<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[costum.css  modified but font color still the same]]></title><description><![CDATA[<p dir="auto">Hi everybody</p>
<p dir="auto">i have installed mi MagicMirror since a few weeks and i try to change the font color of the compliments module.<br />
As far i know i have to write it in the custom.css and i did , but the color is still the same.<br />
Not sure what is the problem and thought somebody can help me.</p>
<p dir="auto">My config.js:</p>
<pre><code>
var config = {
	port: 8080,
	language: "de",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			displaySeconds: false,
			showWeek: true
			header: "Private ",
						symbol: "calendar-check-o ",
						url: "xxx"
			header: "Geburtstage",
						symbol: "calendar-check-0 ",
						url: "xxx"
			module: "currentweather",
				locationID: xxxx
			module: "weatherforecast",
			header: "Wetter   ",
				locationID: "xxx",  //ID from http://www.openweathermap.org/help/city_list.txt
				appid: "xx"
                        module: "compliments",
                        position: "lower_third"
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "xxx",
						url: "xxxl"
				showSourceTitle: true,
				showPublishDate: true,
				reloadInterval: "30000",
				updateIntervall: "400000"
<p dir="auto">#################################################################################</p>
<p dir="auto">My main.css</p>
<pre><code>html {
  cursor: none;
  overflow: hidden;
  background: #000;
::-webkit-scrollbar {
  display: none;
body {
  margin: 0px;
  position: absolute;
  height: calc(100% - 0px);
  width: calc(100% - 0px);
  background: #000;
  color: #aaa;
  font-family: "Roboto Condensed", sans-serif;
  font-weight: 400;
  font-size: 2em;
  line-height: 1.5em;
  -webkit-font-smoothing: antialiased;
 * Default styles.
.dimmed {
  color: #fff;
.normal {
  color: #fff;
.bright {
  color: #fff;
.xsmall {
  font-size: 20px;
  line-height: 20px;
.small {
  font-size: 25px;
  line-height: 25px;
.medium {
  font-size: 35px;
  line-height: 35px;
.large {
  font-size: 65px;
  line-height: 65px;
.xlarge {
  font-size: 70px;
  line-height: 75px;
  letter-spacing: -3px;
.thin {
  font-family: Roboto, sans-serif;
  font-weight: 100;
.light {
  font-weight: 300;
.regular {
  font-weight: 400;
.bold {
  font-weight: 700;
.align-right {
  text-align: right;
.align-left {
  text-align: left;
header {
  text-transform: uppercase;
  font-size: 20px;
  font-family: "Roboto Condensed";
  font-weight: 400;
  border-bottom: 1px solid #666;
  line-height: 15px;
  padding-bottom: 5px;
  margin-bottom: 10px;
  color: #fff;
sup {
  font-size: 50%;
  line-height: 50%;
 * Module styles.
.module {
  margin-bottom: 30px;
.region.bottom .module {
  margin-top: 35px;
  margin-bottom: 0;
.no-wrap {
  white-space: nowrap;
  overflow: hidden;
  text-overflow: ellipsis;
 * Region Definitions.
.region {
  position: absolute;
.region.fullscreen {
  position: absolute;
  top: -0px;
  left: -0px;
  right: -0px;
  bottom: -0px;
  pointer-events: none;
.region.fullscreen * {
  pointer-events: auto;
.region.right {
  right: 0;
.region.top {
  top: 0;
.region.top .container {
.region.top .container:empty {
  margin-bottom: 0;
.region.top.center,
.region.bottom.center {
  left: 50%;
  -moz-transform: translateX(-50%);
  -o-transform: translateX(-50%);
  -webkit-transform: translateX(-50%);
  -ms-transform: translateX(-50%);
.region.top.right,
.region.top.left,
.region.top.center {
  top: 100%;
.region.bottom {
  bottom: 0;
.region.bottom .container {
  background : #000;
  margin-top: 20px;
  margin-bottom: 0px;
.region.bottom .container:empty {
  margin-top: 0;
.region.bottom.right,
.region.bottom.center,
.region.bottom.left {
  bottom: 100%;
.region.bar {
  width: 100%;
  text-align: center;
.region.third,
.region.middle.center {
   width: 100%;
  text-align: center;
  -moz-transform: translateY(-50%);
  -o-transform: translateY(-50%);
  -webkit-transform: translateY(-50%);
  -ms-transform: translateY(-50%);
.region.upper.third {
  top: 33%;
  top: 66%;
.region.lower.third {
  top: 85%;
.region.left {
  text-align: left;
.region.right {
  text-align: right;
.region table {
  width: 100%;
