<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cant get magicmirror to show up on screen]]></title><description><![CDATA[<p dir="auto">Hey there,</p>
<p dir="auto">i have completed all the steps in order to configure the rasp pi to run magicmirror but after running “pm2 start <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a>” as on the guideline, the only thing I get is a terminal message approving that mm is running but it does not boot up.</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/579/cant-get-magicmirror-to-show-up-on-screen</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 15:10:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/579.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Sep 2016 17:14:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 22:25:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lysnikolaou" aria-label="Profile: lysnikolaou">@<bdi>lysnikolaou</bdi></a> Welcome to the world of MagicMirror² :)</p>
]]></description><link>https://forum.magicmirror.builders/post/4351</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4351</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 22:25:49 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 22:21:43 GMT]]></title><description><![CDATA[<p dir="auto">It finally worked for me, after reinstalling raspbian. Thanks you everyone for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/4350</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4350</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 22:21:43 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 21:33:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kula" aria-label="Profile: kula">@<bdi>kula</bdi></a> Great to know it’s working for you. Use PM2, it makes sure your mirror stays up and running and doesn’t stop at some stage. It also provides logs that can help troubleshoot potential mirror problems.</p>
]]></description><link>https://forum.magicmirror.builders/post/4347</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4347</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 21:33:46 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 21:32:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yo-less" aria-label="Profile: yo-less">@<bdi>yo-less</bdi></a> thanks, it works. I’m just getting into it and followed up the tutorial strawberry 3.141 mentioned before - with the difference that I used ssh :)<br />
now I’m going to read about the PM2 thing.</p>
]]></description><link>https://forum.magicmirror.builders/post/4346</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4346</guid><dc:creator><![CDATA[kula]]></dc:creator><pubDate>Fri, 02 Sep 2016 21:32:32 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 21:25:34 GMT]]></title><description><![CDATA[<p dir="auto">Then you’re not experiencing the same problem. What you are describing is normal behavior.</p>
<p dir="auto">If you use SSH, the Pi doesn’t know what monitor it should use, since you’re sitting in front of another monitor, so your command should be:</p>
<pre><code>DISPLAY=:0 npm start
<p dir="auto">Try that, it should work without problems.</p>
<p dir="auto">Everything is also explained <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">here </a>.</p>
<p dir="auto">Why aren’t you using PM2 to run the mirror?</p>
]]></description><link>https://forum.magicmirror.builders/post/4344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4344</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 21:25:34 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 21:21:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yo-less" aria-label="Profile: yo-less">@<bdi>yo-less</bdi></a> sorry, npm start</p>
]]></description><link>https://forum.magicmirror.builders/post/4343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4343</guid><dc:creator><![CDATA[kula]]></dc:creator><pubDate>Fri, 02 Sep 2016 21:21:53 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 21:21:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kula" aria-label="Profile: kula">@<bdi>kula</bdi></a> What command are you talking about?</p>
]]></description><link>https://forum.magicmirror.builders/post/4342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4342</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 21:21:05 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 21:18:32 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone,<br />
I have the same problem. Via ssh I get the same error. But using the same command in the terminal on the pi then it is working. I’m confused…</p>
]]></description><link>https://forum.magicmirror.builders/post/4341</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4341</guid><dc:creator><![CDATA[kula]]></dc:creator><pubDate>Fri, 02 Sep 2016 21:18:32 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 20:06:39 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot to both of you. I will inform you about the results, as soon as I have it done.</p>
]]></description><link>https://forum.magicmirror.builders/post/4340</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4340</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 20:06:39 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 20:05:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lysnikolaou" aria-label="Profile: lysnikolaou">@<bdi>lysnikolaou</bdi></a> Unfortunately, I have no experience with the automatic installation because it isn’t supported for my hardware setup. But it seems to be the best way of going about it and the instructions in the link @strawberry-3-141 has posted is the way to go, <a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a> has put a lot of energy into it and if you follow it closely, I’d be surprised if you still ran into trouble.</p>
