<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot access to MagicMirror despite IpWhiteList]]></title><description><![CDATA[<p dir="auto">Hi MagicMirror users,</p>
<p dir="auto">I have an issue.<br />
I can’t access to my brand new MagicMirror (other than localhost) despite having a proper IpWhiteList configuration.</p>
<p dir="auto">I’m building a small server on a tiny computer running Debian 9 (Stretch). The project is using it to control my home (Home Assistant), run MagicMirror in server mode, and maybe do some facial recognition later…</p>
<p dir="auto">I installed Home Assistant with no problem and can access to the web panel from another computer within my home network (so, fine… Everything is ok).</p>
<p dir="auto">Then, I installed and configured MagicMirror. It works without problem on my localhost.<br />
But unfortunately, I cannot access it elsewere using the IP of my server 192.168.X.X:8080.</p>
<p dir="auto">My IpWhiteList config is:</p>
<pre><code>var config = {
        port: 8080,
        ipWhitelist: [],
<p dir="auto">The CLI gives this:</p>
<pre><code>XXX@serveur:~/MagicMirror$ npm start
&gt; magicmirror@2.1.3 start /home/XXX/MagicMirror
&gt; sh run-start.sh
Gtk-Message: Failed to load module "canberra-gtk-module"
Starting MagicMirror: v2.1.3
Loading config ...
Loading module helpers ...
Module helper loaded: MMM-Paris-RATP-PG
Module helper loaded: MMM-cryptocurrency
Module helper loaded: MMM-WunderGround
Module helper loaded: MMM-Remote-Control
All module helpers loaded.
You're using a full whitelist configuration to allow for all IPs
Server started ...
Starting module: newsfeed
Connecting socket for: MMM-Paris-RATP-PG
Connecting socket for: MMM-cryptocurrency
Cryptocurrency module loaded!
Connecting socket for: MMM-WunderGround
MMM-WunderGround helper started ...
Connecting socket for: MMM-Remote-Control
Starting node helper for: MMM-Remote-Control
Sockets connected &amp; modules started ...
Launching application.
Create new calendar fetcher for url: https://calendar.google.com/calendar/XXX.ics - Interval: 300000
Create new news fetcher for url: http://www.lemonde.fr/rss/une.xml - Interval: 300000
GET_WUNDERGROUND
<p dir="auto">And chrome gives me this:</p>
<pre><code>Ce site est inaccessible
192.168.X.X n'autorise pas la connexion.
Effectuez une recherche Google sur 192 168 8080.
ERR_CONNECTION_REFUSED
<p dir="auto">I don’t have any deny access on the CLI or another error message.<br />
Do you have a clue to help me out?</p>
<p dir="auto">Thank you all</p>
]]></description><link>https://forum.magicmirror.builders/topic/5741/cannot-access-to-magicmirror-despite-ipwhitelist</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 08:38:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5741.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Dec 2017 23:09:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Sat, 23 Dec 2017 11:46:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">Problem solved with a new fresh install. Unfortunately, the issue came from me.<br />
From my config.js to be more accurate.</p>
<p dir="auto">My exact config.js was:</p>
	port: 8080,
	adress: "0.0.0.0",
	ipWhitelist: ["127.0.0.1", "192.168.1.1/24", "192.168.2.1/24", "192.168.2.100"], // Set [] to allow all IP addresses
<p dir="auto">My new and working one is the one Mykle1 gave me:</p>
        port: 8080,
        address: "0.0.0.0",
        ipWhitelist: [],
<p dir="auto">I assume it’s a coma mistake.<br />
Nothing to do with multi web server.</p>
<p dir="auto">Thank you again for your help.<br />
Best regards</p>
]]></description><link>https://forum.magicmirror.builders/post/32679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32679</guid><dc:creator><![CDATA[MrNonoss]]></dc:creator><pubDate>Sat, 23 Dec 2017 11:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Thu, 21 Dec 2017 02:24:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrnonoss" aria-label="Profile: MrNonoss">@<bdi>MrNonoss</bdi></a></p>
<p dir="auto">You’re welcome, mate.</p>
<p dir="auto">I agree. Install MM first and get your connection established. Let me know how you make out.</p>
]]></description><link>https://forum.magicmirror.builders/post/32539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32539</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 21 Dec 2017 02:24:30 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Wed, 20 Dec 2017 22:25:52 GMT]]></title><description><![CDATA[<p dir="auto">There’s no other option than deleting the installation folder.<br />
