<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Wunderground - dates are off??]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a>  (thanks for the module!)<br />
I found this about a week ago: the dates that MMM-Wunderground displays info for are a day behind:<br />
<img src="/uploads/files/1472665976323-wundergroundoff.jpg" alt="0_1472665978330_WundergroundOff.JPG" class=" img-fluid img-markdown" /><br />
Notice how I took the screenshot on Wednesday (31 Aug), but the Wunderground forecast is for 11am, 5pm, 11pm, and then for Wednesday (ie Wunderground seems to think today is 30. Aug)??</p>
<p dir="auto">Wierd.</p>
<p dir="auto">Anyway, here is my minimal config.js to reproduce:</p>
<pre><code>var config = {
        port: 8080,
        language: 'en',
        timeFormat: 24,
        units: 'imperial',
                        module: 'clock',
                        position: 'top_left'
                        }, // closes module alert
                        module: 'MMM-WunderGround',
                        position: 'top_right',
                                apikey: 'xxxxxxxxxxx',
                                pws: 'WA/Kirkland',
                                lang: 'EN',
                                fctext: '1',
                                fcdaycount: "6",
                                fcdaystart: "0",
                                hourly: '1',
                                hourlyinterval: "6",
                                hourlycount: "1",
                                alerttime: 10000,
                                alerttruncatestring: "english:",
                                fade: true
                        } // closes config
                        }, // closes module MMM-WunderGround
                        ] // closes MODULES
<p dir="auto">I’m slightly baffled. Thanks for any help</p>
]]></description><link>https://forum.magicmirror.builders/topic/565/mmm-wunderground-dates-are-off</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 14:34:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/565.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 31 Aug 2016 18:08:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Sun, 18 Sep 2016 01:43:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a> can it be possible to add Moon Phase with animation and dates.</p>
]]></description><link>https://forum.magicmirror.builders/post/4953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4953</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Sun, 18 Sep 2016 01:43:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Sun, 18 Sep 2016 01:32:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a> said in <a href="/post/4938">MMM-Wunderground - dates are off??</a>:</p>
<p dir="auto">currentweather: 0,</p>
<p dir="auto">Thanks it worked .</p>
]]></description><link>https://forum.magicmirror.builders/post/4952</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4952</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Sun, 18 Sep 2016 01:32:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Sat, 17 Sep 2016 18:30:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shashank" aria-label="Profile: shashank">@<bdi>shashank</bdi></a> By pulling the new version off github and adding</p>
<pre><code>currentweather: 0,
<p dir="auto">to your config.</p>
]]></description><link>https://forum.magicmirror.builders/post/4938</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4938</guid><dc:creator><![CDATA[RedNax]]></dc:creator><pubDate>Sat, 17 Sep 2016 18:30:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Sat, 17 Sep 2016 15:36:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a> how i can remove the below mentioned display from the module</p>
<p dir="auto"><img src="/uploads/files/1474126589049-upload-a909da48-3429-47e4-92a3-07d07bec652f.png" alt="0_1474126570680_upload-a909da48-3429-47e4-92a3-07d07bec652f" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/4929</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4929</guid><dc:creator><![CDATA[shashank]]></dc:creator><pubDate>Sat, 17 Sep 2016 15:36:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Fri, 02 Sep 2016 04:19:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yo-less" aria-label="Profile: yo-less">@<bdi>yo-less</bdi></a>  :)<br />
Thx - will keep an eye out for things</p>
]]></description><link>https://forum.magicmirror.builders/post/4293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4293</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Fri, 02 Sep 2016 04:19:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Thu, 01 Sep 2016 21:38:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> Don’t give me any ideas, I’m burning the midnight oil as it stands :D. But I guess it would be quite a feat if the mirror reacted to my moods as well.</p>
<p dir="auto">I do want to share my tweaks and modifications, at the same time I’m aware that they are extremely tailored to my needs and likes. That’s why I need to make them customizable before it makes sense to post them online. Otherwise, people will just come back to me asking me to change this and that again, because they like certain features but not others. What it all boils down to: I need to clean up my code and make it mergeable with the main branch of the project so that <a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a> can simply incorporate my changes into the main module. I’ve promised myself I would to that in the next few days. At the same time, he’s just introcduced a nice new layout option and I need to incorporate that into my code lines first. It’s an uphill battle :D.</p>
