<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Fitbit]]></title><description><![CDATA[<h1>Description:</h1>
<p dir="auto"><a href="https://github.com/SVendittelli/MMM-fitbit" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-fitbit</a> allows you to view your fitbit data right on your mirror!</p>
<p dir="auto">It is fully configurable to allow you to display:</p>
<ul>
<li>Steps</li>
<li>Floors climbed</li>
<li>Caloriees burnt</li>
<li>Distance Walked</li>
<li>Active minutes</li>
<li>Time asleep</li>
<li>Resting heart rate</li>
</ul>
<h1>Screenshot:</h1>
<p dir="auto"><img src="/uploads/files/1462206171732-fitbiteg.png" alt="0_1462206174431_fitbiteg.PNG" class=" img-fluid img-markdown" /></p>
<h1>Download:</h1>
<p dir="auto">[card:SVendittelli/MMM-fitbit]</p>
<hr />
<h2>Initial Version</h2>
<ul>
<li>Development is ongoing and there may still be bugs to squash so please feel free to message me about it!</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/6/mmm-fitbit</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 07:39:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 May 2016 16:28:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Fitbit on Thu, 23 Aug 2018 09:13:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jchenaud" aria-label="Profile: jchenaud">@<bdi>jchenaud</bdi></a> said in <a href="/post/43709">MMM-Fitbit</a>:</p>
<p dir="auto">e i have make something fail</p>
<p dir="auto">hey for new user i have find the probleme<br />
replace <code>this.config.update_interval*60*1000);</code><br />
by</p>
<pre><code>this.config.update_interval*1000);
]]></description><link>https://forum.magicmirror.builders/post/43715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43715</guid><dc:creator><![CDATA[jchenaud]]></dc:creator><pubDate>Thu, 23 Aug 2018 09:13:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Thu, 23 Aug 2018 06:05:03 GMT]]></title><description><![CDATA[<p dir="auto">awesome !!!</p>
<p dir="auto">just one think :  update dont work : i have update_interval: 60 but my data never change (i have make a synchronization on my charg2 on my phone and my data are on net )<br />
for update i need relaunch my MM<br />
maybe i have make something fail</p>
]]></description><link>https://forum.magicmirror.builders/post/43709</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/43709</guid><dc:creator><![CDATA[jchenaud]]></dc:creator><pubDate>Thu, 23 Aug 2018 06:05:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Fri, 08 Sep 2017 17:47:19 GMT]]></title><description><![CDATA[<p dir="auto">hi there was asking if a work around has been implemented on the Fitbit scale to display weight, bmi etc would love to pre order the Aria 2 just for my smart mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/27800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/27800</guid><dc:creator><![CDATA[rentaro]]></dc:creator><pubDate>Fri, 08 Sep 2017 17:47:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Sat, 21 Jan 2017 21:36:56 GMT]]></title><description><![CDATA[<p dir="auto">Also a withings Adaption would be nice :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/11939</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11939</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Sat, 21 Jan 2017 21:36:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Fri, 20 Jan 2017 12:55:45 GMT]]></title><description><![CDATA[<p dir="auto">Could this module be adapted to work for the Misfit?</p>
]]></description><link>https://forum.magicmirror.builders/post/11742</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11742</guid><dc:creator><![CDATA[nbrenn]]></dc:creator><pubDate>Fri, 20 Jan 2017 12:55:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Fri, 06 Jan 2017 21:15:42 GMT]]></title><description><![CDATA[<p dir="auto">I just got a fitbit scale as well and would love a way to track weight in a chart</p>
]]></description><link>https://forum.magicmirror.builders/post/10528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10528</guid><dc:creator><![CDATA[onetwankyfive]]></dc:creator><pubDate>Fri, 06 Jan 2017 21:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Fri, 06 Jan 2017 20:11:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi! I would like to read out the “weight” as well from the user(s).<br />
I’m currently syncing the weight with my Withings account. So the weight is always up to date here as well. I tried just to add “weight” in the resources section. But that did not work. :) Is there anything I can do to fix it?</p>
<p dir="auto">Best regards Erik</p>
]]></description><link>https://forum.magicmirror.builders/post/10526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10526</guid><dc:creator><![CDATA[Snille]]></dc:creator><pubDate>Fri, 06 Jan 2017 20:11:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Thu, 15 Dec 2016 12:28:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/azrael-masters" aria-label="Profile: Azrael-Masters">@<bdi>Azrael-Masters</bdi></a> The way it is currently built, it’ll make two requests for the same user. It wouldn’t be impossible for it to handle multiple users, but would require some work.</p>
<p dir="auto">Feel free to read the API documentation and submit a pull request!</p>
]]></description><link>https://forum.magicmirror.builders/post/9402</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9402</guid><dc:creator><![CDATA[Vendittelli]]></dc:creator><pubDate>Thu, 15 Dec 2016 12:28:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Thu, 15 Dec 2016 11:49:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leemul" aria-label="Profile: leemul">@<bdi>leemul</bdi></a> I tried it by my own, but it doesn’t seem to work.<br />
I placed it 2 times on my mirror, but it doesn’t grab Infos from fitbit anymore.<br />
Maybe it’s by design of the API / Module?</p>