]]></description><link>https://forum.magicmirror.builders/post/4339</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4339</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 20:05:26 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 20:02:51 GMT]]></title><description><![CDATA[<p dir="auto">i did it like this on several pi’s now and never had issues <a href="https://forum.magicmirror.builders/topic/236/complete-setup-tutorial">https://forum.magicmirror.builders/topic/236/complete-setup-tutorial</a></p>
]]></description><link>https://forum.magicmirror.builders/post/4338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4338</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 02 Sep 2016 20:02:51 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 20:01:35 GMT]]></title><description><![CDATA[<p dir="auto">I will certainly let you know. Do you think that it would be better to run the automatic installation command or manually install nodejs, clone the rep and the install npm?</p>
]]></description><link>https://forum.magicmirror.builders/post/4337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4337</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 20:01:35 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 19:53:16 GMT]]></title><description><![CDATA[<p dir="auto">Then do it again, since you’re only just starting, you will only lose an hour or so and hopefully end up with a working system. This way you can ensure you have a working mirror that is fun to configure. At this stage you’re having problems with it starting up, who knows what other problems might be lurking in the darker corners of your Raspbian installation. Just make sure you grab the latest Raspbian image when reinstalling.</p>
<p dir="auto">Let us know whether it worked the second time round.</p>
]]></description><link>https://forum.magicmirror.builders/post/4336</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4336</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 19:53:16 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 19:50:13 GMT]]></title><description><![CDATA[<p dir="auto">No, only this, but I first followed wrong instructions and installed unnecessary software that might have somehow affected the other installations.</p>
]]></description><link>https://forum.magicmirror.builders/post/4335</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4335</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 19:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 19:38:53 GMT]]></title><description><![CDATA[<p dir="auto">That might be the best way of going about it if you are only planning on using the Pi for the Magic Mirror.<br />
Did you start out with a brand new Pi or did you install some other software on it as well?</p>
]]></description><link>https://forum.magicmirror.builders/post/4334</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4334</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 19:38:53 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 19:18:27 GMT]]></title><description><![CDATA[<p dir="auto">I had done just that, even before your post. And when i run nodejs -v it outputs v6… which is just fine. I don’t know, maybe I will reinstall raspbian and start it all over again</p>
]]></description><link>https://forum.magicmirror.builders/post/4330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4330</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 19:18:27 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 19:02:47 GMT]]></title><description><![CDATA[<p dir="auto">Hm, like I said, anything I’m suggesting at this stage is purely experimental as I have no experience with setting up the MagicMirror electron environment, but you could try upgrading your node installation.</p>
<p dir="auto">Please only do that if you are willing to set up your Pi all over again (Reinstalling Raspbian, etc.) should this fail, because it’s hardly ever a good idea to turn your system into a patchwork project.</p>
<p dir="auto">Someone at <a href="http://stackexchange.com" target="_blank" rel="noopener noreferrer nofollow ugc">stackexchange.com</a> said this helped them in installing Node.js on their Pi 3:</p>
<pre><code>curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
sudo apt-get install -y nodejs
sudo apt-get install -y build-essential
<p dir="auto">Source: <a href="http://raspberrypi.stackexchange.com/questions/45319/install-newer-node-version-on-pi-3" target="_blank" rel="noopener noreferrer nofollow ugc">http://raspberrypi.stackexchange.com/questions/45319/install-newer-node-version-on-pi-3</a></p>
<p dir="auto">If you’re not willing to reinstall everything, should this compromise your Raspbian setup, I would suggest waiting for other forum members’ suggestions on how to proceed.</p>
]]></description><link>https://forum.magicmirror.builders/post/4329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4329</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 19:02:47 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 18:49:35 GMT]]></title><description><![CDATA[<p dir="auto">I get an error every time. Both with npm install electron and by reinstalling the whole package. I dont get what the error is but it seems to be with nodejs.</p>
]]></description><link>https://forum.magicmirror.builders/post/4328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4328</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 18:49:35 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 18:39:16 GMT]]></title><description><![CDATA[<p dir="auto">This would mean that there seems to be a problem with your electron installation. Since you’ve got a Pi 3, I would try to get that fixed, it’s much easier to have the mirror act the way you want it to if the kiosk mode comes up automatically. I’m running the mirror on a Pi 1 and it took me forever to get everything set up so that the system boots into the mirror, I had to make sure the browser didn’t start too early, and so on. It requires many manual modifications and I’m almost certain that’s not the path you want to take :).</p>
