<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror connecting problem..]]></title><description><![CDATA[<p dir="auto">hi, I am starter of MagicMirror2.<br />
i want to connect with my own application (Android studio) with my mm2. but my application failed to connecting.<br />
Logcat (from android studio) told that  java.net.ConnectException: failed to connect to /192.x.x.x (port 8080): connect failed: ECONNREFUSED (Connection refused)<br />
i don’t know why it is…<br />
could you help me …</p>
<p dir="auto">thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/5744/magicmirror-connecting-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 03:21:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5744.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Dec 2017 13:51:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror connecting problem.. on Tue, 19 Dec 2017 02:26:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahnim" aria-label="Profile: ahnim">@<bdi>ahnim</bdi></a> said in <a href="/post/32466">MagicMirror connecting problem..</a>:</p>
<p dir="auto">OH!!!  thank you so much! I followed your tips, and  i resolved it…!</p>
<p dir="auto">That is good news, mate. Enjoy your mirror. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/32467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32467</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 19 Dec 2017 02:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror connecting problem.. on Tue, 19 Dec 2017 02:18:20 GMT]]></title><description><![CDATA[<p dir="auto">OH!!!  thank you so much! I followed your tips, and  i resolved it…!<br />
the problem is about access to the connection.<br />
Thank you so, so much.<br />
i’m deeply greatful to you for your help!<br />
i hope to have a good day!!! :D</p>
]]></description><link>https://forum.magicmirror.builders/post/32466</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32466</guid><dc:creator><![CDATA[ahnim]]></dc:creator><pubDate>Tue, 19 Dec 2017 02:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror connecting problem.. on Mon, 18 Dec 2017 21:57:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahnim" aria-label="Profile: ahnim">@<bdi>ahnim</bdi></a> said in <a href="/post/32456">MagicMirror connecting problem..</a>:</p>
<p dir="auto">what can i do for “ACCESS DENIED”  in mm2?</p>
<p dir="auto">I am not sure I know what you mean. You get an  “ACCESS DENIED” message when trying to connect to MM2 from another device on the same network?</p>
<p dir="auto">In that case:<br />
<strong>EXAMPLE</strong></p>
<p dir="auto">This is the very beginning of my config.js file on the machine running MM2.</p>
<pre><code>var config = {
	address: "0.0.0.0",
	port: 8080,
	ipWhitelist: [],
<p dir="auto">Then, on another device on your network that has a browser (PC, MAC, laptop, cell phone on wifi, etc), Open the browser and enter the ip address of the machine/device that MM2 is running on. I used my iPhone as an example here, using the Safari browser.<br />
I entered the address <code>192.168.1.20:8080</code> into the Safari browser. That’s the address of my MM2 mirror.<br />
<img src="/assets/uploads/files/1513634181698-11.png" alt="0_1513634157368_11.png" class="img-markdown  img-fluid" /></p>
<p dir="auto">If this does not work for you then something else is going on there</p>
]]></description><link>https://forum.magicmirror.builders/post/32462</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32462</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 18 Dec 2017 21:57:07 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror connecting problem.. on Mon, 18 Dec 2017 18:37:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> oh i resolve it.  your example is so helpful to me. i really thank you.<br />
i was confused about that address number. .<br />
but can i ask one more question?<br />
what can i do for “ACCESS DENIED”  in mm2?  i resolve “NOT FOUND” problem but i have a “ACCESS DENIED” problem…</p>
<p dir="auto">really thank you for your replying TT</p>
]]></description><link>https://forum.magicmirror.builders/post/32456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32456</guid><dc:creator><![CDATA[ahnim]]></dc:creator><pubDate>Mon, 18 Dec 2017 18:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror connecting problem.. on Mon, 18 Dec 2017 14:10:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahnim" aria-label="Profile: ahnim">@<bdi>ahnim</bdi></a> said in <a href="/post/32398">MagicMirror connecting problem..</a>:</p>
<p dir="auto">192.x.x.x (port 8080):</p>
<p dir="auto">Make sure you have the correct address of the device that is running the MM software and that MM is running.</p>
<p dir="auto">Then, the proper format for the address would be</p>
<p dir="auto"><strong>EXAMPLE</strong></p>
<p dir="auto"><code>192.168.1.100:8080</code></p>
]]></description><link>https://forum.magicmirror.builders/post/32448</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32448</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 18 Dec 2017 14:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror connecting problem.. on Mon, 18 Dec 2017 07:16:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> thanks to your reply, i tried it.<br />
but this time, the error says “NOT FOUND 404”…<br />
i have tried a lot. but every time says ‘NOT FOUND 404’.<br />
if you know about it, could you tell me what to do…?<br />
Thank you very much!</p>
]]></description><link>https://forum.magicmirror.builders/post/32443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32443</guid><dc:creator><![CDATA[ahnim]]></dc:creator><pubDate>Mon, 18 Dec 2017 07:16:16 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror connecting problem.. on Sun, 17 Dec 2017 14:35:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahnim" aria-label="Profile: ahnim">@<bdi>ahnim</bdi></a></p>
<p dir="auto">Try this at the beginning of your config.js for MM:</p>
	address: "0.0.0.0",
	port: 8080,
	ipWhitelist: [],
]]></description><link>https://forum.magicmirror.builders/post/32405</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32405</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 17 Dec 2017 14:35:00 GMT</pubDate></item></channel></rss>