  border-spacing: 0;
  border-collapse: separate;
<p dir="auto">####################################################################</p>
<p dir="auto">my custom.css</p>
<pre><code>/*****************************************************
 * Magic Mirror                                      *
 * Custom CSS                                        *
 * By Michael Teeuw http://michaelteeuw.nl           *
 * MIT Licensed.                                     *
 * Add any custom CSS below.                         *
 * Changes to this files will be ignored by GIT. *
 body {
.compliments {
 color: #ff0000;
.newsfeed {
color:#82bae5;
<p dir="auto">##########################################################################</p>
<p dir="auto">i have no clue what happens and why it is not working.</p>
<p dir="auto">Any idea ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/5811/costum-css-modified-but-font-color-still-the-same</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 20:57:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5811.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Dec 2017 21:36:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to costum.css  modified but font color still the same on Thu, 12 Mar 2020 15:23:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hellonoonan" aria-label="Profile: Hellonoonan">@<bdi>Hellonoonan</bdi></a> said in <a href="/post/70499">costum.css modified but font color still the same</a>:</p>
<p dir="auto">.brightb {<br />
color: #fff;<br />
}</p>
<p dir="auto">Maybe this?</p>
<pre><code>.bright {
color: #fff;
<p dir="auto">without the b?</p>
]]></description><link>https://forum.magicmirror.builders/post/70525</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70525</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 12 Mar 2020 15:23:13 GMT</pubDate></item><item><title><![CDATA[Reply to costum.css  modified but font color still the same on Thu, 12 Mar 2020 15:21:37 GMT]]></title><description><![CDATA[<p dir="auto">What is the solution to this? I am having the same issue so I didnt want to create a new topic.</p>
<p dir="auto">Here is my custom.css.  Office hours remain Blue and Id like to change the color as Ive changed the background image and they are now drowned out.</p>
 * Magic Mirror                                      *
 * Custom CSS                                        *
 * MIT Licensed.                                     *
body {#
.region.fullscreen.below {
  background-image: url('image.jpg');
  background-repeat: no-repeat;
  background-size: cover;
  margin: 5px;
  position: absolute;
  height: calc (50% - 0px);
  width: calc (50% - 0px);
  font-weight: 400;
  font-size: 2em;
  line-height: 1.5em;
.brightb {
color: #fff;
.currentweather .wi-sunrise {
color: #ffd700;
.currentweather .wi-sunset {
color: #ffa500;
.currentweather .wi-day-sunny {
color: #ffff00;
.currentweather .wi-night-showers {
color: #55acee;
.currentweather .wi-degrees {
color: #fff;
.currentweather .wi-rain {
color: #55acee;
.currentweather .wi-showers {
color: #55acee;
color: #55acee;
.currentweather .wi-night-alt-cloudy-windy {
color: #aaa;
.currentweather .wi-night-cloudy {
color: #aaa;
.currentweather .wi-cloudy {
color: #aaa;
.currentweather .wi-day-cloudy {
color: #aaa;
color: #aaa;
.currentweather .wi-cloudy-windy {
color: #aaa;
color: #55acee;
.currentweather .wi-thunderstorm {
color: #ff00ff;
.currentweather .wi-snow {
color: #fff;
.currentweather .wi-fog {
color: #999;
.currentweather .wi-night-clear {
color: #fff;
.currentweather .wi-night-rain {
color: #55acee;
.currentweather .wi-night-thunderstorm {
color: #ff00ff;
.currentweather .wi-night-snow {
color: #fff;
.weatherforecast .wi-sunrise {
color: #ffd700;
.weatherforecast .wi-sunset {
color: #ffa500;
.weatherforecast .wi-day-sunny {
color: #ffff00;
.weatherforecast .wi-night-showers {
color: #55acee;
.weatherforecast .wi-degrees {
color: #fff;
.weatherforecast .wi-rain {
color: #55acee;
.weatherforecast .wi-showers {
color: #55acee;
color: #55acee;
.weatherforecast .wi-night-alt-cloudy-windy {
color: #aaa;
.weatherforecast .wi-night-cloudy {
color: #aaa;
.weatherforecast .wi-cloudy {
color: #aaa;
.weatherforecast .wi-day-cloudy {