<p dir="auto">Your mirror installation is not properly set up, I would try to fix that.</p>
<p dir="auto">I’m not sure if the problem on your system is electron or the mirror installation, as I’m not able to use electron on my Pi I have no experience with using it. But you can try going to your MagicMirror folder and typing in: “npm install electron”, this may set things right.</p>
<p dir="auto">If it doesn’t, maybe try a reinstall.</p>
]]></description><link>https://forum.magicmirror.builders/post/4327</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4327</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 18:39:16 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 18:33:48 GMT]]></title><description><![CDATA[<p dir="auto">Ok it is now working.<br />
I will now try to enable kioskmode.</p>
]]></description><link>https://forum.magicmirror.builders/post/4326</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4326</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 18:33:48 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 18:33:07 GMT]]></title><description><![CDATA[<p dir="auto">Ok, there might be a problem with your electron installation.<br />
Can you go into your MagicMirror folder and type “node serveronly”?</p>
<p dir="auto">Then, go back to your browser window and type in “localhost:8080”</p>
]]></description><link>https://forum.magicmirror.builders/post/4325</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4325</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 18:33:07 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 18:19:55 GMT]]></title><description><![CDATA[<p dir="auto">I get a whole bunch of errors, but the output tells me that I either have wrong versions of nodejs or npm or the magicmirror package itself is the one to blame. After that comes the message that electron js/electron.js fails<br />
Here is the log file that need to be submitted according to the log output:</p>
<p dir="auto">0 info it worked if it ends with ok<br />
1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]<br />
2 info using npm@3.10.3<br />
3 info using node@v6.5.0<br />
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]<br />
5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0<br />
6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing<br />
7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0<br />
8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true<br />
9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games<br />
10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror<br />
11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]<br />
12 info lifecycle magicmirror@2.0.0~start: Failed to exec start script<br />
13 verbose stack Error: magicmirror@2.0.0 start: <code>electron js/electron.js</code><br />
13 verbose stack spawn ENOENT<br />
13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)<br />
13 verbose stack     at emitTwo (events.js:106:13)<br />
13 verbose stack     at ChildProcess.emit (events.js:191:7)<br />
13 verbose stack     at maybeClose (internal/child_process.js:877:16)<br />
13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)<br />
14 verbose pkgid magicmirror@2.0.0<br />
15 verbose cwd /home/pi/MagicMirror<br />
16 error Linux 4.4.13-v7+<br />
17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”<br />
18 error node v6.5.0<br />
19 error npm  v3.10.3<br />
20 error file sh<br />
21 error code ELIFECYCLE<br />
22 error errno ENOENT<br />
23 error syscall spawn<br />
24 error magicmirror@2.0.0 start: <code>electron js/electron.js</code><br />
24 error spawn ENOENT<br />
25 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.<br />
25 error Make sure you have the latest version of node.js and npm installed.<br />
25 error If you do, this is most likely a problem with the magicmirror package,<br />
25 error not with npm itself.<br />
25 error Tell the author that this fails on your system:<br />
25 error     electron js/electron.js<br />
25 error You can get information on how to open an issue for this project with:<br />
25 error     npm bugs magicmirror<br />
25 error Or if that isn’t available, you can get their info via:<br />
25 error     npm owner ls magicmirror<br />
25 error There is likely additional logging output above.<br />
26 verbose exit [ 1, true ]</p>
]]></description><link>https://forum.magicmirror.builders/post/4324</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4324</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 18:19:55 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 18:12:57 GMT]]></title><description><![CDATA[<p dir="auto">What information comes up when you enter “pm2 logs mm” in the terminal window?</p>
]]></description><link>https://forum.magicmirror.builders/post/4323</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4323</guid><dc:creator><![CDATA[yo-less]]></dc:creator><pubDate>Fri, 02 Sep 2016 18:12:57 GMT</pubDate></item><item><title><![CDATA[Reply to cant get magicmirror to show up on screen on Fri, 02 Sep 2016 18:11:41 GMT]]></title><description><![CDATA[<p dir="auto">I get the “this site cant be reached” error</p>
]]></description><link>https://forum.magicmirror.builders/post/4322</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4322</guid><dc:creator><![CDATA[lysnikolaou]]></dc:creator><pubDate>Fri, 02 Sep 2016 18:11:41 GMT</pubDate></item></channel></rss>
