<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[newfeed is not updated.]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/5584/newfeed-is-not-updated</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 23:31:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5584.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Nov 2017 20:48:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to newfeed is not updated. on Fri, 24 Nov 2017 21:43:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wireshark" aria-label="Profile: wireshark">@<bdi>wireshark</bdi></a></p>
<p dir="auto">In most cases, this occurs when adding a newfeed. Have you added a newsfeed? Did the problem start afterwards? Does the default NY Times (by itself) exhibit this behavior?</p>
]]></description><link>https://forum.magicmirror.builders/post/31572</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31572</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 24 Nov 2017 21:43:24 GMT</pubDate></item></channel></rss>
