<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror directory missing.]]></title><description><![CDATA[<p dir="auto">OK. I had Jessie running on a Pi3 from China.<br />
<code>Revision        : a22082</code></p>
<p dir="auto">Everything was running fine until I put it away for a couple months and then Jessie did an update and I got the blank screen error. I tried what I could, including rolling back electron etc.  but I couldn’t get rid of it.</p>
<p dir="auto">So, I saved my config files and kissed a few other node.js goodies I was using goodbye knowing I’d rebuild them better than before. So I installed a fresh image of Stretch and reinstalled MagicMirror. Still no joy so I tried pretty much anything I could think of or find on the net to help but still… blank screen.</p>
<p dir="auto">so. I tried again. this time things got actually weird.  I ran the install script and it seemed to work but I didn’t have a MagicMirror directory. So I ran the script again and got an error that said I already had an install and to either rename the directory or do a git pull inside the directory.</p>
<p dir="auto"><img src="http://dantodd.com/images/MagicMirrorDirectory.PNG" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">I’m sort of at an impasse. I can’t find anything to delete to make the script run again and I don’t REALLY want to do a fresh install of stretch.</p>
<p dir="auto">Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/5617/magicmirror-directory-missing</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 01:30:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5617.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Dec 2017 18:00:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror directory missing. on Sat, 02 Dec 2017 18:50:23 GMT]]></title><description><![CDATA[<p dir="auto">Well. After manually installing version 1.7.6 of electron and globally installing the coffee and lint nodes that the initial install complained about. I ran the manual install and everything seems to be working. I now have to add back my modules and see where we are.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/31850</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31850</guid><dc:creator><![CDATA[dantodd]]></dc:creator><pubDate>Sat, 02 Dec 2017 18:50:23 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror directory missing. on Sat, 02 Dec 2017 18:30:44 GMT]]></title><description><![CDATA[<p dir="auto">thanks. I’ll give that a shot. Or maybe I’ll see about installing a Jessie image. I just hate using old software due to potential security issues and breaking other, newer apps.</p>
]]></description><link>https://forum.magicmirror.builders/post/31848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31848</guid><dc:creator><![CDATA[dantodd]]></dc:creator><pubDate>Sat, 02 Dec 2017 18:30:44 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror directory missing. on Sat, 02 Dec 2017 20:11:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dantodd" aria-label="Profile: dantodd">@<bdi>dantodd</bdi></a> said in <a href="/post/31846">MagicMirror directory missing.</a>:</p>
<p dir="auto">FYI, Stretch has been problematic for a number of users in various circumstances. With that said, you could try downloading MM manually and moving it into that directory and see what happens, if anything. If it moves normally, and appears, you can run <code>npm install</code> in the new MM directory.</p>
<p dir="auto">Edit:</p>
<p dir="auto">Try doing the above in your GUI, rather than in your terminal, with the exception of <code>npm install</code> of course.</p>
]]></description><link>https://forum.magicmirror.builders/post/31847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31847</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 02 Dec 2017 20:11:51 GMT</pubDate></item></channel></rss>
