<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Magic mirror Pi3 + Windows 7 1.60m x 0.60m]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">First of all, I want to thank all the contributors of this forum without whom I could not have created my mirror.</p>
<p dir="auto">It has been about three months since I attended this forum silently to finally be able to present you my work.</p>
<p dir="auto">I wanted to make a mirror to put it in my living room above a buffet.</p>
<p dir="auto">The buffet being very long, it was necessary to create a mirror imposing enough to dress the wall.</p>
<p dir="auto">So I left on dimensions of 1.60 meters by 0.60 meter.</p>
<p dir="auto">This allowed me to go through a 32-inch screen.</p>
<p dir="auto">having a home containing a lot of home automation (blinds, lights, heating, cameras, …) I wanted to be able to order some of my equipment thanks to the mirror.</p>
<p dir="auto">So I started to install magic mirror on a raspberry pi 3. I started to have problems with the display of the cameras on magic mirror. Even with a 32-inch screen, there is a moment when all the modules you want to put have no place to display.</p>
<p dir="auto">So, as I had room, I told myself that I could add a separate 19-inch screen for the cameras, on a Windows computer that I used to PVR.</p>
<p dir="auto">so I insert in the mirror:</p>
<p dir="auto">1 raspberry 3 for magic mirror<br />
1 32-inch screen for the magic mirror</p>
<p dir="auto">1 acer veriton under windows 7 for cameras<br />
1 19-inch screen for cameras.</p>
<p dir="auto">I started by mounting the frame. I wanted the mirror glass to be directly glued to the chassis with a 5 cm deflection to hide all the switches.</p>
<p dir="auto">In addition, it was necessary that the 5 cm of the mirror is opaque because I wanted to put an LED strip for the light. so I had a special primer for car windshields.</p>
<p dir="auto">For the mirror, I’m lucky to have a friend who works in a factory. So I could have a 6mm laminated glass spy mirror of 1.60 * 0.60 at a very good price.</p>
<p dir="auto">I stuck the mirror on the chassis with windshield glue.<br />
 <br />
after all these explanations, place some photos:</p>
<p dir="auto"><img src="/assets/uploads/files/1514319811905-save_20171226_115611.jpeg" alt="0_1514319809835_SAVE_20171226_115611.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514318125131-img_20171113_122408-800x600.jpg" alt="0_1514318123933_IMG_20171113_122408 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514318154046-img_20171113_122425-800x600.jpg" alt="0_1514318152778_IMG_20171113_122425 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514319898615-img_20171113_122439-800x600.jpg" alt="0_1514319896765_IMG_20171113_122439 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514319922163-img_20171114_165711-800x600.jpg" alt="0_1514319920981_IMG_20171114_165711 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514319967622-img_20171209_173620-800x600.jpg" alt="0_1514319966563_IMG_20171209_173620 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514320008915-img_20171215_170144-800x600.jpg" alt="0_1514320007094_IMG_20171215_170144 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514320151734-img_20171215_170205-800x600.jpg" alt="0_1514320150372_IMG_20171215_170205 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514320169203-img_20171215_170144-800x600.jpg" alt="0_1514320168388_IMG_20171215_170144 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514320226620-img_20171226_203457-800x600.jpg" alt="0_1514320225785_IMG_20171226_203457 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514320251408-img_20171226_203507-800x600.jpg" alt="0_1514320250573_IMG_20171226_203507 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514320281819-img_20171226_203518-800x600.jpg" alt="0_1514320280859_IMG_20171226_203518 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514320300414-img_20171226_203536-800x600.jpg" alt="0_1514320299634_IMG_20171226_203536 [800x600].jpg" class=" img-fluid img-markdown" /><br />
I added to magic mirror the OPENJARVIS solution for voice control.</p>
<p dir="auto">I plugged a rf 433 module on the ft and I can ask the mirror to turn on the lights, to open the shutters.</p>
<p dir="auto">With jarvis I can have the weather, the radio, the way … to the voice. I think it’s a good complement for magic mirror.</p>
<p dir="auto">I installed the following modules:</p>
<p dir="auto">[Remote-Control] Shutdown, Configure and Update your MagicMirror<br />
Calendar Monthly<br />
Calendar<br />
My commute (x3)<br />
Soccer live score<br />
Soccer<br />
World<br />
Clock<br />
Suncalc<br />
Wunderground,<br />
Newsfeed,<br />
Snow</p>
<p dir="auto">I failed to install the following modules:</p>
<p dir="auto">MMM-NOAA - Another Weather Module (each indicates standby but no info appears)<br />
