<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change colors on each news feed]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I’m searching a way to change color on newsfeed module.<br />
The hard is to find a simply way to change color about each feed.<br />
Can someone help me?<br />
Thanks<br />
Magic mirror is a good world 😉</p>
]]></description><link>https://forum.magicmirror.builders/topic/6014/change-colors-on-each-news-feed</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 10:58:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/6014.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Dec 2017 19:39:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change colors on each news feed on Tue, 16 Jan 2018 01:43:26 GMT]]></title><description><![CDATA[<p dir="auto">Thank you!<br />
My problem is solved follow your readme!<br />
Great thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/34047</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34047</guid><dc:creator><![CDATA[saljoke]]></dc:creator><pubDate>Tue, 16 Jan 2018 01:43:26 GMT</pubDate></item><item><title><![CDATA[Reply to Change colors on each news feed on Sun, 14 Jan 2018 17:18:49 GMT]]></title><description><![CDATA[<p dir="auto">If anyone is interested, as a consequence of this post (and a +1 I saw somewhere…), I’ve created a PR adding this functionality to the core <code>newsfeed</code> module. I don’t know that it will be accepted, but hope someone finds it useful.</p>
<p dir="auto">If anyone on the forums is interested, you can use <a href="https://github.com/MichMich/MagicMirror/pull/1137" target="_blank" rel="noopener noreferrer nofollow ugc">PR #1137 on MM</a> to check it out.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/33937</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/33937</guid><dc:creator><![CDATA[ninjabreadman]]></dc:creator><pubDate>Sun, 14 Jan 2018 17:18:49 GMT</pubDate></item></channel></rss>
