<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Run module]]></title><description><![CDATA[<p dir="auto">Good evening,<br />
do you know if there is a module running a command that runs an external program?<br />
I use the Carousel module and I would like to be able to insert a command in some slides that does something.</p>
<p dir="auto">Thank you, Alberto</p>
]]></description><link>https://forum.magicmirror.builders/topic/5591/run-module</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 07:00:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5591.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 26 Nov 2017 20:41:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Run module on Fri, 13 Apr 2018 11:31:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> Thanks for the quick reply!</p>
]]></description><link>https://forum.magicmirror.builders/post/38350</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38350</guid><dc:creator><![CDATA[autonomus]]></dc:creator><pubDate>Fri, 13 Apr 2018 11:31:24 GMT</pubDate></item><item><title><![CDATA[Reply to Run module on Thu, 12 Apr 2018 20:09:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/autonomus" aria-label="Profile: autonomus">@<bdi>autonomus</bdi></a> you can do that in the node_helper, it’s also already done by some modules</p>
<p dir="auto">e.g. <a href="https://nodejs.org/dist/latest-v8.x/docs/api/child_process.html#child_process_child_process_exec_command_options_callback" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/dist/latest-v8.x/docs/api/child_process.html#child_process_child_process_exec_command_options_callback</a></p>
]]></description><link>https://forum.magicmirror.builders/post/38327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38327</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Thu, 12 Apr 2018 20:09:39 GMT</pubDate></item><item><title><![CDATA[Reply to Run module on Thu, 12 Apr 2018 11:48:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Did you manage to solve this somehow? I’m trying to run a Linux command or script from inside a module.</p>
]]></description><link>https://forum.magicmirror.builders/post/38311</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/38311</guid><dc:creator><![CDATA[autonomus]]></dc:creator><pubDate>Thu, 12 Apr 2018 11:48:02 GMT</pubDate></item><item><title><![CDATA[Reply to Run module on Sat, 02 Dec 2017 22:53:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dasbooter" aria-label="Profile: dasbooter">@<bdi>dasbooter</bdi></a><br />
No  :(</p>
]]></description><link>https://forum.magicmirror.builders/post/31860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31860</guid><dc:creator><![CDATA[alverman]]></dc:creator><pubDate>Sat, 02 Dec 2017 22:53:45 GMT</pubDate></item><item><title><![CDATA[Reply to Run module on Sat, 02 Dec 2017 16:26:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alverman" aria-label="Profile: alverman">@<bdi>alverman</bdi></a></p>
<p dir="auto">I’m looking for someway to run a script. Did you have any luck</p>
]]></description><link>https://forum.magicmirror.builders/post/31844</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31844</guid><dc:creator><![CDATA[dasbooter]]></dc:creator><pubDate>Sat, 02 Dec 2017 16:26:07 GMT</pubDate></item></channel></rss>