MMM-Jarvis-Voice-Control (the microphone does not appear on the magic mirror interface)</p>
<p dir="auto">Here…</p>
<p dir="auto">I hope I have not been too long in the presentation.</p>
<p dir="auto">Hoping that in my turn I can help forum members as you have helped me a lot.</p>
<p dir="auto">PS: Sorry for the translation … Google translate is my friend;)</p>
]]></description><link>https://forum.magicmirror.builders/topic/5901/magic-mirror-pi3-windows-7-1-60m-x-0-60m</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 01:33:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/5901.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Dec 2017 20:32:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Wed, 10 Jan 2018 10:28:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris" aria-label="Profile: Chris">@<bdi>Chris</bdi></a><br />
Thanks for the detailed info!</p>
]]></description><link>https://forum.magicmirror.builders/post/33734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33734</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Wed, 10 Jan 2018 10:28:57 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Wed, 10 Jan 2018 08:32:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a> said in <a href="/post/33672">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto">Wooooooow! That one is really stunning :) congratulations, bravo, super!</p>
<p dir="auto">Hello,<br />
Thank you for the compliments,</p>
<p dir="auto">what glue do you use?</p>
<p dir="auto">3M glue with car windshield ref. 08603<br />
<img src="https://s-b-c-i.fr/1651-thickbox_default/colle-pu-pre-brise-1k-3m-cartouche-310ml.jpg" alt="text alternatif" class=" img-fluid img-markdown" /></p>
<p dir="auto">And what did you use to cover the outer glass (leds)?!</p>
<p dir="auto">3M hanging primer ref. 58012<br />
<img src="https://m.color-box.eu/ori-primaire-pour-collage-pare-brise-30ml-1464.jpg" alt="text alternatif" class=" img-fluid img-markdown" /></p>
<p dir="auto">For the frame, medium-type wood.<br />
The thickness of the chassis depends on the size of the mirror,</p>
<p dir="auto">cordially</p>
]]></description><link>https://forum.magicmirror.builders/post/33728</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33728</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Wed, 10 Jan 2018 08:32:39 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Tue, 09 Jan 2018 21:19:23 GMT]]></title><description><![CDATA[<p dir="auto">Wooooooow! That one is really stunning :) congratulations, bravo, super!</p>
<p dir="auto">Two question, what glue do you use? Brand or shop?  And what did you use to cover the outer glass (leds)?</p>
]]></description><link>https://forum.magicmirror.builders/post/33672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33672</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Tue, 09 Jan 2018 21:19:23 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Tue, 09 Jan 2018 09:16:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayman" aria-label="Profile: hayman">@<bdi>hayman</bdi></a></p>
thanks for the compliment</p>
<p dir="auto">Do you want to talk about the open-jarvis solution or the MMM-Jarvis-Voice-Control module?</p>
<p dir="auto">For open-jarvis, it works very well and there are many plug-ins available.<br />
By cons, I did not try to reinstall MMM-Jarvis-Voice-Control.</p>
<p dir="auto">I am fighting with MMM-Assistant right now … :s</p>
]]></description><link>https://forum.magicmirror.builders/post/33645</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33645</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Tue, 09 Jan 2018 09:16:44 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Tue, 09 Jan 2018 09:01:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris" aria-label="Profile: Chris">@<bdi>Chris</bdi></a> said in <a href="/post/33081">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto">o over the right topic to share</p>
<p dir="auto">very nice work…</p>
<p dir="auto">is the Jarvis working know … ?</p>
]]></description><link>https://forum.magicmirror.builders/post/33643</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33643</guid><dc:creator><![CDATA[hayman]]></dc:creator><pubDate>Tue, 09 Jan 2018 09:01:37 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Sun, 31 Dec 2017 10:48:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/enettekoven" aria-label="Profile: enettekoven">@<bdi>enettekoven</bdi></a> said in <a href="/post/33020">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto">This. Is. Awesome!</p>
<p dir="auto">My jaw still hurts from when it fell to the ground of amazement :-O</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> said in <a href="/post/33032">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto">Wow this is looking awesome, one of the best I have seen so far.</p>
