<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to find and use key commands in MM. For absolute beginners.]]></title><description><![CDATA[<h2>How to find and use key commands in MM. For absolute beginners.</h2>
<ul>
<li>Some very useful key commands that often go unnoticed in MM.</li>
</ul>
<p dir="auto">It is common enough that a new user will successfully install and run MM,<br />
only to be left wondering how to stop the MM process. Y’all know who you are. :^)</p>
<h2>The Alt key! And sometimes the Control key</h2>
<p dir="auto">There are so many different platforms and OS’s being used for MM, but in MOST cases<br />
the <strong>Alt</strong> key will drop a Menu Bar at the top of MM while it is running. From there<br />
you can execute a host of commands by clicking through the menus. Here I have<br />
provided the key commands that have been most useful to me. They don’t even require that<br />
you to press the Alt key. Simply execute the key command while MM is running.</p>
<h2>Simultaneously means at the same time ;^)</h2>
<ul>
<li>
<p dir="auto">Minimize MM = <strong>Control</strong> and <strong>M</strong></p>
</li>
<li>
<p dir="auto">Reload MM = <strong>Control</strong> and <strong>R</strong></p>
</li>
<li>
<p dir="auto">Open Dev Tools = <strong>Control</strong> and <strong>Shift</strong> and <strong>I</strong> (That’s an <strong>i</strong>)</p>
</li>
<li>
<p dir="auto">Default Display Size = <strong>Control</strong> and <strong>0</strong> (That’s a zero)</p>
</li>
<li>
<p dir="auto">Zoom In = <strong>Control</strong> and <strong>Shift</strong> and <strong>=</strong> (That’s an equals sign)</p>
</li>
<li>
<p dir="auto">Zoom Out = <strong>Control</strong> and <strong>-</strong> (That’s a dash/minus sign)</p>
</li>
<li>
<p dir="auto">Toggle Full Screen = <strong>F11</strong></p>
</li>
</ul>
<h2>Other “Absolute Beginner” tutorials</h2>
<h2>How to MANUALLY install MM on your Pi. For absolute beginners.</h2>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners">https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners</a></p>
<h2>How to create a working config. For absolute beginners.</h2>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners">https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners</a></p>
<h2>How to check your config for errors. For absolute beginners.</h2>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners">https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners</a></p>
<h2>How to add modules. For absolute beginners.</h2>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners">https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners</a></p>
<h2>How to post code on the forum. For absolute beginners.</h2>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners">https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners</a></p>
<h2>Install MagicMirror on a PC Windows 7/10 - Complete walkthrough</h2>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7">https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 00:46:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5619.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Dec 2017 21:22:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to find and use key commands in MM. For absolute beginners. on Wed, 19 Jun 2019 00:36:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/58067">How to find and use key commands in MM. For absolute beginners.</a>:</p>
<p dir="auto">never had to push shift too</p>
<p dir="auto">That is odd. My Pi mirror, running MM 2.1.0, requires the Shift key to Zoom In, but not out, as does my dev machine running MM 2.5.0 and Ubuntu 16.04 LTS. I just tested both. Go figure.</p>
]]></description><link>https://forum.magicmirror.builders/post/58068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58068</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 19 Jun 2019 00:36:01 GMT</pubDate></item><item><title><![CDATA[Reply to How to find and use key commands in MM. For absolute beginners. on Wed, 19 Jun 2019 00:01:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> never had to push shift too</p>
]]></description><link>https://forum.magicmirror.builders/post/58067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58067</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 19 Jun 2019 00:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to How to find and use key commands in MM. For absolute beginners. on Tue, 18 Jun 2019 21:20:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/58046">How to find and use key commands in MM. For absolute beginners.</a>:</p>
<p dir="auto">ctrl + will also zoom in steps, ctrl - reverses that</p>
<p dir="auto">Yes, <strong>Ctrl</strong> and <strong>-</strong> zooms out. However, I believe it’s <strong>Ctrl</strong> <strong>Shift</strong> <strong>+</strong> to zoom in. I have that listed above as <strong>Control</strong> and <strong>Shift</strong> and <strong>=</strong>. ( <strong>=</strong> and <strong>+</strong>, same key)</p>
]]></description><link>https://forum.magicmirror.builders/post/58065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58065</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 18 Jun 2019 21:20:04 GMT</pubDate></item><item><title><![CDATA[Reply to How to find and use key commands in MM. For absolute beginners. on Tue, 18 Jun 2019 02:29:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> ctrl + will also zoom in steps, ctrl - reverses that</p>
]]></description><link>https://forum.magicmirror.builders/post/58046</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58046</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Jun 2019 02:29:57 GMT</pubDate></item><item><title><![CDATA[Reply to How to find and use key commands in MM. For absolute beginners. on Tue, 18 Jun 2019 00:27:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brandonbrown" aria-label="Profile: brandonbrown">@<bdi>brandonbrown</bdi></a> asked about toggling fullscreen today so I thought I would bring this topic to the attention of those that may not know about it. Someone will find it useful, hopefully.</p>
]]></description><link>https://forum.magicmirror.builders/post/58045</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/58045</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 18 Jun 2019 00:27:40 GMT</pubDate></item></channel></rss>
