {
				keyFilePath: "secret.json", //When you want to change the location of this file, set this.
				savedTokensPath: "resources/tokens.js" //When you want to change the location of this file, set this.
			audio: {
			encodingIn: "LINEAR16", //Ignore this. I think you don't need to change this.
			sampleRateOut: 16000 //Ignore this. I think you don't need to change this.
			snowboy: {
			models: [
			file: "resources/miroir.pmdl",
			sensitivity: 0.5,
			hotwords : "MIRROR" //One of models should be "MIRROR"
			file: "resources/Ok Google.pmdl",
			sensitivity: 0.5,
			record: {
			recordProgram: "arecord", //You can use "rec", "sox". But I recommend use "arecord".
			stt: {
			auth: [{
			projectId: "my-project-1505046981535", //ProjectId from Google Console
			keyFilename: "config.stt.auth.json"
			}], //You can use multi accounts for saving money.
			request: {
			encoding: "LINEAR16", //Ignore this. I think you don't need to change this.
			sampleRateHertz: 16000, //Ignore this. I think you don't need to change this.
			languageCode: "fr-FR" //See https://cloud.google.com/speech/docs/languages
			speak: {
			useAlert: true, //If you want to show the text of speech, set this true. But It could be ignored by command of modules directly.
			language: "fr-FR", //If you want to set the default language of speech of command result, set this.
			alias: [
			"help :command" : ["teach me :command", "what is :command"]
			] // You can use aliases for difficult pronunciation or easy using.
<p dir="auto">Hoping you can help me,</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.magicmirror.builders/post/33500</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33500</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Sun, 07 Jan 2018 13:09:40 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Sat, 06 Jan 2018 03:20:08 GMT]]></title><description><![CDATA[<p dir="auto">Just wanted to repost here, @sean thanks and got it going. This is an INCREDIBLE module and thank you. My problem was with my MIC after setup. If anyone else is coming across this, this link here helped to get my MIC setup properly:</p>
]]></description><link>https://forum.magicmirror.builders/post/33431</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33431</guid><dc:creator><![CDATA[shep99]]></dc:creator><pubDate>Sat, 06 Jan 2018 03:20:08 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Fri, 05 Jan 2018 20:23:52 GMT]]></title><description><![CDATA[<p dir="auto">Thanks very much @sean appreciated. I did re install, and ran google-auth then electron-rebuild. After that, I did have to rename the folders from electron-v1.4-linux-arm-{libc} to electron-v1.4-linux-arm-glibc and everything loaded! :) I created my own models smartmirror.pmdl, and snowboy.pmdl ) with snowboy from the RPI that is running MM with the MIC, and running the following two commands I can record and play back WAV files with arecord:</p>
<pre><code>arecord --device=plughw:1,0 --format S16_LE --rate 44100 -c1 test.wav
aplay --device=plughw:0,0 test.wav
<p dir="auto">When MM startups up, I can here an initial ding, but cannot trigger any key word detection for some reason? I was wondering if my config might be off? Below is my configuration:</p>
<pre><code>{
  module: 'MMM-Assistant',
  position: 'bottom_left',
    assistant: {
      auth: {
      audio: {
    snowboy: {
      models: [
          file: "resources/smartmirror.pmdl",
          sensitivity: 0.5,
          file: "resources/snowboy.pmdl",
          sensitivity: 0.5,
    record: {
    stt: {
      auth: [{
        projectId: 'smartmirror-XXXXX-REMOVED', //ProjectId from Google Console
        keyFilename: 'config.stt.auth.json'
      request: {
        encoding: 'LINEAR16', //Ignore this. I think you don't need to change this.
        languageCode: 'en-US' //See https://cloud.google.com/speech/docs/languages
    speak: {
      language: 'en-US', //If you want to set the default language of speech of command result, set this.
    alias: [
<p dir="auto">I am trying to activate using snowboy, smartmirror, assistant, google, etc but it never triggers.</p>
<p dir="auto">Thanks @sean really appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/post/33413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33413</guid><dc:creator><![CDATA[shep99]]></dc:creator><pubDate>Fri, 05 Jan 2018 20:23:52 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Fri, 05 Jan 2018 08:18:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shep99" aria-label="Profile: shep99">@<bdi>shep99</bdi></a><br />
Hmmm… This error might be derived from the various different versions of node.js of MM, Electron, Google API and other dependencies. MMM-Assistant should have many dependencies, so always the version problem makes me crazy. :(</p>
<p dir="auto">I’m not sure about your situation, but I think <code>google-auth</code> should be performed before <code>electron-rebuild</code>. because that authentification library uses the different version of modules with other dependencies. I think you’d better try re-install.</p>
]]></description><link>https://forum.magicmirror.builders/post/33378</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33378</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 05 Jan 2018 08:18:52 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Thu, 04 Jan 2018 21:23:25 GMT]]></title><description><![CDATA[<p dir="auto">Thank you @Sean appreciated! I tried that ( also tried the steps outlined here ) : <a href="https://github.com/eouia/MMM-Assistant/wiki/Urgent-Issue-on-installation" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-Assistant/wiki/Urgent-Issue-on-installation</a></p>
<p dir="auto">And after install Ihad two folders in <code>  /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/</code></p>
<p dir="auto">electron-v1.4-linux-arm-{libc}<br />
and<br />
node-v48-linux-arm-glibc</p>
<p dir="auto">I renamed the folder electron-v1.4-linux-arm-{libc} to electron-v1.7-linux-arm-glibc but when I run</p>
<pre><code>cd /modules/MMM-Assistant
node google-auth.js
<p dir="auto">I get the following error:</p>
<pre><code>pi@smartmirror1:~/MagicMirror/modules/MMM-Assistant $ node google-auth.js
module.js:597
  return process.dlopen(module, path._makeLong(filename));
Error: Module version mismatch. Expected 48, got 50.
    at Error (native)
    at Object.Module._extensions..node (module.js:597:18)
    at Module.load (module.js:487:32)
    at tryModuleLoad (module.js:446:12)
    at Function.Module._load (module.js:438:3)
    at Module.require (module.js:497:17)
    at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/node_modules/grpc/src/node/src/grpc_extension.js:38:15)
    at Module._compile (module.js:570:32)
    at Object.Module._extensions..js (module.js:579:10)
]]></description><link>https://forum.magicmirror.builders/post/33358</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33358</guid><dc:creator><![CDATA[shep99]]></dc:creator><pubDate>Thu, 04 Jan 2018 21:23:25 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Thu, 04 Jan 2018 16:57:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shep99" aria-label="Profile: shep99">@<bdi>shep99</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/acogkenf" aria-label="Profile: acogkenf">@<bdi>acogkenf</bdi></a></p>
<p dir="auto">If you go to <code>'/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/grpc/src/node/extension_binary/</code>, there might be some weird directory name which has <code>{something}</code>, then change it to <code>electron-v1.7-linux-arm-glibc</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/33338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33338</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Thu, 04 Jan 2018 16:57:05 GMT</pubDate></item><item><title><![CDATA[Reply to Assistant Error on Thu, 04 Jan 2018 16:45:58 GMT]]></title><description><![CDATA[<p dir="auto">I am also getting this error unfortunately… I beleive it might be due to this:</p>
<p dir="auto">“Currently under Electron 1.7, there might be non-compatible issues of grpc. I will make a patch for this, but it will take somewhat time. sorry.”</p>
]]></description><link>https://forum.magicmirror.builders/post/33336</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33336</guid><dc:creator><![CDATA[shep99]]></dc:creator><pubDate>Thu, 04 Jan 2018 16:45:58 GMT</pubDate></item></channel></rss>
