<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Did an update got errors and need help]]></title><description><![CDATA[<p dir="auto">Did as usually but got this errors.<br />
And i can not start the mirror.<br />
So rely need help on getting it to work again.</p>
<pre><code>npm ERR! Linux 4.9.20-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
npm ERR! node v6.10.2
npm ERR! npm  v3.10.10
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.1.3 start: `sh run-start.sh`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.1.3 start script 'sh run-start.sh'.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR!     sh run-start.sh
npm ERR!     npm bugs magicmirror
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls magicmirror
pi@magicpi:~/MagicMirror $
]]></description><link>https://forum.magicmirror.builders/topic/5737/did-an-update-got-errors-and-need-help</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 20:29:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5737.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Dec 2017 11:10:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Did an update got errors and need help on Mon, 18 Dec 2017 14:25:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a></p>
<p dir="auto">This will take you less than an hour and you’ll be up and running AND you won’t lose anything from your previous install</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners">https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners</a></p>
]]></description><link>https://forum.magicmirror.builders/post/32450</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32450</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 18 Dec 2017 14:25:05 GMT</pubDate></item><item><title><![CDATA[Reply to Did an update got errors and need help on Mon, 18 Dec 2017 04:17:42 GMT]]></title><description><![CDATA[<p dir="auto">No one how can assist?</p>
]]></description><link>https://forum.magicmirror.builders/post/32442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32442</guid><dc:creator><![CDATA[wizz]]></dc:creator><pubDate>Mon, 18 Dec 2017 04:17:42 GMT</pubDate></item></channel></rss>
