<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black Screen]]></title><description><![CDATA[<p dir="auto">RaspberryPi 3b, installing with the script on Github . Node version: 7.10.1 npm version :4.2.0</p>
<p dir="auto">When I use npm:start .Nothing <a href="http://happened.No" target="_blank" rel="noopener noreferrer nofollow ugc">happened.No</a> error ,but black screen. I use dev mod to check the web page,find  mistakes and errors in js. I tried a lot of ways .<br />
!</p>
]]></description><link>https://forum.magicmirror.builders/topic/5614/black-screen</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 05:18:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5614.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Dec 2017 13:55:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black Screen on Fri, 08 Dec 2017 12:32:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nyovelt" aria-label="Profile: Nyovelt">@<bdi>Nyovelt</bdi></a> said in <a href="/post/32106">Black Screen</a>:</p>
<p dir="auto">I have given it up</p>
<p dir="auto">Oh no, you should never give up. I’m sorry to hear that.</p>
<p dir="auto">Do you want to make one last attempt? It won’t take you very long. Less than 30 minutes! Most people have had success this way.</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners">https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners</a></p>
]]></description><link>https://forum.magicmirror.builders/post/32107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32107</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 08 Dec 2017 12:32:04 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen on Fri, 08 Dec 2017 12:20:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>  I have given it up… Since i need few features ,i just decide to use VB to programe a desktop version.</p>
]]></description><link>https://forum.magicmirror.builders/post/32106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32106</guid><dc:creator><![CDATA[Nyovelt]]></dc:creator><pubDate>Fri, 08 Dec 2017 12:20:48 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen on Sat, 02 Dec 2017 14:03:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nyovelt" aria-label="Profile: Nyovelt">@<bdi>Nyovelt</bdi></a></p>
<p dir="auto">Are you using Raspbian Jessie?</p>
<p dir="auto">Can you post your terminal output in a code block so we can have a look at it.</p>
]]></description><link>https://forum.magicmirror.builders/post/31832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31832</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 02 Dec 2017 14:03:45 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen on Sat, 02 Dec 2017 13:58:27 GMT]]></title><description><![CDATA[<p dir="auto">Uncaught refernce error inclock js<br />
Failed to load resource :the server responded with a status of 404</p>
<p dir="auto">and NO helper founders for modules</p>
]]></description><link>https://forum.magicmirror.builders/post/31831</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31831</guid><dc:creator><![CDATA[Nyovelt]]></dc:creator><pubDate>Sat, 02 Dec 2017 13:58:27 GMT</pubDate></item></channel></rss>
