<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-RTSPStream]]></title><description><![CDATA[<p dir="auto">Trying to install that module, get the following results :</p>
<p dir="auto">MMM-RTSPStream@1.2.1 postinstall /home/pi/MagicMirror/modules/MMM-RTSPStream<br />
./install_sd_patch.sh &amp;&amp; sudo npm i -g http-server</p>
<p dir="auto">Applying Graceful Shutdown patch to MagicMirror.<br />
error: Anwendung des Patches fehlgeschlagen: js/electron.js:96<br />
error: js/electron.js: Patch konnte nicht angewendet werden</p>
<p dir="auto">npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):<br />
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})<br />
npm ERR! Linux 4.9.35-v7+<br />
npm ERR! argv “/usr/bin/node” “/usr/bin/npm” “install”<br />
npm ERR! node v6.12.0<br />
npm ERR! npm  v3.10.10<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! MMM-RTSPStream@1.2.1 postinstall: <code>./install_sd_patch.sh &amp;&amp; sudo npm i -g http-server</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the MMM-RTSPStream@1.2.1 postinstall script ‘./install_sd_patch.sh &amp;&amp; sudo npm i -g http-server’.<br />
npm ERR! Make sure you have the latest version of node.js and npm installed.<br />
npm ERR! If you do, this is most likely a problem with the MMM-RTSPStream package,<br />
npm ERR! not with npm itself.<br />
npm ERR! Tell the author that this fails on your system:<br />
npm ERR!     ./install_sd_patch.sh &amp;&amp; sudo npm i -g http-server<br />
npm ERR! You can get information on how to open an issue for this project with:<br />
npm ERR!     npm bugs MMM-RTSPStream<br />
npm ERR! Or if that isn’t available, you can get their info via:<br />
npm ERR!     npm owner ls MMM-RTSPStream<br />
npm ERR! There is likely additional logging output above.</p>
<p dir="auto">npm ERR! Please include the following file with any support request:<br />
npm ERR!     /home/pi/MagicMirror/modules/MMM-RTSPStream/npm-debug.log</p>
<p dir="auto">What I am supposed to do know ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/5613/mmm-rtspstream</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 15:05:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5613.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Dec 2017 12:44:56 GMT</pubDate><ttl>60</ttl></channel></rss>