I tried, but, with no succes.</p>
<p dir="auto">I’m bored. Il will try to reinstall the whole things, starting by MM, testing --&gt; If Ok --&gt; Then Install Home Assistant and test again, it will give tips (I hope)</p>
<p dir="auto">Thank you again Mykle</p>
]]></description><link>https://forum.magicmirror.builders/post/32534</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32534</guid><dc:creator><![CDATA[MrNonoss]]></dc:creator><pubDate>Wed, 20 Dec 2017 22:25:52 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Wed, 20 Dec 2017 20:51:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrnonoss" aria-label="Profile: MrNonoss">@<bdi>MrNonoss</bdi></a></p>
<p dir="auto">If you remove or disable Home Assistant can you then connect to MagicMirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/32527</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32527</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Wed, 20 Dec 2017 20:51:00 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Wed, 20 Dec 2017 20:39:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I come back with a hint…<br />
There are two web server on my computer, but I didn’t installed any “Apache” or so, so I didn’t configured anything<br />
One is with Home Assistant (coded in Python) and the other one is the MagicMiror.</p>
<p dir="auto">Could it be a sort of conflict between these two?</p>
]]></description><link>https://forum.magicmirror.builders/post/32526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32526</guid><dc:creator><![CDATA[MrNonoss]]></dc:creator><pubDate>Wed, 20 Dec 2017 20:39:11 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Sun, 17 Dec 2017 16:42:56 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your quick reply.</p>
<p dir="auto">Nope, Home Assistant is using port 80</p>
]]></description><link>https://forum.magicmirror.builders/post/32417</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32417</guid><dc:creator><![CDATA[MrNonoss]]></dc:creator><pubDate>Sun, 17 Dec 2017 16:42:56 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Sun, 17 Dec 2017 16:18:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrnonoss" aria-label="Profile: MrNonoss">@<bdi>MrNonoss</bdi></a> said in <a href="/post/32413">Cannot access to MagicMirror despite IpWhiteList</a>:</p>
<p dir="auto">Thank you for your tip <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>, but unfortunately, it changed nothing.</p>
<p dir="auto">Ah, hmm. Are Home Assistant and MM accessing the same port?</p>
<p dir="auto">But looking at my CLI after launching MM, the end seems strange.<br />
Is it normal to stop like this?<br />
GET_WUNDERGROUND</p>
<p dir="auto">Yes, completely normal</p>
]]></description><link>https://forum.magicmirror.builders/post/32416</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32416</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 17 Dec 2017 16:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Sun, 17 Dec 2017 15:44:16 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for your tip <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>, but unfortunately, it changed nothing.</p>
Is it normal to stop like this?</p>
<pre><code>GET_WUNDERGROUND
]]></description><link>https://forum.magicmirror.builders/post/32413</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32413</guid><dc:creator><![CDATA[MrNonoss]]></dc:creator><pubDate>Sun, 17 Dec 2017 15:44:16 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot access to MagicMirror despite IpWhiteList on Sun, 17 Dec 2017 00:18:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrnonoss" aria-label="Profile: MrNonoss">@<bdi>MrNonoss</bdi></a> said in <a href="/post/32384">Cannot access to MagicMirror despite IpWhiteList</a>:</p>
<p dir="auto">var config = {<br />
port: 8080,<br />
ipWhitelist: [],</p>
<p dir="auto">Try this:</p>
        port: 8080,
        address: "0.0.0.0",
        ipWhitelist: [],
]]></description><link>https://forum.magicmirror.builders/post/32389</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32389</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 17 Dec 2017 00:18:50 GMT</pubDate></item></channel></rss>