<p dir="auto">Thank you very much for the compliments.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/33041">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto">WOW very nice job!!!   I don’t recall seeing you asking questions in the NOAA weather module forum…</p>
<p dir="auto">In fact, I did not ask any questions on the subject. I tried by myself by reading all the posts.</p>
<p dir="auto">However, I do not admit to being defeated … I was going to try to make it work again today.<br />
I’ll go over the right topic to share the results.</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.magicmirror.builders/post/33081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33081</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Sun, 31 Dec 2017 10:48:35 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Sat, 30 Dec 2017 15:54:01 GMT]]></title><description><![CDATA[<p dir="auto">WOW very nice job!!!   I don’t recall seeing you asking questions in the NOAA weather module forum…</p>
]]></description><link>https://forum.magicmirror.builders/post/33041</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33041</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sat, 30 Dec 2017 15:54:01 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Sat, 30 Dec 2017 08:22:51 GMT]]></title><description><![CDATA[<p dir="auto">Wow this is looking awesome, one of the best I have seen so far.</p>
]]></description><link>https://forum.magicmirror.builders/post/33032</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33032</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 30 Dec 2017 08:22:51 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Sat, 30 Dec 2017 00:33:51 GMT]]></title><description><![CDATA[<p dir="auto">This. Is. Awesome!</p>
]]></description><link>https://forum.magicmirror.builders/post/33020</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33020</guid><dc:creator><![CDATA[enettekoven]]></dc:creator><pubDate>Sat, 30 Dec 2017 00:33:51 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Wed, 27 Dec 2017 10:46:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter" aria-label="Profile: Peter">@<bdi>Peter</bdi></a> said in <a href="/post/32825">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto">Very impressive!<br />
Nice job!<br />
Peter</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said in <a href="/post/32834">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris" aria-label="Profile: Chris">@<bdi>Chris</bdi></a></p>
<p dir="auto">I dig it man! I really enjoy the story and the pictures. You’ve done an excellent job. Congratulations! :-)</p>
<p dir="auto">Thank you for the compliments.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cruunnerr" aria-label="Profile: cruunnerr">@<bdi>cruunnerr</bdi></a> said in <a href="/post/32836">Magic mirror Pi3 + Windows 7 1.60m x 0.60m</a>:</p>
<p dir="auto">looks really really nice. Well done! :D</p>
<p dir="auto">Did you really just glued the mirror? i would be scared that the glass will fall…<br />
Anyhow it looks great !</p>
<p dir="auto">In fact, I glued the ice on the wooden frame using glue for automobile windshields.</p>
<p dir="auto">For fixing to the wall, it is fixed thanks to specific fixing brackets.</p>
<p dir="auto"><img src="/assets/uploads/files/1514371440840-img_20171226_120915-800x600.jpg" alt="0_1514371439493_IMG_20171226_120915 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1514371463971-img_20171227_113537-800x600.jpg" alt="0_1514371462179_IMG_20171227_113537 [800x600].jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Normally he should not move :)</p>
]]></description><link>https://forum.magicmirror.builders/post/32862</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32862</guid><dc:creator><![CDATA[Chris]]></dc:creator><pubDate>Wed, 27 Dec 2017 10:46:52 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Wed, 27 Dec 2017 00:09:42 GMT]]></title><description><![CDATA[<p dir="auto">looks really really nice. Well done! :D</p>
]]></description><link>https://forum.magicmirror.builders/post/32836</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32836</guid><dc:creator><![CDATA[cruunnerr]]></dc:creator><pubDate>Wed, 27 Dec 2017 00:09:42 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Tue, 26 Dec 2017 23:17:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris" aria-label="Profile: Chris">@<bdi>Chris</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/32834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32834</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 26 Dec 2017 23:17:33 GMT</pubDate></item><item><title><![CDATA[Reply to Magic mirror Pi3 + Windows 7 1.60m x 0.60m on Tue, 26 Dec 2017 20:38:02 GMT]]></title><description><![CDATA[<p dir="auto">Very impressive!<br />
Nice job!<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/post/32825</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32825</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Tue, 26 Dec 2017 20:38:02 GMT</pubDate></item></channel></rss>
