<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar and newsfeed loading...]]></title><description><![CDATA[<p dir="auto">Hi everybody,</p>
<p dir="auto">I’m trying to set up my MM in my Rpi 2+ but I’m not able to have calendar and newsfeed working. They’re stilll loading.<br />
Clock, weather and forecast weather worked fine.</p>
<p dir="auto">For the Calendar, I’ve tried my private Google Calendar and others public calendars but no one works.<br />
For the newsfeed, I’ve tried many rss feeds and it’s still the same thing.</p>
<p dir="auto">Node.js is v6.5</p>
<p dir="auto">JSHint says no trouble with my config,js</p>
<p dir="auto">Pull is already up-to-date</p>
<p dir="auto">Thanks for the help</p>
]]></description><link>https://forum.magicmirror.builders/topic/596/calendar-and-newsfeed-loading</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 20:27:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/596.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Sep 2016 13:08:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar and newsfeed loading... on Fri, 09 Sep 2016 11:22:58 GMT]]></title><description><![CDATA[<p dir="auto">Don’t worry. I’ve reinstalled everything from scratch an it works</p>
]]></description><link>https://forum.magicmirror.builders/post/4564</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4564</guid><dc:creator><![CDATA[elfary]]></dc:creator><pubDate>Fri, 09 Sep 2016 11:22:58 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar and newsfeed loading... on Sun, 11 Sep 2016 11:24:35 GMT]]></title><description><![CDATA[<p dir="auto">Starting with npm start dev shows me a lot of errors!!!</p>
<p dir="auto">magicmirror@2.0.0 start /home/pi/MagicMirror<br />
electron js/electron.js “dev”</p>
<pre><code>npm ERR! Linux 4.4.13-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" "dev"
npm ERR! node v6.5.0
npm ERR! npm  v3.10.3
npm ERR! code ELIFECYCLE
npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
npm ERR! If you do, this is most likely a problem with the magicmirror package,
npm ERR! not with npm itself.
npm ERR!     electron js/electron.js "dev"
npm ERR!     npm bugs magicmirror
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls magicmirror
]]></description><link>https://forum.magicmirror.builders/post/4545</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4545</guid><dc:creator><![CDATA[elfary]]></dc:creator><pubDate>Sun, 11 Sep 2016 11:24:35 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar and newsfeed loading... on Thu, 08 Sep 2016 14:11:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elfary" aria-label="Profile: elfary">@<bdi>elfary</bdi></a> any errors in the terminal or electron console (<code>CMD+SHIFT+I</code> or starting mirror with <code>npm start dev</code>)?</p>
]]></description><link>https://forum.magicmirror.builders/post/4503</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4503</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Thu, 08 Sep 2016 14:11:22 GMT</pubDate></item></channel></rss>