<p dir="auto">You can find my fork of the MMM-WunderGround module <a href="https://github.com/yo-less/MMM-WunderGround" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>, feel free to check its state again after the weekend. I will also pot any notice  <a href="https://forum.magicmirror.builders/topic/128/weatherunderground-currently-hourly-daily-configurable/">here</a>, so maybe add the thread to your watchlist.</p>
]]></description><link>https://forum.magicmirror.builders/post/4288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4288</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Thu, 01 Sep 2016 21:38:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Thu, 01 Sep 2016 16:54:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yo-less" aria-label="Profile: yo-less">@<bdi>yo-less</bdi></a><br />
Woah - THATs why I like Linux hackers…  simple problem followed by a solution that is WAY OVER THE TOP  (and I mean that in the nicest possible way). Now there are probably setting to determine when the new day will start / how many days in advance / how to deal with Daylight-savings time etc. And since you stay up longer on Fridays and Saturdays than on the  other days, that is probably also taken care of. Come to think of it, maybe the facial recognition software will determine by your frown if the data are confusing or not and readjust  :)</p>
<p dir="auto">Care to share what you “tweaked”? I love it!</p>
]]></description><link>https://forum.magicmirror.builders/post/4275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4275</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Thu, 01 Sep 2016 16:54:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Wed, 31 Aug 2016 21:42:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> I see your point, I changed the config to start with the forecast for tomorrow as well, for the same reasons. Then I realized that after midnight the forecasts for the new day would not be shown, which I didn’t like, because the hourly forecasts only showed 1am, 4am, 7am and 10am, so I messed around with the source code so that it normally starts its forecasts with the weather tomorrow but between midnight and sunrise it still shows the forecast for the new day that is now day 0. After sunrise the first day that is shown in the forecast table is the next day. Not sure if I’m making any sense here :D</p>
]]></description><link>https://forum.magicmirror.builders/post/4240</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4240</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Wed, 31 Aug 2016 21:42:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Wed, 31 Aug 2016 21:36:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yo-less" aria-label="Profile: yo-less">@<bdi>yo-less</bdi></a><br />
See my problem - I was getting the hourly forecasts for  TODAY as well as the “daily” forecast for TODAY (which I considered superfluous). Setting  fcdaystart=1 simply removes todays “daily” forecast &amp; resulted exactly in what I wanted:<br />
today 3pm<br />
today 9pm<br />
tomorrow 3 am<br />
all day tomorrow<br />
all the day-after-tomorrow<br />
etc</p>
<p dir="auto">But tomorrow morning, I’ll see<br />
9am<br />
3pm<br />
9pm<br />
next day etc.</p>
]]></description><link>https://forum.magicmirror.builders/post/4239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4239</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Wed, 31 Aug 2016 21:36:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Wed, 31 Aug 2016 21:31:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> Does it make a difference in your forecast texts when you set fcdaystart = ‘1’?<br />
What you see should be the forecast text for the current conditions outside, no matter what day your forecasts start on.</p>
]]></description><link>https://forum.magicmirror.builders/post/4238</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4238</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Wed, 31 Aug 2016 21:31:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Tue, 27 Sep 2016 20:48:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> said in <a href="/post/4227">MMM-Wunderground - dates are off??</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a><br />
Ahh - I guess that makes sense (kind of). Have to admit that I thought I remembered it did hourly for today; then daily for the next few days. I’ll look through the config to “remove” the daily forecast for today &amp; post what I found.</p>
<p dir="auto">config.js:<br />
<code>fcdaystart = "1"</code></p>
<p dir="auto">Duh</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/4232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4232</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Tue, 27 Sep 2016 20:48:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Wed, 31 Aug 2016 20:36:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rednax" aria-label="Profile: RedNax">@<bdi>RedNax</bdi></a><br />
]]></description><link>https://forum.magicmirror.builders/post/4227</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4227</guid><dc:creator><![CDATA[amanzimdwini]]></dc:creator><pubDate>Wed, 31 Aug 2016 20:36:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Wunderground - dates are off?? on Wed, 31 Aug 2016 20:19:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amanzimdwini" aria-label="Profile: amanzimdwini">@<bdi>amanzimdwini</bdi></a> The module will display the hourrly data of today. Then the ‘day’ data will also display the outlook for today…(even when it’s almost over) So details and a summary for today… There could be an option to offset the day part…</p>
]]></description><link>https://forum.magicmirror.builders/post/4225</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4225</guid><dc:creator><![CDATA[RedNax]]></dc:creator><pubDate>Wed, 31 Aug 2016 20:19:11 GMT</pubDate></item></channel></rss>