color: #aaa;
color: #aaa;
.weatherforecast .wi-cloudy-windy {
color: #aaa;
color: #55acee;
.weatherforecast .wi-thunderstorm {
color: #ff00ff;
.weatherforecast .wi-snow {
color: #fff;
.weatherforecast .wi-fog {
color: #999;
.weatherforecast .wi-night-clear {
color: #fff;
.weatherforecast .wi-night-rain {
color: #55acee;
.weatherforecast .wi-night-thunderstorm {
color: #ff00ff;
color: #fff;
.compliments .bright {
color : #fff;
font-size: 30px;
.calendar_monthly #yearDigits {
	color: #fff;
	font-weight: normal;
.calendar_monthly #monthName {
.calendar_monthly #monthName:after {
	content: " •";
	color: #fff;
	font-weight: bold;
.calendar_monthly .monthPrev {
	color: #fff;
.calendar_monthly .monthNext {
	color: #fff;
.calendar_monthly .square-box {
	position: relative;
	width: 85%;
	overflow: hidden;
	margin: 0px auto;
.calendar_monthly .square-box:before {
	content: "";
	display: custom;
	padding-top: 20%;
.calendar_monthly .square-content {
	top: 0;
	left: 0;
	bottom: 0;
	right: 0;
.calendar_monthly .square-content .today {
	border: 3px solid #80ff00;
	font-weight: light;
	color: #7dcfff;
.calendar_monthly .square-content div {
	display: table;
	width: 100%;
	height: 100%;
.calendar_monthly {
    color: #fff;
.calendar_monthly2 #yearDigits {
color: #fff;
.calendar_monthly2 #monthName {
.calendar_monthly2 #monthName:after {
content: " •";
color: #80ff00;
font-weight: bold;
.calendar_monthly2 .monthPrev {
color: #333333;
.calendar_monthly2 .monthNext {
color: #333333;
.calendar_monthly2 .square-box {
position: relative;
width: 50%;
overflow: hidden;
margin: 0px auto;
.calendar_monthly2 .square-box:before {
content: “”;
display: block;
padding-top: 20%;
.calendar_monthly2 .square-content {
top: 0;
left: 0;
bottom: 0;
right: 0;
.calendar_monthly2 .square-content .today {
border: 1px solid #80ff00;
color: #80ff00;
.calendar_monthly2 .square-content div {
display: table;
width: 100%;
height: 100%;
.calendar_monthly2 .square-content span {
display: table-cell;
text-align: center;
vertical-align: middle;
.clock .date {
    color: #fff;
.normal {
  color: #999;
.bright {
  color: #fff;
	text-align: center;
.OfficeHours .bright {
text-align: left;
color: #fff;
font-size: 40px;
header {
    text-transform: none;
    font-size: 35px;
    font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
    font-weight: 600;
    border-bottom: 2px solid #0084ff;
    line-height: 55px;
    color: #fff;
.clock .bright {
font-size: 100px;
color: #7dcfff
/* wind speed selector */
.currentweather &gt; .module-content &gt; div &gt; div.normal.medium &gt; *:nth-child(2),
/* wind direction selector */
.currentweather &gt; .module-content &gt; div &gt; div.normal.medium &gt; *:nth-child(3),
/* sunset/sunrise time selector */
.currentweather &gt; .module-content &gt; div &gt; div.normal.medium &gt; *:nth-child(6){
    color: white;
#module_4_currentweather header {
color: #FFFFFF;
border-bottom: 1px solid #FFFFFF;
#module_4_currentweather .wi-sunrise {
color: #fff;
]]></description><link>https://forum.magicmirror.builders/post/70499</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/70499</guid><dc:creator><![CDATA[Hellonoonan]]></dc:creator><pubDate>Thu, 12 Mar 2020 15:21:37 GMT</pubDate></item><item><title><![CDATA[Reply to costum.css  modified but font color still the same on Sat, 23 Dec 2017 00:54:13 GMT]]></title><description><![CDATA[<p dir="auto">ha…it works</p>
<p dir="auto">thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/32651</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32651</guid><dc:creator><![CDATA[Wurzelxquadrat]]></dc:creator><pubDate>Sat, 23 Dec 2017 00:54:13 GMT</pubDate></item><item><title><![CDATA[Reply to costum.css  modified but font color still the same on Fri, 22 Dec 2017 22:53:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wurzelxquadrat" aria-label="Profile: Wurzelxquadrat">@<bdi>Wurzelxquadrat</bdi></a></p>
<pre><code>.compliments .bright {
color : #ff0000;
]]></description><link>https://forum.magicmirror.builders/post/32647</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32647</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 22 Dec 2017 22:53:04 GMT</pubDate></item></channel></rss>