]]></description><link>https://forum.magicmirror.builders/post/9399</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/9399</guid><dc:creator><![CDATA[Azrael Masters]]></dc:creator><pubDate>Thu, 15 Dec 2016 11:49:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Mon, 05 Dec 2016 12:09:27 GMT]]></title><description><![CDATA[<p dir="auto">The module looks great, well done. Quick question though, is it possible to incorporate multiple profiles and rotate through them?</p>
<p dir="auto">For example, we’ve a few users in the house with a fitbit and it would be useful to display the module for each user on rotation.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/8948</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/8948</guid><dc:creator><![CDATA[leemul]]></dc:creator><pubDate>Mon, 05 Dec 2016 12:09:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Sat, 15 Oct 2016 06:31:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maelremrem" aria-label="Profile: Maelremrem">@<bdi>Maelremrem</bdi></a>  I haven’t added that functionality yet, the API I use doesn’t yet support it. Feel free to send a pull request to make the JavaScript do it though!</p>
]]></description><link>https://forum.magicmirror.builders/post/6340</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/6340</guid><dc:creator><![CDATA[Vendittelli]]></dc:creator><pubDate>Sat, 15 Oct 2016 06:31:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Fri, 09 Sep 2016 12:42:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/onetwankyfive" aria-label="Profile: onetwankyfive">@<bdi>onetwankyfive</bdi></a> Currently working on a fix, job hunting got in the way!</p>
]]></description><link>https://forum.magicmirror.builders/post/4569</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4569</guid><dc:creator><![CDATA[Vendittelli]]></dc:creator><pubDate>Fri, 09 Sep 2016 12:42:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Fri, 09 Sep 2016 12:41:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jgom" aria-label="Profile: jgom">@<bdi>jgom</bdi></a> Yes, I’d like to add that functionality, but I don’t have an Aria so can’t test it! If you do, then feel free to send a pull request to the github repo!</p>
]]></description><link>https://forum.magicmirror.builders/post/4568</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/4568</guid><dc:creator><![CDATA[Vendittelli]]></dc:creator><pubDate>Fri, 09 Sep 2016 12:41:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Sat, 13 Aug 2016 08:19:24 GMT]]></title><description><![CDATA[<p dir="auto">I just finished to install your module and I love it ! But how a I can make the distances in Kms ?</p>
]]></description><link>https://forum.magicmirror.builders/post/3672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3672</guid><dc:creator><![CDATA[Maelremrem]]></dc:creator><pubDate>Sat, 13 Aug 2016 08:19:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Tue, 02 Aug 2016 07:32:35 GMT]]></title><description><![CDATA[<p dir="auto">Maaann you made the module I wanted to make on the MM1 :O Thx !</p>
]]></description><link>https://forum.magicmirror.builders/post/3251</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/3251</guid><dc:creator><![CDATA[Maelremrem]]></dc:creator><pubDate>Tue, 02 Aug 2016 07:32:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Sat, 23 Jul 2016 17:41:23 GMT]]></title><description><![CDATA[<p dir="auto">Is this module going to get fixed in the future?</p>
]]></description><link>https://forum.magicmirror.builders/post/2835</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2835</guid><dc:creator><![CDATA[onetwankyfive]]></dc:creator><pubDate>Sat, 23 Jul 2016 17:41:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Sun, 12 Jun 2016 13:26:20 GMT]]></title><description><![CDATA[<p dir="auto">is it possible to incorporate the fitbit aria scale into this module as well?  Have a weight chart created to track body weight over time?  I first saw it done on a android smart mirror with a withings wifi scale.</p>
<p dir="auto">link : <a href="https://github.com/maxbbraun/mirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/maxbbraun/mirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/1588</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1588</guid><dc:creator><![CDATA[jgom]]></dc:creator><pubDate>Sun, 12 Jun 2016 13:26:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Sun, 12 Jun 2016 10:20:45 GMT]]></title><description><![CDATA[<p dir="auto">Sadly it seems like there is no API :(</p>
]]></description><link>https://forum.magicmirror.builders/post/1584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1584</guid><dc:creator><![CDATA[paviro]]></dc:creator><pubDate>Sun, 12 Jun 2016 10:20:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Fri, 10 Jun 2016 12:45:46 GMT]]></title><description><![CDATA[<p dir="auto">wonder if there is any way to grab Apple Watch or Health data</p>
]]></description><link>https://forum.magicmirror.builders/post/1545</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1545</guid><dc:creator><![CDATA[cyberphox]]></dc:creator><pubDate>Fri, 10 Jun 2016 12:45:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Thu, 09 Jun 2016 19:42:32 GMT]]></title><description><![CDATA[<p dir="auto">For troubleshooting or HOWTO questions, please post in the Troubleshooting thread:<br />
<a href="https://forum.magicmirror.builders/topic/214/fitbit/1">https://forum.magicmirror.builders/topic/214/fitbit/1</a></p>
]]></description><link>https://forum.magicmirror.builders/post/1531</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1531</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Thu, 09 Jun 2016 19:42:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Fitbit on Mon, 02 May 2016 17:06:22 GMT]]></title><description><![CDATA[<p dir="auto">Nice one! Very beautiful!</p>
]]></description><link>https://forum.magicmirror.builders/post/10</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Mon, 02 May 2016 17:06:22 GMT</pubDate></item></channel></rss>
